My Small But Growing 1/4" drive Socket Set Collection
I don’t have one. I would suggest that those be primarily for display, judging by how many sockets are cracked, they seem kind of fragile.
I think Lugz has a set
I have two incomplete No. 1208 sets.
The set on the left is missing a couple sockets, the spinner, the midget sliding tee, the adaptor (for the midget sliding tee (female), and the 6" extension.
The set on the right is missing the midget sliding tee and the 6" extension.
The set on the left was the first one shown on the SK thread, at the time, and kicked off a fun identification-guessing process...
LesserSon
PA USA
What @Oldtuleguy and @LesserSon have are No. 1212 sets. The XL extensions - 9"! - are the tell.
Your eyes must have been tired; this IS a 1208 set, missing the 6” spinner and the 7/16” 12pt socket.
If my Duro/Indestro spinners didn’t have hex drive shafts, I’d stick a one in the box. I’ve probably got something S-K (maybe not cad) for the 7/16 socket.
The unmarked (but obviously S-K) 1/4” drive knurled sockets are few and far between. I sent most of the ones I had that weren’t cracked to BK for his set. I’ll check to see if I have any left when I return to the Bay Area.
I have a badly cracked 5/16. There was also similarly configured 3/8 set. These cheapo sets were sold under fulton, tiger,Brazil and probably other names.20240812_103310.jpg20240812_102832.jpg20240812_102834.jpg
F
^ but as near as Don and I were able to determine, the markings on the S-K "Carb-O-Mang" sockets are somewhat unique (two dots- one on each side of size stamp; cross-hatch knurling; NO "S-K" or other markings), and they have that dull "cad" type finish.
F
^ those look like a match (somewhat.) one of the other "weird" things about the "Carb-O-Mang" set was the detents on the "Sliding T handle" - detent ball at both ends!
F
PROTO J47118 25 piece 1/4" drive SAE Socket Wrench Set (with add-ons)
* this set has a few extra pieces and is now 32 pieces *
this set includes:
4704 1/8" 6 pt shallow socket
4705 5/32" 6 pt shallow socket
4706 3/16" 6 pt shallow socket
4707 7/32" 6 pt shallow socket (* two each *)
4708 1/4" 6 pt shallow socket (* two each *)
4709 9/32" 6 pt shallow socket
4710 5/16" 6 pt shallow socket
4711 11/32" 6 pt shallow socket
4712 3/8" 6 pt shallow socket
4714 7/16" 6 pt shallow socket
4716 1/2" 6 pt shallow socket
4718 9/16" 6 pt shallow socket
4708S 1/4" 8 pt shallow socket
4710S 5/16" 8 pt shallow socket
4712S 3/8" 8 pt shallow socket
4706L 3/16" 6 pt deep well socket
4707L 7/32" 6 pt deep well socket
4708L 1/4" 6 pt deep well socket
4709L 9/32" 6 pt deep well socket
4710L 5/16" 6 pt deep well socket
4711L 11/32" 6 pt deep well socket
4712L 3/8" 6 pt deep well socket
4714L 7/16" 6 pt deep well socket
4716L 1/2" 6 pt deep well socket
4718L 9/16" 6 pt deep well socket
4760 2 inch Extension
4761 6 inch Extension
4770 Universal Joint
4749 Oval Head Ratchet
4769 6 inch Spinner Handle w/Bolster
Steel Box w/Plastic Insert
* The 4704 (1/8" 6 pt) and 4705 (5/32" 6 pt) are both add-ons to the set.
* The 4708S (1/4" 8 pt), 4710S (5/16" 8 pt), and 4712S (3/8" 8 pt) are add-ons to the set.
* The tools are all NOS except the 4764 Spinner, which is used.
F
PROTO 17 piece 1/4" drive METRIC Socket Wrench Set w/Steel Box
this set includes:
4704M 4mm 6 pt shallow socket
4705M 5mm 6 pt shallow socket
4705.5M 5.5mm 6 pt shallow socket
4706M 6mm 6 pt shallow socket
4707M 7mm 6 pt shallow socket
4708M 8mm 6 pt shallow socket
4709M 9mm 6 pt shallow socket
4710M 10mm 6 pt shallow socket
4711M 11mm 6 pt shallow socket
4712M 12mm 6 pt shallow socket
4713M 13mm 6 pt shallow socket
4714M 14mm 6 pt shallow socket
4749 Oval-Head Ratchet
4749XLQR Teardrop 45-tooth Quick-Release Ratchet
4764 6 inch Flexible Spinner Handle
4765 6 inch Flexible Extension
Steel Box
Steel Rail for Sockets w/Clips
* You will not find this set in any catalogs.
* The tools are all NOS.
* The BOX is used.
F
Fleet 13 piece 1/4" drive SAE Socket Wrench Set w/Original Box
Manufactured by Fleet Tool Corp., Schiller Park, Illinois U.S.A.
this set includes:
1007 7/32" 6 pt shallow socket
1008 1/4" 6 pt shallow socket
1009 9/32" 6 pt shallow socket
1010 5/16" 6 pt shallow socket
1011 11/32" 6 pt shallow socket
1012 3/8" 6 pt shallow socket
1014 7/16" 6 pt shallow socket
1016 1/2" 12 pt shallow socket
1008S 1/4" 8 pt shallow socket
1010S 5/16" 8 pt shallow socket
1012S 3/8" 8 pt shallow socket
1060-1 RHFT Ratchet
1065 3 inch Extension
F
Penens 17 piece 1/4" drive SAE Socket Wrench Set w/Original Box
manufactured by Penens Corp, Schiller Park, Illinois U.S.A.
this set includes:
1006 3/16" 6 pt shallow socket
1008 1/4" 6 pt shallow socket (* two each *)
1009 9/32" 6 pt shallow socket1010 5/16" 6 pt shallow socket
1066 6 inch Extension
1070 6 inch Flex Handle (Breaker Bar) (* two each *)(* one has loose drive anvil *)
1060 RHFT Ratchet
Steel Box (* box is heavily oxidized *)
PowderKeg
Little Rock, AR
So I finally have another 1/4" set to add - scored at the annual Threshermens Show in Pinckneyville IL yesterday (missed it 3 times earlier going by the vendor). An International Forge set with ratchet, Provincial posted one @ 6 years ago with fewer sockets and no ratchet, but a driver handle in far better shape than my chewed-up one. The sockets are marked with I.F.C and the size only.. Ratchet says USA (had to be MDF sourced) but nothing else marked that way. Already have a ratchet in the obsess.... er, "collection" but couldn't resist since I've never seen anything else in person. Can't complain for $20.
F
^ I have almost two complete sets of International Forge 1/4", one of which includes a copper-plated ratchet, just in case you're interested. They're in a box of 1/4" mish-mash I haven't gotten to yet.
Not sure if I have a spinner. The ratchets are carbon-copies of the same era MDF Craftsmans, other than the brand name forged into them.
International forge and metcoid offered some moore drop forge stuff
F
^ I don't have any Metcoid but... that International Forge ratchet (made by MDF) is a dead ringer for the older RP Craftsman models.
Pretty sure I have two ratchets... one plain steel, one copper, and one complete set and one almost complete set. I should dig them out - I finally got through that box of Proto stuff (except for three empty socket boxes.)
F
Truecraft 32 piece 1/4" drive SAE Socket Wrench & Bit Set w/Original Box
manufactured by Truecraft Tool Co., Chicago, Illinois U.S.A.
this set includes:
21206 3/16" 12 pt shallow socket
21207 7/32" 12 pt shallow socket
21208 1/4" 12 pt shallow socket
21209 9/32" 12 pt shallow socket
21210 5/16" 12 pt shallow socket
21211 11/32" 12 pt shallow socket
21212 3/8" 12 pt shallow socket
21214 7/16" 12 pt shallow socket
21216 1/2" 12 pt shallow socket
1/4" hex X 1/4" square Drive Adapter
T10 Tamper-Resistant TORX Bit
T15 Tamper-Resistant TORX Bit
T20 Tamper-Resistant TORX Bit
T25 Tamper-Resistant TORX Bit
T27 Tamper-Resistant TORX Bit
T30 Tamper-Resistant TORX Bit
T40 Tamper-Resistant TORX Bit
PH1 #1 Phillips Bit
PH2 #2 Phillips Bit
PH3 #3 Phillips Bit
5/32" Slotted Screwdriver Bit
3/16" Slotted Screwdriver Bit
1/4" Slotted Screwdriver Bit
1/8" Hex Bit
5/64" Hex Bit
3/32" Hex Bit
1/8" Hex Bit
5/32" Hex Bit
3/16" Hex Bit
7/32" Hex Bit
1/4" Hex Bit
6739 Reversible Ratcheting Driver Handle
Plastic Blow-Mold Box
* As opposed to a screw-in cap that gets lost, the end cap on the driver is tethered to the handle, which is hollow at the end, allowing the user to store a few bits in the handle.
* These were manufactured in the U.S.A. prior to Daido Corporation's acquisition of Truecraft.
Truecraft Tool Co., 2425 South Michigan Ave., Chicago, IL / formerly Otto Kaufman Co., acquired by Daido Corp., Japan / http://alloy-artifacts.org/other-makers-p6.html#truecraft-tool / https://www.garagejournal.com/forum/threads/truecraft-tools-memories-of-first-tools.255703/ / https://ameblo.jp/corgibell/entry-12601727921.html /
F
^ I have a Craftsman 1/4" drive metric set like that. Actually very handy to use.
PowderKeg
Little Rock, AR
I've got a triple play of Metcoid ratchets and 2 out of 3 IFC - need a 1/2" if it exists - but until this IFC set I've never seen anything else socket or drive tool-wise. If you get to digging out those IFC sets I'd be curious what sockets are there. A couple of mine are doubles and there's still room in the box for more. Interestingly several are 12pt, which isn't overly common for 1/4".
F
Jensen 10 piece 1/4" drive SAE Socket Wrench Set
includes 6 point sockets: 3/16", 7/32", 1/4", 9/32", 5/16", 11/32", 3/8", 7/16", and 1/2" and 6-inch spinner handle
the tools are NOS. the box is a repurposed "Powr-Kraft"
Jensen / Jensen Tools & Supply, Inc., 100 Ames Pond Drive, Suite 202, Tewksbury, MA 01876 (formerly 4117 No. 44th, Phoenix, AZ 85018 - 1977) / http://www.jensentools.com/ / primarily a repackager of outsourced private brand tools (sockets and wrenches outsourced from Proamerica/KAL) /
* note the two = marks on each side of the size stamping and lack of any manufacturer's name or part number on the sockets.
Compare with:
KAL 1/4" drive SAE socket set
Proamerica 1/4" drive SAE socket set
F
Bethlehem "Quickway" 9 piece SAE Socket Wrench Set "A" in Original Box
manufactured by Bethlehem Spark Plug Co., Bethlehem, Pennsylvania U.S.A.
this set includes:
9/32" 6 point socket
5/16" 6 point socket
11/32" 6 point socket
3/8" 6 point socket
7/16" 6 point socket
15/32" 6 point socket
1/2" 6 point socket
3/8" Hex "T" Handle
5/32" x 4" cross bar (with no detents)
Steel Box
Bethlehem "Quickway" thread at GarageJournal.com
F
EASCO 91-150 8 piece 1/4" drive METRIC Socket Wrench Set w/Holder
manufactured by EASCO Hand Tools, Hunt Valley, Maryland, U.S.A.
this set includes:
516104 4 mm 6 pt shallow socket
516105 5 mm 6 pt shallow socket
516106 6 mm 6 pt shallow socket
516107 7 mm 6 pt shallow socket
516108 8 mm 6 pt shallow socket
516109 9 mm 6 pt shallow socket
516110 10 mm 6 pt shallow socket
516111 11 mm 6 pt shallow socket
-- Steel Holder
EASCO hand tools thread at GarageJournal.com
F
G.M. Mfg. Co. 7 piece 1/4" Hex Drive SAE Socket Wrench Set w/Holder
manufactured by G.M. Mfg. Co., Long Island City, New York, U.S.A.
this set includes:
1/4" 6 pt 1/4" hex drive shallow socket (2 each)
1/4" "Radio" socket (for knurled nuts and knobs)
5/16" 6 pt 1/4" hex drive shallow socket
11/32" 6 pt 1/4" hex drive shallow socket
3/8" 6 pt 1/4" hex drive shallow socket
7/16" 6 pt 1/4" hex drive shallow socket
"Ell" handle
-- Steel Holder
G.M. Mfg. Co. tool thread at GarageJournal.com
F
