Fatboy148!
50-cents per glove? I'm in - thanks [SIZE=5]Fatboy148![/SIZE] !
I'm thinking it's 12 pair or 24 gloves. I base that on the stock number:
B62081-L12P​
I think that's size Large and 12 Pair.
So I'm hoping for 24 gloves......
ETA...
Confirmed by reading the last sentence of the description... "These come in a pack of 12 pairs for your convenience."
ching0n
These came in. Despite me thinking they'd be clones of one another, the pictures do reflect the physical differences. The cheap one came w/a shorter pilot bit w/poor runout, it also has less meat where the set screw goes so it's easier for it to come off when inserting the bit. Despite that, the cheap one cut through 3/16" mild steel like butter. The brazing was a bit messy so we'll see how long those carbides stay in place. This is a decent deal imo if you don't care to be all that accurate (electrical box holes for instance). I might pick two more.
The 7$ one came w/two pilot bits that were longer and w/much better runout. It seemed to not cut as easy as the cheap one but got the job done just fine. I'll keep both since the cheap one needed a better pilot bit and the pricier one came w/a spare.
I picked this up to chamfer holes, it's for stone but I'll be using it on steel:
looks to do the job but I'm not a fan of having it on a grinder since it's easy to not go straight and have an uneven chamfer. Will have to look for a drill press adapter (manual deburring tool above, chamfer tool below):
burger
Erf
darrowco
Los Angeles (California)
B62081-L12P​
ETA...
Yep, you are right - 12-pair showed up, not a bad deal.
ching0n
B62081-L12P​
ETA...
just got these; it's indeed 12 pairs, good fit, good deal. thanks.
srs2000
VEVOR Car Sound Deadening Mat, 400 mil 16 sqft Automotive Sound Deadener, High Density Foam Sound Deadener Material & Heat Barrier, Double Layer Waterproof Structure Acoustic Insulation Mat​
More car insulation / sound deadening (not sure this would help much for sound) from Vevor. Its adhesive and about .4" of closed cell foam with a foil sheet on top. I couldn't come up with a use for this for normal cars past maybe above the headliner. I could see its use if you are insulating a trailer/camper/van/RV/etc though. Car audio people say closed cell foam like this won't actually help with noise, especially with a foil exterior so I'd treat it more like insulation.
16 square feet is $13.99 but there is a 20% off coupon. $11.19 after coupon.
FireShot Capture 116 - Amazon.com_ VEVOR Car Sound Deadening Mat, 400 mil 16 sqft Automotive_ ...jpg
ching0n
Yes.
Shows 20c/each.
Cle-Line does this often. There were 1/8" bits in packs of 12 for $1 a few weeks ago.
well, looks like I'll be able to fill much of 1/3 of those vevor bit dispensers I got a while back :D
ching0n
More of a heat barrier application I reckon; ****** tunnel, firewall/bulkhead/underhood
ching0n
FWIW; I've bought two plasmas and some of the better featured imports are the "bestarc", "amico" and "hynade". I got a bestarc & "ghuozi" latter of which resembles the amico. What I like about these is the integral pressure regulator on the front as well as the moisture trap being better sorted (I think it also autodrains). Some like the amico and hynade have the trap built into the chassis so it's not bound to get bumped w/something. That yeswelder is a good deal though and I believe they have decent customer support.
srs2000
BroncoAZ
Flexzilla Air Hose, 3/8 in. x 25 ft., 1/4 in. MNPT Fittings, Heavy Duty, Lightweight, Hybrid, ZillaGreen - HFZ3825YW2 https://www.amazon.com/dp/B0021WVO8W?tag=atomicindus08-20
This is now down to 12.98.
50 foot hose is about double the price at 24.98. $10 cheaper than normal.
Flexzilla Air Hose, 3/8 in. x 50 ft., 1/4 in. MNPT Fittings, Heavy Duty, Lightweight, Hybrid, ZillaGreen - HFZ3850YW2 https://www.amazon.com/dp/B001C6NC7O?tag=atomicindus08-20
The 50’ hose is less now than I paid in 2019, and the two I bought then are still holding up fine.
