KwikFab
Central Valley, CA
Received a package yesterday afternoon from a repeat customer.
Made sense to purchase it and have it sent to me before I made something for it and send it all out to him (he's in Alaska).
He wanted a molle panel for the rear center console cover as one person used to make them some years back; he has since shut down his website and disappeared so I got to mocking it up today.
Here's the panel -
The kit was advertised as being a means of carrying a first aid kit, specifically the tear-away Orca Tactical pack found on Amazon so I found it appropriate to buy one myself for mock reasons -
Quick cardboard mock up -
The design is super simple so it took a minute or two to draw up and get to cutting -
Here it is after it was cut, and bent on the press brake -
Perfect -
Here's the tear away action; the rear of the kit is secured nice and tight to the molle panel -
Not bad for a quick first attempt -
Have to say, I've used molle both in the military and in training and I remember just how secure the stuff is on your carrier and whatnot.
However, this was the first time cutting a template on steel.
Looking at how the rear looped through the panel, I may want to adjust the holes and spacing for the molle panel but that may take longer than it did making this whole thing.
Might have to toy with it tonight on CAD.
Had very little 16 gauge left so made two more.
Apparently, more people want them so onto cutting.
Two quick bends on each one.
And since it's early and I'm relaxing the rest of the day, figured I'd throw a coat of primer on them.
rcktpwrd
Raleigh, NC
While I was at work, she reinstalled the interior of the wagon. While it was all apart, she did a very thorough cleaning of everything, it looks good! Still waiting on one sun visor to be refinished, when she went to pick the stuff up the other day there was a small issue with one visor and the guy tore the fabric when trying to fix whatever the problem was...
I got out the D/A again and went over all the glass with Mothers water spot remover and a Griots glass polishing pad. Glass is better but really needs more polishing to get rid of more of the water spots and whatnot. I also think I need to get new product as what I have is 6-8 years old.
Magnum440d100
Indiana
That jungle website made a delivery today.
So now I’m moving my taps and matching bits from my packouts to the drawers. Just bummed because I use/used to use 12-24 at work, and there’s no spot for it. But there is one “extra” slot it seems. Maybe that’ll be a catch all for the random ones.
Can’t wait to get the rest of the drawers. Gotta talk myself into the justification lmao
DGersic
DeKalb, IL
Final mockup / acceptance test for the drawer on Blum tandem slides. We’re good to go. I’ll start on the real,drawers this week.
Oil change on the Camry.
Belt sander applied to the bits that go in the track, so they fit now. Messed with getting the new featherboards on the saw.
Jgaz
Your “mock up” drawer looks great!
Did I read somewhere that you are looking for melamine coated bottoms for your drawers?
I used an MDF based material that had a whiteboard layer on one side and a blackboard? material on the other.
It is used in a 22”x 15” drawer I made for my wife’s cutting table.
You can see it here where I removed on of the organization trays she has in the drawer.
I liked the material and I was able to buy a 24”x24” so not much left over
I used 1/2” Baltic birch with 1/4” finger joints for the drawer construction.
I didn’t worry about glueing in the drawer bottom.
The bottom was cut as a snug fit to help square up the drawer and I really just relied on the finger joint glue squeeze out to hold it snug so it doesn’t rattle.
DGersic
DeKalb, IL
Thanks. I was, but we’re back to normal plywood now.
bulletpruf
San Antonio
Picked up this vise from my neighbor a few years ago; didn't have a need for it at the time, but I can't pass up a deal on a decent vise.
And now that I'm setting up a shop, a lot of my tools have migrated there, so now I need a vise for my chainsaw workstation/workbench.
Figured there was a decent vise under the 4 or 5 coats of paint, and I was right.
Decided to leave it au naturale, but with a coat of boiled linseed oil.
After this was done, I got started on a resto of a rusty and beat to hell Rock Island 94; hope to finish that up tomorrow.
Motorman55
South Jersey
UPDATE.....The black felt came in the mail so yesterday I applied it to the three plaques. Only thing left now is to add the metal engraving plates once I get them.
Meanwhile, I made another motorcycle trophy for our Car Show. The cast metal motorcycle topper and eagle are vintage metal pieces.
I stained the bottom plate the same 'Classic Black' as the three plaques and clear polyeurthane the base. I used my miter saw to make the horizontal slat cuts to the vertical piece to represent motorcycle cylinder fins and trimmed the top with a couple angle cuts to represent a motors head.
I used one of the cut off pieces to make the eagle perch which I also stained with the 'Classic Black' then glued it to the vertial piece. I left the vertical piece natural pine and just polished it and the perch with the Howard's Feed-n-Wax. Lastly I added the black felt to the bottom. Just have to add a brass engraving plate.
Still a few more trophies to make....1723693572035.jpeg1723693542993.jpeg1723693511113.jpeg
Another day another Car Show Trophy completed. This one is for the Rat Rod or Rat Bike Catagory. Its called 'Rats Rule'
Grabbing some wide wood popsicle sticks, I fashioned a background picket fence and a separate pine board sign with the name of the Trophy catagory on it. Glued the fence into a slit cut I made into the top back of the plaque and wiped some Howard's Feed-n-Wax on it. Next I stained and clear polyurethane the pine oval base plate. After it dried, I took one of the Car Show ribbons, trimmed it to size and slipped it up between the sign and the picket fence. Drilled some small holes thru the sign board and fence and attached the sign with small nails and super glue securing the ribbon at the same time.
Grabbed one of the rubber Holloween rats and leaving his body unpainted, I painted his eyes red and trimmed off a couple of his whiskers and shortened his overly long tail. Drilled a couple holes thru his feet and tail and into the wood base to mount with nails. Also painted a small plastic Party Favor trophy and super glue it to the rats body. Lastly I added some black felt to the bottom of the plaque.
And that ends the tail, pun intended, of the 'Rats Rule' Trophy. On to the next one......1723955336931.jpeg1723955273882.jpeg
Daedalus
Mama's car got some lovin' today. Bled all 4 calipers to replace the brake fluid, and drained/refilled the trans with Nissan Matic S. The brake fluid wasn't terrible, but the trans fluid was far too overdue. Shame on me. Coolant is ordered and on the slow boat. It was a bit muggy today, but not too hot, thankfully.
bugnut
Central Ohio
Finished the cleaning and reassembly of the Ford 8n carb. Not sure the issue, everything looked okay, but had to run with the choke on and it was surging and without power. Looks like a leak on the gasket at the choke side? Maybe?
bulletpruf
San Antonio
Normally if you have to run it with the choke on, I'd say you have a vacuum leak somewhere, but there aren't many places to for a leak on one of these. If it still surges once it's back together, start it up and then spray some brake cleaner around the intake and base of the carb; when the engine picks up rpm, you've found your leak.
DeeDubz
Socal
Ball joints, track bar and tie rods... fun stuff. Thankful to have the proper tools to get it done
Snip's
My Whitney Jensen was showing some wear and tear and looking a little grungy... Gave it a little Spa treatment...
This is the #5 JR hole punch... Still in production for over 100 years... It must be a good design because the knock offs are being cranked out by "other" countries... Mine is an earlier model but is now being sold by Roper Whitney and thankfully still being manufactured in Rockford Illinois, USA :giggle: With only hand power, it can apply 2,400 pounds of hole popping force (without burrs that a drill bit would give)...
I cleaned it up yesterday in a bath of Simple Green and hit it with a splash of Rust-Oleum hammered silver....It was a little tricky because some of the parts are riveted in place... The two screws I cleaned up this morning and applied some nickel plating to resist rust...
Before:
Now:
Nickel goodness...
Bessy
Ontario, Canada
Phone was dead, so no photos to speak of, but I finally pulled out the spindle sander and placed it on the back of the overturned whaler taking up residence in my shop, so that I could finesse (widen) the slots in my pipe clamp racks to accept the clamps I've got. Once that was done I glued up five of the six pieces of the rack. I'll finish that tomorrow after work, I think, so I can get it hung up on the wall, and populated. Many of my longer clamps are taking up residence on the outboard motor stand/cart while the OB is on the boat for the summer, but I will need that unit back come the end of September, so I need to get a move on mounting clamps up on the walls.
LeeG
Phoenix, AZ
I use an app on my phone to keep track of all my stuff. Today was too hot to do anything useful, so I went through my “in the truck bed “ toolbox, removed some unnecessary duplicates, and made sure I knew what was in there.
I know that this level of detail is more than most want to do, and it took a long time to get it all done, but I’m glad I did it.
Lee
Snip's
For rust removal on iron / steel / cast iron parts, I use white vinegar (5% acidity)... Pretty cheap at the grocery store...
But before the items go into the vinegar, I remove any oily surface contamination with SG... The SG lets the vinegar get to work better....
I flush the parts with cold water and quickly dry the item... Some small amount of flash surface rust may form...
Then add your desired finish (paint, BLO, wax, oil etc.)
niget2002
Josephine, TX
Processed the first good pediment, as much as I intend to.
Started printing more lost PLA masters.
I need to try some lost PLA casting for some aluminum parts.
Today I finished up the construction on the Kayak. I glued on some more fiberglass layers on the bow and stern for abrasion resistance and cleaned up the underside of the coping lip.
When this epoxy dries, I'll start sanding everything down in prep for finishing. My plan at this point is to use some Automotive 2k clear. I've epoxied a test piece to test out the clear I already have. I need to check and see how much clear I have from a previous project. I think I have at least half a quart. Should be enough for 4-5 coats of clear on the kayak.
