My Small But Growing 1/4" drive Socket Set Collection
Tom "Python" Aycock
RE: "skinny box"
I recently sold a Thorsen set to @Tom "Python" Aycock that seemed to be in an awfully narrow box - not like any other "Thorsen" box I'd ever seen.
Tom is you see this post, can you measure that box?
I got a Husky, New Britain and a Giller set from ya. I Don't see a Thorsen set I bought from ya. The one Thorsen set I bought from ya back on 7APR was in a KAL box.
Of the active Thorsen sets I'm trying to fill in the 1/4 drive size, I have:
#1416 and #1416S circa 1961 16pc set that measures 6 7/8" in width, just shy of 3" deep and 1 1/4" tall
#1411 circa 1980 11pc set that measures 7 1/16" in width, 3 5/32" deep and 1 9/32" tall
I also have a military issue circa 1985 1/4" drive set but it's a pretty standard size box
RE: "skinny box"
Tom "Python" Aycock
Hey guys. Found this double female 1/4" drive at a flea market the other day. I know Stevens Walden has a 3/8" and 1/2" double female included in their PM32 set. Curious if anybody else had knowledge of this one and possibly the manufacturer and/ or the kit it belonged with. The SW ones appear to be fully knurled while this one only has an area of knurling. It has a good heavy feel to it so I'd like to think USA Made1000026167.jpg1000026166.jpg1000026165.jpg1000026164.jpg1000026162.jpg
If there are no markings on the socket, that’s going to be a tough one. 4 point sockets of many sizes were once popular for use on pipe plugs although 8 point sockets gradually gained in popularity over time. There were some distributor wrenches that came with sockets that resemble the Walden examples as well.
Some 4 point sockets.
Tom "Python" Aycock
Lack of markings is the bane of my existence for sure!
Any ideas on this 1/4" drive socket? 6 unequal sided.
USA Pat. 4644831 ROC Pat. 27181 N
F
@Tom "Python" Aycock -
Your 1/4" drive 1/4" square socket might well be an early refrigeration socket. I know they were made in both 3/16" and 7/32", but off the top of my head I don't recall a 1/4" size.
I have a Walden PM21 set that uses that goofy female-to-female "connector", as well as one of their 1/2" drive sets that uses the same kind of set-up - using extensions with male ends at both ends - but I've not seen a 1/4" drive set like that. :headscrat
outofbounds
Recent find for me is this “21 piece” Williams 1/4 Drive x Tall Socket set. 21 pc thanks to Added bonus of 8 standard 1/4 Drive sockets stuffed into the well in the lower right hand corner. I don’t reckon they were part of the original set. The flimsy plastic insert smacks of late 70s early 80s timeframe.
F
"Mark I" 16-piece 1/4" drive SAE Socket Wrench Set
this set includes:
3/16" 6-pt socket
7/32" "
1/4" "
9/32" "
5/16" "
11/32" "
3/8" "
7/16" "
1/2" "
1/4" 8-pt socket
5/16" "
Pear-Head Ratchet
5-inch flex handle (breaker bar)
6-inch extension
2-inch extension
Steel Box
* all pieces are stamped "Japan"
* none of the pieces are marked with part numbers
* the ratchet appears to be a knock-off of the Walden model 3150. I count 22 clicks
F
Pexto No. 1 Radio Socket Wrench Set 061924 01.jpgPexto No. 1 Radio Socket Wrench Set 061924 02.jpg
manufactured for Peck Stow, and Wilcox, Southington, Connnecticut U.S.A.
this set includes:
5/16" 6-point Socket (* socket is split *)
11/32" 6-point Socket
3/8" 6-point Socket
5/16" Knurled Radio Socket
1/4" Hex Drive Handle
I was not able to find a No. 1 Radio set in any catalog, but did find a similar type set in a 1927 Supplee-Biddle Hardware catalog
  • 1927 Supplee-Biddle Hardware Co. catalog Pexto Radio Socket Set ad pp 249.JPG
F
Bridgeport 485 "Radio-Lectric" Socket Wrench Set
manufactured by the Bridgeport Hardware Mfg. Corp, Bridgeport, Connecticut U.S.A.
this set includes:
1/4" Knurled Radio Socket
3/8" 6-point Socket
7/16" 6-point Socket
1/2" 6-point Socket
1/4" Hex Drive Driver Handle
- cardboard box
* none of the sockets are marked with part numbers or manufacturers name or logo
* the driver handle is marked with "Radio-Lectric" and the "BHM" trademarked logo on the ferrule.
* this set uses a unique "interference fit" arrangement - there is no detent ball employed here.
* the box has been repaired to keep it intact.
bmwrd0
Beaver Fever Oregon
Is that 1/4", or 9/32" on the drive end? If the later, it might be an early Snap-on.
F
^ If it is indeed 1/4" square at both ends, I would be more inclined to think that it came in a refrigeration socket set - I've never seen any 1/4" Walden "connectors" like that goofy set-up in the PM-21 kit with the double-male-end extensions.
That socket doesn’t look Walden-like to me. Walden did make 1/4” drive 1/4” four point sockets. I have one in my Walden 1/4” drive oddball set. IMG_2558.png
F
Herbrand 01213 14 piece 1/4" drive SAE Socket Wrench Set w/Original Box
manufactured by the Herbrand Co., Orangeburg, South Carolina U.S.A. ("Triangle Era")
this set includes:
20606 3/16" 6-pt socket
20607 7/32" "
20608 1/4" "
20609 9/32" "
20610 5/16" "
20611 11/32" "
20612 3/8" "
20614 7/16" "
20616 1/2" "
22000 1/4" drive RHFT Ratchet
21001 2 inch Extension
20116 6 inch Extension
----- 6 inch Spinner Handle
* all of the pieces in the set except the spinner handle are marked with part number and "HERBRAND" and the Triangle logo.
* the spinner handle is not original to the set and is marked "U.S.A." and "HERBRAND" but lacks a part number.
F
Herbrand MA7-1 8 piece 1/4" drive Bit and Ratchet Set w/Original Box
manufactured by the Herbrand Co., Orangeburg, South Carolina (?)
this set includes:
M19-FS Flexible 1/4" Driver Handle
M2S 1/4" drive Fingertip Ratchet
M03M-1 1/4" square female x 1/4" hex Drive Adapter
T10 x T15 two-way Torx Bit
T20 x T25 two-way Torx Bit
3mm x 4mm slotted Screwdriver Bit
P1 x P2 phillips Screwdriver Bit
Steel Box w/plastic insert
* the flex driver handle swings 180° - the catch is released by applying thumb pressure to the lever on the shaft
F
Wright 18 piece 1/4" drive SAE Socket Wrench Set w/Steel Box
manufactured by Wright Tool Co., Barberton, Ohio U.S.A.
this set includes:
2006 3/16" 6-pt Socket
2007 7/32" "
2008 1/4" "
2009 9/32" "
2010 5/16" "
2011 11/32" "
2012 3/8" "
2014 7/16" "
2016 1/2" "
2308 1/4 10-pt Socket
2310 5/16" 10-pt Socket
2312 3/8" 10-pt Socket
2402 2 inch Extension
2406 6 inch Extension
2441 6 inch Spinner Handle
2436 6 inch Flex Handle (Breaker Bar)
2400 RHFT Ratchet
Steel Box
* the box is not original to this set *
This WW2 vintage Walden FSN marked box arrived at the Post Office yesterday. It had a mixed batch of tools inside. Some were the expected Walden sockets with a flex handle missing the retaining ball. There were some D-I sockets along with a Duro-Chrome flex handle with the two male ends. There was a wartime unmarked S-K flex handle that unfortunately had a stuck retaining ball that showed no signs of freeing up. The other sockets and extension were disposable checkout counter ****.
Duro/ D-I toolsIMG_3344.jpeg
LesserSon
PA USA
I picked this up at Jake’s Flea this morning, hoping it would be Bonney inside. Unmarked cad-plated S-K instead. But I do not recognize the mostly-gone label on the underside of the lid.
DID S-K do a crackle red in the ‘40s-50”s?
Does anyone recognize the logo from what’s left of the label?
Smokeshow69
The logo looks Blackhawk but I’m not sure if they did wrinkle finish ?
F
@LesserSon - "Carb-O-Mang" made during the 1940s. Slightly on the rare side. :thumbup:
