ching0n
Thanks Chingon! In for the boat flooring.
As am I. Thanks!
just a warning, upon closer inspection these don't seem to be simply rubber mats (for work-table duty) but EVA foam topped. Perfectly fine for boats but don't know how well it holds up to oil/grease/etc for tool box tops as I had suggested. I'll still get it and maybe line other surfaces w/less noxious use.
stillnostrebor
SW Missouri
I am planning to use it for something much closer to the intended use... someday... maybe.:)
ching0n
You might want to search vevor and sort price from low to high. They're clearing stuff out and there are some deep discounts. $6 space heater, $8 100 foot pressure washer drain clearer, $10 bar cart, plastic welding kit, $10 diamond drill bits, Tesla charger adapter thing that I wouldn't trust, .... There's just a lot of stuff that may or may not be ****.
VEVOR Pressure Washer Hose, 100FT, 1/4" Kink Free Brass Thread Replacement For Most Brand Pressure Washers, 3/4'' Bending Radius, 4200 PSI Heavy Duty Power Washer Extension Spray Nozzle https://www.amazon.com/dp/B0CF59DFSX?tag=atomicindus08-20
VEVOR 6PCS Diamond Drill Bits 3/4",1-1/8",1-1/4",1-1/2",1-3",2" Tile Diamond Hole Saw Kit Vacuum Brazed Diamond Drill Bit 0.59in Segment Tile Hole Saw w Storage Case for Tile Ceramic Porcelain Marble https://www.amazon.com/dp/B09CKH62MZ?tag=atomicindus08-20
VEVOR 6 x 18 inch Drop-in Fire Pit Pan, Rectangular Stainless Steel Fire Pit Burner, Natural & Propane Gas Fire Pan H-Burner 90,000 BTU for Indoor or Outdoor Use https://www.amazon.com/dp/B0CGX3QPCS?tag=atomicindus08-20
VEVOR Electric Space Heater with Thermostat Remote Control, 2-Level Adjustable Quiet Ceramic Heater Fan, 16in Tip-Over Overheat Protection Small Heaters Built-in Filter for Office Room Desk Indoor Use https://www.amazon.com/dp/B0CQN97WKM?tag=atomicindus08-20
VEVOR 24 inch Round Drop-in Fire Pit Pan, Stainless Steel Fire Pit Burner, Natural & Propane Gas Fire Pan 92,000 BTU, for Indoor or Outdoor Use https://www.amazon.com/dp/B0CGX3HVKG?tag=atomicindus08-20
VEVOR Fire Pit Grate, Heavy Duty Iron Round Firewood Grate, Round Wood Fire Pit Grate 19", Firepit Grate with Black Paint, Fire Grate with 4 Removable Round Legs for Burning Fireplace and Firepits https://www.amazon.com/dp/B09BC1264T?tag=atomicindus08-20
VEVOR Plastic Welding Kit, 100W Plastic Welder Soldering Iron Gun, Car Bumper Repair Kit with 2 Welding Tips, 1 Soldering Tip, 20 Plastic Welding Rods for Kayak/Toys/Plastic Tested to UL Standards https://www.amazon.com/dp/B0CJBMVF4X?tag=atomicindus08-20
in4 the hi-pressure hose and space heater. I don't have a high pressure washer that goes that high but it's 100' of hi-P hose for 8$. I use space heaters as resistive loads sometimes. The diamond hole bits were tempting but looks like some ppl did not get the case and others did not get the circ. saw.
srs2000
Can the pressure washer hose be used with typical pressure washer attachments? From the pics it looks like I'd have to use their jets unless there's an adapter that exists. I haven't had a pressure washer long enough to know enough about it.
Wiz02
Southeastern PA
this is a different make but I suspect it's merely a rebrand. I don't need a scope, I don't know how to use one really, but it's a hard deal to pass up; we'll see if anything majorly wrong when it arrives based on those two videos.
I kind of wish it had a signal generator and maybe CAN bus sniffing though.
After close to 30 years of disuse, I have lost all my analog and digital design and troubleshooting skills.
As cool as that scope is, I have too many projects to buy it in the hope that someday I will use it.
ching0n
I believe mine would work w/another one of the females included here but I was going more for chopping the hose up to suit length and crimping new fittings:
edit; for its intended purpose it should work as is by plugging into the pistol wand in my machine (and likely many others)
olytdi
Olympia, Washington
Thanks OP -- ordered the crane scale. If you choose "other seller options" for the item, there's a listing for $25 but with $10 off coupon making it $15 and change with free shipping with prime.
ching0n
Another crane scale, the price is right even if accuracy and precision drift around. Thanks ching0n, now I can get a better idea of how much various motorcycles, transmissions, small engines weigh.
I was going to pass on it but my luggage scale maxed out last time I went to buy some scrap.
olytdi
Olympia, Washington
I got tired of having to hold my dog in my arms to weigh him (total weight minus my weight) on a bathroom scale. Now I can just lift him from his harness with the scale.
ching0n
Was looking for a larger electric screwdriver but having needed to take apart a laptop a few weeks back, I'll take it:
this got here today. Solid deal and not that much pricier than the well received 33 pc HF mechanical set. Decent gift option imo.
srs2000
If anyone is interested in that magnetic stirrer they have multiple listings. This one appears identical but has a $6 coupon. I saw so many instances of this happening. Kinda weird.
Limited-time deal: VEVOR Magnetic Stirrer, 0-2000 RPM Stir Plate with Adjustable Speed Knob, 3000mL Plate Stirrer Kit, Stir Bar Included https://www.amazon.com/dp/B0CW5ZXD2R?tag=atomicindus08-20
$4 hot tub mat
VEVOR 74 x 72 Inch Hot Tub Mat, Extra Large Inflatable Hot Tub Pad, Waterproof Slip-Proof Backing, Absorbent Spa Pool Ground Base Flooring Protector Mat Reusable Outdoor & Indoor, Also for Car Repair https://www.amazon.com/dp/B0CRTLKCTM?tag=atomicindus08-20
$20 4 bike rack
VEVOR 4 Bike Rack Garage Storage, Free Standing Gravity Wall Vertical Bike Stand, Sturdy Steel & Easy Assemble, For Road, MTB, and Hybrid Bicycles, Holds Up to 260 Lbs https://www.amazon.com/dp/B0CW34K9MM?tag=atomicindus08-20
I think there is a 2 bike for $10.
$11 7" snap ring pliers
VEVOR 4 Pcs Snap Ring Pliers Set - Heavy Duty 7-inch Internal/External Circlip Pliers Kit (Tip Diameter 0.07'') with Straight/Bent Jaw for Ring Remover Retaining - Storage Pouch Included https://www.amazon.com/dp/B0CDPH3KVG?tag=atomicindus08-20
V
vwpieces
Hills, PA
Found the same when I searched. At least 3 listing for the blue pocket hole jig. $20-76
Roll sound deadener price dropped with 20% off coupon. Coupon only deducts from One roll.
ching0n
$4 hot tub mat
$20 4 bike rack
yeah, i've been searching the same item I come across on amazon for better deals (from vevor). I must've forgotten, good catch. They sell that jacuzzi mat for car garages too but smaller area for the price:
srs2000
VEVOR Air Blower, 450W 0.6HP Inflatable Blower, Portable and Powerful Bounce House Blower, 1750Pa Commercial Air Blower Pump Fan, Used for Inflatable Bouncy Castle and Jump Slides, Yellow https://www.amazon.com/dp/B0B8CMCLWS?tag=atomicindus08-20
$24
I never used one of these for a bounce house but they tend to be pretty strong for blowing / cooling stuff. Mine was significantly smaller too.
ching0n
There's dozens of these things at this price point and ordinarily would shy away from wire ones because they sag w/heavy power tools but I think are ok for 12v drivers. I find myself wanting certain tools quickly accessible by the garage door and this one fits the bill I think plus it's modular. Pro-tip, if you want to avoid sag, look for one w/a sturdy upper shelf from which you can wire the bottom supports:
also came across this one that may work for people's toolboxes:
XXL__
Truer words have never been spoken.
I have bought all kinds of "stuff" that showed up on GJ Hot Deals. I seem to be unable to resist Knipex pliers...
I keep buying side cutters. I have an actual use for them, but I currently have 3 of them still in their clamshell packages. I need help.
Sumboodie
AK
The 50’ hose is less now than I paid in 2019, and the two I bought then are still holding up fine.
They are really hard to keep clean. It's like they soak up grease and oil and then it makes black marks on everything.
Sumboodie
AK
$24
Says $60
