Blast cabinet dust collector
RMR&C
NW Montana
I'm trying to find out what would be the best dust collector for my blast cabinet. I use the cabinet to remove rust from car parts, so I have to use a pretty aggressive media. Currently I am using crushed garnet. Problem is, it's pretty dusty and I have just killed my 2nd shopvac. Is there a collector made specifically for media blasters? Will the woodworking type work or will the abrasive just tear them up? What do you guys use? Any help is appreciated:)
Keyblazer
Irvine, CA
I have a smallish HF blast Cabinet, and I use a shop vac...
The trick is to use the bags for Drywall inside the shopvac... They are designed to filter and retain smaller fine particles and keep them out of the motor.
They are cheap enough to replace every few months or, to pull them out when you wanna use the vac for other stuff..
Like this:
http://www.shopvac.com/shopvac-acce...lter-Bags-for-25-Gallon-Tanks__919-46-00.aspx
ghnl
Mebane, NC
I use a shop vac with a 'Dust Deputy' cyclone seperator. It works well - >90% of the dust stays on the seperator, the shop vac's filter stays clean and thus suction doesn't drop off.
e-tek
Saskatoon, SK
The water system is a real "cats-***" set up, but a vaccuum with the tank bag works just as well I find.
R
RMR&C
NW Montana
Thanks for the input........I was using the "water filtration" method right before my last vac died, seemed to work real well. Will likely go back to it....I was just wondering what else was available.
Stephenw, can you explain how your setup works?
Stephenw
Utah
pgreen
Venus, TX
After killing a couple shop vacs, and practically going deaf listening to them, I invested in one of these:
http://www.sandblasting.com/sandblast-dust-collectors.html
Econoline is the brand I got. Their factory is in Grand Haven, Michigan, just 20 minutes from my place. They ship, and I believe they also sell through Grainger and other places. If you use your blast cabinet much, it is well worth it. I also added one of their lights to my cabinet. Now when I turn on the cabinet light, the dust collector kicks on automatically.
No connection, just a happy customer!
mdbeck1
Norman, OK
I didn't see a price on their web site. Would you mind telling us a rough price of what you paid/retail?
daveroy
Omaha NE
Did you check my link? I have a drawing and operational description on my site.
http://www.shopngarage.com/forum/index.php?topic=196.0
StephenW,
Just a design question.. Other than looks/balance issues is there any reason to have the dust tube run inside the collection tube on your design? Are there some cooling issues or something like that that I am not aware of? would two 'ports' right at the top of the bucket (with tubes into the water inside the bucket) work just as well.
I ask because I wanted to place mine under the cabinet. Using a 5Gal bucket should give plenty of room for two ports and still keep it short enough (I think). But I didn't know if the 'tower' served some alternate purpose.
Dave
zmotorsports
Northern Utah
This is similar to the one I use. Although not an Econoline it looks pretty close to this. I bought mine with my cabinet as an accessory because I had heard that the shop-vac don't last and are louder. Mine is over fifteen years old now and other than having to clean it three to four times a year is has not given me a second of grief. I use the crushed glass beads in mine. Mike.
Stephenw
Utah
StephenW,
Dave
I just wanted to build it really complicated. :bounce:
Here is a simplified design by Goodfellow...
Goodfellow's Design
PCO6
Newmarket, Ontario
Goodfellow's Design
It's a liitle hard to tell from the photo below but mine is like the Goodfellows design. I shoot with my right hand and the media exhausts through port in the floor on the left side. It works great and is easy to maintain.
tcianci
Walpole, Ma
I made an enclosure for a HEPA filter out of a 2 gallon plastic paint bucket with a snap on lid. I put a fitting through the side of the bucket and that fitting attaches to the outlet on the blast cabinet. I put another fitting through the bottom of the bucket(therefore on the inside of the filter) and that fitting attaches to a cheap shop vac. Same vac for quite a few years now and when I empty out the filter bucket, I dump the collected dust and abrasive into my pressure blaster for one last go-round before its junk.
spongerich
Monroe, NY
I built one similar to Stephenw's I opted to skip the pipe in a pipe design and ran 2. The intake comes down to about 3" above the bottom of the can and has some slots cut in it to minimize bubbling. The hookup to the shop vac runs about 3" through the lid. Works great. I already had a tall 10 gallon plastic can, so the whole thing cost about $20 in PVC pipe and fittings.
I was using the filter bags in my vac, but at $5 each, it gets costly.
Shadowdog500
Down the shore
My blast cabnet has a little squirl cage built in. I put a sock over the discharge and dump the media from the sock back into the cabinet every now and then. I dont use it every day and it works good enough for me.
Chris
farmerbob
I'm new to this forum having done an internet search on a blast cabinet dust solution. I used Goodfellow's original design and it is the "cat's meow". Was unable to obtain a list of parts from the provided link (forum appears to have been taken down). But since you gents were kind enough to provide this dust entrapment design, i'd like to share my parts list. I'm using a small 2gal craftsman wet/dry vac with the smaller diameter vac hose. both hoses slip fit to the threaded side of the couplers on my parts list without modification.
NIPCO 1 1/4 " PVC - parts purchased for around 8-9 bucks.
1 4ft section PVC (two pieces cut at 2 1/4 inches to pair fittings above and below lid, one cut at 12 inches to reach water level)
1 90degree elbow (glue type) - used below lid
1 coupler (glue type) - used below lid
2 couplers (one side glue, the other male thread) - both used above lid with threads up
used a 5 gallon bucket that I get my pool HTC in. These are heavy duty with screw-on lids so if you have a friend that has a pool, ask them if they have one handy.
Again, thanks for the valuable information.
Stephenw
Utah
Welcome to the forum. I updated the links.
isaac338
Halifax, NS, Canada
I like your cab, PCO6.. what are the dimensions?
(sorry for the hijack)
JimmyM
North Madison Ohio
www.tptools.com for all your blast cabinet needs,,
I have the vac34 on my home built cabinet, works very well and is similar to the econoline mentioned above,
isaac338 check out tp tools web site they have the plans to build a cabinet out of 2 sheets of 3/4" plywood thats what I have
JimmyM
North Madison Ohio
by the way,, has anyone used the dust collector from Harbor Freight for a blast cabinet? it looks as though it could work quite well
PCO6
Newmarket, Ontario
The cabinet is 40" wide, 28" high and 28" deep. It's made of galvanized sheet metal from an HVAC supplier. I can't recall the guage but I would guess it's about 20g. The stand is 32" high. It's about 35 years old and I've put it through a lot of use. I initially set it up for a syphon feed blaster but switched to a pressure blaster (big improvement). :thumbup:
It loads through the front and the arm holes are in the door. I used to use a combination of rubber gloves and car tire inner tubes for my arms but that was less than ideal. I cut down the tubes and now just wear long rubber gloves that are the full length of my arms. They seal well when I put my arms through. It I can also pass small parts through the door without even opening it. I have the door glass cut for me at an auto glass shop. As mentioned, I use a simple vacume / water pail system and there is virtually no dust while I am blasting
Here are a few more pictures of it ...
Stuey
28m above sea level
Sorry about that - didn't know the forum was closed. The broken links have since been removed.
Thanks for the parts list - great 1st post!
mad57
Goodfellow's Design
is a good idea...its been used for awhile as a dry wall dust less sanding tool,it has saved me for yrs in a custys home.
bchee
Texas
that ***** to hear about shopngarages
stephen and goodfellow have some awesome ideas
Arkansas
Hello,
I realize this is an old post, but I have a question that relates to this topic.
If I decide to invest in a certain dust collector preferably in blasting applications, are there things I should look out for when buying?
I know any dust collector isn't cheap.
-Kaitlyn
astroracer
Mid_Michigan
I built this cheap dust collector out of two kitty litter buckets and a shop vac filter. The motor is from Harbor Freight. I have about 130 dollars into it.... It works very well, I will use it without even thinking about it in the closed up shop during the winter...
Just saying, you don't have to spend big bucks. :)
A shop vac hose runs from the cabinet to the upper box.
I empty this out about twice a year, knock the dust off the filter and go back to work.
The really nice thing is, it all fits in the blast cabinet when it's not in use.
Mark
Arkansas
Looks pretty good. I have noticed there are a lot of people that DIY collectors instead of purchasing one. I also find it awesome that you used kitty litter buckets. Anything to keep the dust out right? lol
-Kaitlyn
brownsmustang
SWMO
Keep an eye out on the facebook market place. I found a Delta 50-721 dust collector for 125$. I use it for my blast cab and my pc booth.
NUTTSGT
Northern Central Ohio
-Kaitlyn
Got to keep the dust out. I have the vent/output of my shopvac vented outside through the roof like a DWV.
clubairth
That's a great question and hope anybody that has run either one of those units will report back?
I went with the original dust deputy at around $100 with the bucket. Now you can certainly use your own 5 gallon bucket and save a few bucks too.
I will say that is a wonderful modification to my box. Really keeps my vacuum clean and I have the proper blast cabinet type vacuum NOT a shop vac with a water bong on it.
Over the years I have had to replace the vacuum motor twice at around $100. I hope and plan that I will never need to replace another motor but we will see.
Note that the final exhaust into that blue bag was a complete failure and I DON'T recommend anybody doing this!! Covered my shop in very fine dust.
I am sure you are breathing all that fine dust too.
I just removed the blue bag and plumbed the final out put thru a wall and out of my shop.
