MaxJax Installation Tips - WORTH READING
JSK
Southern CA
After the MaxJax was assigned to Dannmar, I have not been as much involved. But I have installed a few of these so I'll be glad to share my own experience. My original cart design was a fully assembled welded unit so not too familiar with the revised unassembled design which was implemented in order to make a more compact shipping bundle for retail stores.
First, I am a firm believer of epoxy. On most of the MaxJax lifts I have installed, I filled the 7/8” hole with two-part anchor epoxy then installed as per the instructions. It can get messy, but in my years of installing lifts, it has always proved beneficial. To me, it just adds an extra level of assurance. However, if installed properly, and when lifting max 6,000 pounds, (which in the two-post world is very minor), and with shorter than usual lifting arms, the floor loading from a MaxJax is a lot less than typical two-posts. So, the PD58 anchors minus the epoxy are more than capable when installed as per instruction. You can find answers to all of your uneasy concerns here.
If you do choose to use epoxy, make sure you clean the dust out of the holes good prior. Fill the hole about two-thirds or too much epoxy will ooze out of the hole once the anchor is tapped in. This creates a mess which needs to be cleaned up quickly before the epoxy hardens. Make sure to put grease inside the anchor in the event epoxy finds its way onto the threads. The grease prevents the epoxy from polluting the threads and it also helps when remove the sacrificial “pounding in and setting bolt” after the anchors are installed.
The most important thing to focus on is locating and drilling the holes exactly where they need to be. If when drilling, the bit initially walks to the left slightly on some of the holes, then walks to the right on others, the accumulated spacing may be just enough to make the bolts not fit clear through the base plate of the lift once installation is complete. Take your time. Drill pilot holes first only after double checking. Do your best to make sure the pilot drill stays exactly on your mark. And when drawing your marks, be very careful to locate the exact pinpoint center of the base plate holes.
NOTE: The instructions say to drill the first hole, position the column in place, install an anchor, secure the column, then mark the second hole using the base plate as a guide. Drill second hole, position the column in place, install an anchor, secure the column, then mark the third hole using the base plate as a guide - repeat steps etc. Although this seems like a redundant process, it is a cautious way to insure the holes are exactly where they need to be. If however you opt to drill first, install later, be sure to get your marks dead nuts.
The second most important thing to remember is drill bit - 7/8” is 7/8”. Don’t use a close enough metric bit or, just as bad, an under size or worn bit. Worn drill bits will make your install a nightmare. If you find yourself using a sledge hammer to pound in the anchors, the bit was worn, too small at the tip, or just plain the wrong size. Underside and top spalling will occur if a sledge hammer is used. Use a rotary hammer drill, not a regular Dewalt with a concrete bit - you’ll be drilling long before the cows come home. When drilling, make sure you hold the drill perfectly vertical. Although it’s impossible to be perfect, pay attention and do your best.
After the holes are drilled, get a vacuum cleaner and clean all the dust out of the holes and around the work area. If using epoxy, I recommend a screwdriver and wet rag to plunge the holes once or twice. Let the holes dry thoroughly before proceeding and it may even help to blow dry after.
Install the 5/8” spacing nut onto the sacrificial bolt. Before proceeding, be sure to install the bolt all the way until it touches the inside bottom of the anchor. This way the threads won’t take all the punishment of the pounding and make removing the sacrificial bolts difficult. Once the bolt is making contact with the inside bottom of the anchor, position the spacing nut 5/8” away from the anchor. Pound in each anchor until the top of the anchor is approximately 5/8” below the surface of the concrete. Repeat steps. If using epoxy, install one at a time. Do not pour epoxy in all of the holes at once.
After the anchors are installed, install a flat washer, then start tightening the 5/8” spacing nut to set the anchors. Depending on the condition or hardness of your concrete, the final size of the finished hole, the aggregate and other conditions, some of your anchors may set higher than others. However, they should pull up at least 3/8” – ½”. It should take a little elbow grease to set them properly. If you find it super easy to pull them up, and/or they start protruding from the top of the hole, you may have suspect concrete or an oversized hole. I would investigate the cause before proceeding. If using epoxy, let the epoxy dry fully before using the lift. After the initial use with car, the anchors may tend to creep up slightly further as the bolts make their final set - this is normal.
NOTE: Some of you will find the top of the concrete spalled or cracked away a little around the hole during installation. Brand new, sharp drill bits will minimize this. If, after the install is complete, you would like to pretty up the floor around the holes, the best thing to use is an epoxy rather the Quikrete. Quikrete or concrete patch is easier to use, but it’s brittle and will eventually crack away due to stress and strain on the concrete during lift use. An epoxy or Bondo type fill is flexible and will make a better patch around the anchor holes. You can even add paint or color to the epoxy to better match your floor.
Jeff
BendPak
Seanbev24
Lynnwood, Wa
Thanks for the info Jeff. I'll finally be installing my maxjax soon. It's just been sitting in the garage while I get some other things taken care of.
dmeadow
Houston, Texas
Thanks, Jeff. Wish I had this info before doing my install. Any insight into why Wej-it changed the design of the PD58? Will the new design start showing up with the MaxJax soon?
tatra
pirate contest city
personally i like to drill right thru concrete so the old insert can be pounded thru of damaged and a new one installed in the same hole..........would the epoxy be such that it would prevent one form doing this?.........is it ok to drill thru and not affect the insert's capabilties?.........and have you considered offering just a base plate as an accesory for unhindered drilling .............could allow for one to drill holes at a remote location and not have to haul a tower around,,,,,,,,,and while i have you here............my floor is the pits and figure my best approach is to drill piers and then pour a slab on top.........any pointers........already have the auger so cost for me would be minimal...........bought mine on the original group buy and still haven't got it in yet..........hopefully before the snow flies...........thanx
kj68135
Jeff- When you talk about using epoxy with the anchors, if going that route would you purchase different anchors than what are included with the MaxJax?
I'm going to be installing piers for my lift; am hoping 3'x3'x8"-12" will be sufficient. In your experience is that adequate?
Thanks
regguy1
On Mount Olympus with Zeus
Helpful Post :thumbup:
Consider printing up an info sheet like that and including it with MaxJax.
Instructions are nice, but sometimes little tips from practical experience really help.
PLRX
SoCal
Great information. I already lay out a new foundation for my Max Jax.
I'm planning on drilling, set it up and then paint my garage floor with 1-part garage floor paint.
BillGalbraith
Great information. A couple questions:
I'm no where near ready to install, but when I do, I'd buy a new drill bit and rent a hammer drill. Will the drill bit stay sharp enough to do all of the required holes? (I have 3500 psi concrete, if that makes a difference).
What about a template to drill the starter holes? Could a steel plate be precision drilled for the exact location of the holes, then all the pilot holes drilled at the same time? I guess it would be 'drilla hole, insert a steel pin to maintain that position, drill another hole, insert another pin'.
Joe From NY
NY
i just put mine in last week after waiting 5 months for a new pour and then it curing. you can lay the column on its side, trace and cut plywood the same square shape of the column. then c-clamp the wood to the base and use closest hole saw in each hole to drill out holes in the wood. then lay the wood over the concrete in the proper position. spraypaint through the holes in the plywood to the concrete, and then drill out the paint with your rotary hammer drill bit.
fishinjeff
I joined this forum specificlly looking for info on lifts for my 4 car garage but short ceilings (9'3") & this is what I have gravitated to. Is there a specific epoxy you would like to see used & local sources for said epoxy? Thanks for the info I am about to pull the trigger on one of these as it looks like the most usable tool for my circumstances.
Jeff
Dolfan
Greater Atlanta
Jeff
You might want to check this thread out. I'm in the process of documenting a comparison between mid-rise and MaxJax lifts, which are the two most common lifts for low ceiling use.
Hope it helps.
http://www.garagejournal.com/forum/showthread.php?t=75488
regguy1
Jeff
I used this Simpson Strong Tie Epoxy on my anchors. It comes in a single tube version that mixes in the special nozzel. This stuff is like a rock when it hardens:
WVBrady
WV
Leveling floor rather than "prettying up"
"An epoxy or Bondo type fill is flexible and will make a better patch around the anchor holes."
One of my problems is that my floor was sloped for drainage, so I will have to do some grinding or chiseling where the columns will sit. I was wondering if I could use some epoxy to smooth and level it better after chiseling. (I am not convinced that Bondo is strong enough to put on the floor.) Would the same expoxy as referenced for the anchors be appropriate?
TIA,
Brady
regguy1
Re: Leveling floor rather than "prettying up"
TIA,
Brady
You can shim under the base to level columns. MaxJax supplies shims of various thickness with the lift.
The epoxy is to bond the anchors to the concrete with additional holding power above the wedge action of the anchors, you don't want "flexible bondo"
WVBrady
WV
Sorry, I left out part of my original post. They sent me some shims, but they were all the same thickness. Anyway, there is far too much slope to fix it with one shim and they say not to use more than one shim at any one location. The instructions say that the distances between the columns at the top and at the bottom should not differ by more than 1/8"; that is a very difficult criterion to meet. I think that the only way I can do that is to use some sort of epoxy or similar material to level the column location in both directions. I mentioned that particular epoxy because, if I used it for the anchors I might have some left over.
creekman
My car width, out to out on the tires is 69", if you use the recommended 115" for a sports car that leaves about 23" between the door and inside face of the post. Also I can reach my pick up points with no extension of the arms. Could I move the posts out further, I have the room and it would allow me to open the door and get my 230 lbs through the door opening?
It's a great piece of work, very heavy duty... The directions are feeble... They say take the hydraulic tube out to mount the hose connection on the post base, then they show the 3 pipe fittings. First off you can install the fitting with the hydraulic tube in place, 2nd you can only install the first 2 fittings, the 3rd has to be installed through the access hole.
Jvvmusme
Bogota, Colombia
I would go for 120-125" widht
c4cruiser
Lacey WA
I'll be in stalling my MaxJax with the posts at 130" measured from the back of the bases. I'll be using the lift for two Corvettes (c4 and C5) When I did the initial rough measuring, I found that there is a good 6" difference in the width of the jacking points side-to-side. The wide spacing will allow me some extra wiggle room when driving the cars between the posts.
As far as the fittings on the rams, I removed them from the post frames. It didn't take very long to do and having the rams out allowed me to tighten the fittings so there won't be any leaks. Putting them back into place was easy.
mkjrcc
has anyone thought about putting the maxjax lift on the driveway when the weather is nice outside. Install 2 cement pad for the post. I'm thinking about doing that next year.
Jvvmusme
Bogota, Colombia
I have done it in Bogota, Colombia. It duplicates your area letting you do others things inside the garage.
sidwin
i see that most people bolt one post pretty close to the wall. i wonder what the optimum distance would be that would still allow you room to work on that side of the car? if the base 14in and i mount the poles 130 inches across that would give me 102 inches minus a car. if the car i'm using is 80 inches wide that would give me 22 inches. that would give me 11 inches per side plus the base= 25 inches. is that enough room? or should i aim to have the post 10 inches over to start?
sidwin
i finished my installation. like every one said a 90 degree fitting should have been included to make the hoses lay flush. i got mine for $3 a piece at hydraulic hop. I bought 5 ft extension so i could move my main unit into a corner. that cost $35 for that hose but now mine fits and looks cleaner. 7 out of my 10 anchors went in fine. i tried redoing the 3 but the spun again so i'm going to be getting epoxy anchors. i epoxy each hole when i used the standard wej-it anchor. to be honest i wasn't impressed with the stock one.
get 10 quarts of atf dexron 3. troubleshooting you will have oil everywhere. the hoses don't come with teflon on them so you should add them. i've only tried lifting one car and it worked. i had to retorque the bolts afterwards.
thanks,
sid
sidwin
after having it for 4 months i figured out a couple of things i would have done differently during the installation.
go buy epoxy anchors. they are expensive but 100x simple to use. buy 2 tubes to concrete epoxy. The drill bits for sps max is god awful expensive. Between the anchors and drill bits were the most of the installation cost.
if i had to do it again, i would have either gotten the stock line cut and replaced with the 1/2 npt reducer on one side then ran the line directly into the post. I would have not used a single fitting on the post at all. would have prevented the headaches with all those little nagging leaks. i would have put the quick connect on the reservoir.
olytdi
Olympia, Washington
I found no need to mess with epoxy anchors. My install went flawlessly with standard anchors. I've been using it for two years and have had no problems whatsoever. Four and a half inch pour: no cracks, movement, etc. Still torques to spec.
I ran my lines up and over to my wall-mounted pump.
I mounted my column closest to the wall with enough room to walk between it and the wall...
Cobra96
Hello Everyone!
Just wondering if anyone has had a similar problem.
I installed my maxjax lift with PD58s outside. The majority of the anchors worked well, with the exception of three of them where the concrete was only 4" thick. I used three power serts to remedy that problem.
NOW, I'm installing the lift in my garage where the cement is 6" thick. While setting the anchors, a hairline crack developed that connected all three of the rear anchors. Im 8" off the edge.
Just wondering if anyone else has experienced this? It happened while torquing the base plate down. Wej-it specs recommend 90lbs.
ct71rr
Massachusetts
What is a good measurement to use for the distance from the garage door opening? I'll be lifting full size cars for the most part.
realien
Atlanta
I am in the middle of installing my max jax mx6 and one anchor (middle back) is spinning with a bolt in it, I've put a little epoxy around the top to see if I can get the bolt back out once its set. Anyone had to deal with this and have advice ?
sidwin
Hopefully u drilled all the way through. Punch the anchor through the ground. Stuff tissue in the hole. Shoot epoxy in the hole then try again with new anchor. If sound again go get a chemical anchor.
Thanks-Sid
realien
Atlanta
Thanks-Sid
Unfortunately I did not drill all the way through, my garage concrete is like 7" thick and I didn't get all the way through..
Next option was to use my 4' pry bar and see if I can pry it out
realien
Atlanta
lucky for me the epoxy did the trick, it torqued to 90 ft/lbs as did the others, so should be good now ( torqued without the lift to confirm they didn't turn or move
realien
Atlanta
MX6 locking mechanism ?
Does anyone have the MX6 ? The instructions for the locking mechanism that goes on the back of the lift seems to be missing, they tell you how to use it, but no indication of which bolt to use and orientation, I think I know how it goes based on the picture on the lift post, but the actual instructions are severely lacking :)
