Update:
It runs!
Got everything temped up, crossed my fingers, turned the key... It turned over twice and fired right up!
Idles great, accelerates smoothly, no stumbling or hesitation,
BUT... Has a nasty exhaust backfire if I let off the accelerator abruptly. I can bring it down slowly and reduce the frequency and severity of the backfire but not eliminate it completely. Adjusted the idle jets on the carb, checked for exhaust leaks, plugs, wires, etc. I do have the stock vacuum line going to the ECU. Even tried temping up the Honda airbox to see if that makes a difference. Not really.
Does not backfire through the carb, just the exhaust.
Have a Weber jet kit on order, will try that next. Currently jetted at 45, might just be too lean. let's hope it's that simple.
Ideas, thoughts suggestions, criticisms, complaints, snarky comments welcome.
(Weber 38 carb on a Honda 1500 Goldwing Engine in a 32 Ford Roadster isn't something that yields much help on a Google search.)
