Sawmill
glennm
Better make sure you don’t have a couple of drinks and step out of that door 😳
Slab storage is a great idea, I just have mine in a pile with stickers in between.
R
RivennHewn
PNW
If he's using Trex he's going to be cutting a lot of stringers. Trex requires 9" on center for stairs.
The stairs go away, the door is getting filled in & sided. Thinking I’ll put a little window up high, just for a little light. It was an unnecessary egress. It’ll make better storage for my wife, keeping her stuff out of the garage 😜
R
RivennHewn
PNW
A weak link in my processing boards has been my 1965 Delta Rockwell jointer. I ordered a Byrd Tool Shelix cutter head for it, along with new bearings, pulley, and belt.
I neglected to order a stepped key for the pulley/arbor. One is 5mm and one is 6mm.
I got quoted a $50 minimum order for a $2 part.
Seems a ****** way to do business, but I get it.
Time to make my own. Wore my fingers out, but it worked.
I need to adjust the infeed/outfeed tables tomorrow, before it taste some wood.
PugetDude
Superstition Mountains, AZ
After spending $$$ for the cutter head, bearings, pulley, belt, etc they still wanted to charge you $50 for an in-stock step key that should have been denoted as part of the upgrade package?
****** customer service, IMO. I would have tossed a couple in an envelope and mailed them to you for free with a "Thanks for your business" note. They had an opportunity to provide an exceptional service experience but pissed all over it.
R
RivennHewn
PNW
My thoughts, exactly.
R
RivennHewn
PNW
Even though I’ve taken most of the summer off from milling, I had one 6x6 come out of the kiln with quite a twist. Figured I’d resaw it.
Just started the cut and it all went BANG!
F’d up the belt, blade, and bearings.
Finally got it put back together today. ✅
R
RivennHewn
PNW
I’ve been dreaming up a little “Finishing “ kiln.
Something I can take a “dry” board, and get it really dry. I’ve had a couple projects that I needed a few more boards for, but some boards were at a higher moisture content.
This chopsaw bench has a kiln downstairs.
I found a little 500 Watt heater on Amazon. Cheap. Should do the trick.
I added a couple 2.5” blast gates on the other end for air movement.
The outfeed tables are still in progress.
glennm
That’s a great idea ! How much wood can it hold and does it seem to be working well? I could use a small finishing kiln as well. All our wood is stacked outside covered and should be “seasoned” a bit before use
R
RivennHewn
PNW
Just had the initial fire-up. Haven’t loaded it up yet.
Approx 78” long x 21” deep x 34” high inside dimensions. 29 cubic feet.
hh76
NE Wisconsin
I'm curious to see how this works for you. I've been thinking about putting together something similar.
Do you worry about bringing the temp up higher to sterilize?
R
RivennHewn
PNW
This one isn’t going to hit the 145 degrees needed for bug kill.
I’m afraid that would cause movement in the wood/top.
It would need a bigger heater to hit that temp.
If I’m concerned about it, I’d have to use the big kiln.
Today I added a little frame to keep the material off the concrete, and give it some airflow under the boards.
R
RivennHewn
PNW
Pulled a 30’ Cedar off my neighbor’s yard.
Had to fight a 5 knot current, making it a slow pull. Trying to go faster only made it submarine.
Top was split, but I still got two 12’ sections
