Wall mount panel for bins that isn't expensive?
AceofSpad3s
BTL-A4
Santa Clarita
Here's a few ideas:
For option 1 bend a srtip of metal to the profile shown and bolt it to the wall
For option 2 use a straight strip of metal and some sort of spacer and bolt that to the wall.
Firebrick43
West central Indiana
Youngandfree
VA
I have a bunch of the akro mills type bins that are supposed to be able put on louvered panels, but not the mounting system. HF sells those cheap parts racks for $25 with the bins that has a mount for them, but if I try and source something like that by itself, it is very expensive. https://www.amazon.com/Akro-Mils-30136-Louvered-Mounting-AkroBins/dp/B003BT4G8Y?tag=atomicindus08-20
Does anyone know of any cheaper options? Don't want to spend $100 to put up some $1 bins if I have an option.
These are $25 each
kbuhagiar
Escondido, CA
vwpieces
Hills, PA
Offf, I bought several of those just a few years ago for around 25$ a piece.
;) Yeah 4 Pack
Ordered on September 25, 2023 as AWD.
And a one pack
Yet another order but back in 2018 for retail.
But todays retail is absurd.
Edit: And forgot this one, also AWD
southalabama
Brewton AL
I’ve seen those metal shelf brackets used.
Think I saw it here but my Google foo isn’t working tonight
Whoops wrong thread.
Found it
rayra
Escaped from Los Angeles
Cmon people. All the OP needs is some flat strips of metal screwed to the wall studs with some fender washers behind it as spacers. Metal strips of a thickness suitable to hanging the AKRO bins. Which IIRC is <1/8".
And most 'big box' hardware stores have racks of metals to pick from. Although their prices these days are terribly high.
rharman
SoCal
The plastic rails that came with my Akro stuff are probably right at 1/16" and have a sharp edge to them - likely to aid in sliding the bins on.
HD & Lowes have stupid high prices on their metal/aluminum items. I rarely need steel and I'm lucky to have a really good aluminum supply house nearby.
johnre
Portland, OR
While we're on the subject, does anyone know what the row-to-row spacing is supposed to be?
There are many different size Akro-Mils bins available, and I'm sure there's there's a common increment to the vertical size such that, with the correct spacing, they all can fit on a given panel.
