fishwatcher
- Joined
- Jan 26, 2023
- Messages
- 758
I just picked up a used pair of Park Tools I beam style torque wrenches. I already have a small Lezyne tool that goes up to 10nm. And a click style torque wrench from Amazon that I think goes up to 20-ish nm.
I compared the three 1/4” bit/socket torque wrenches.
The Lezyne is the most conservative. After I set a bolt at 5nm with it, the 1/4” bit Park Tools I beam torque wrench will turn some more, almost a full nm to reach 5nm. Then I take the click style torque ratchet wrench and it turns more again for almost another half or up to one more nm before it clicks.
This range of difference is about the same at 7 or 10nm targets.
How acceptable is this range of error? I’m assuming the park tools I beam style is the most accurate. It measures right in between the other two.
Am I testing wrong? Are these results expected given the different styles I have?
I didn’t try the big torque wrench. I tried the 3/8” Park Tools and 10nm mark is so small, it’s not going to be in the best range to use for small nm specs.
Thanks.
Thanks.
