Trust me guys I understand.
Mike I also always did the bounce test.
In no way was I ever thinking you were unsafe and apologize if that’s how it came across.
I hope others will read and heed your methods.
I used this type of hoist extensively, daily, on all types and sizes of vehicles for most of my last 10 years as a professional mechanic.
My post was just my thoughts and mostly aimed at the users with less experience.
Your post that spoke of the rear frame kick up is very much in line with my experience
No worries. To be honest, I wasn't quite sure how to take it but now understand. I have only been working off a 2-post lift for the past 14+ years now so I'm sure nowhere near your experience but thought I'd share my thoughts of arm placement as well as additional support in case anyone else had questions.
Wow Mike that might be a hell of a project zero'n out that furd, I'm surprised you took this on. Past that I'm a little taken back about what you stated the owner said. When he commented that the other shop didn't say anything about the other ball joints, was he doubting your recommendation or was it nothing more then a comment and you have free rein to do whatever it takes to make it right?.
Yeah, I know it's a Ford Cam, but I'm up for the challenge to try to make it a decent ride.
I don't think he was doubting me as much as just waiting for his ride to arrive to pick him up after the test drive.
He had mentioned he had a weird shimmy in his steering wheel and suspected brakes originally. When he arrived I said I wanted to go on a test drive with him to confirm what he was experiencing as I don't like to just throw parts at something based on no evidence. During the test drive I mentioned that I had no indications of warped brakes or pulsing in the pedal like he had mentioned a few months ago. I mentioned that if the pulsing is accompanied by a shaking of the steering wheel, then it usually is indicative of front rotors either warped or some disk thickness variation going on and if it is felt in the floorboards or in your ****, then it will cause for more suspicion of the rear brakes. I explained the difference while driving but said I didn't feel either.
That is when he told me that it seems to come and go and isn't consistent.
Okay, that sheds a different light on things and explained why I then really didn't suspect brakes because a warped rotor or a thickness variation isn't going to come and go intermittently. Those conditions either exist or they don't.
That is when he said it seems to be worse on rough roads and after having a flat repaired the guy at the tire shop told him he had a bad passenger's side ball joint. Okay, well that seems a little more logical as to how it can appear to come and go depending on the road surface during braking.
Once back to the shop and while he was waiting for his ride to show up is when I thought I'd rack it and check the passenger's side ball joint while he was standing there. Yes, it was bad and had a considerable amount of slop, but when I walked to the driver's side with the pry bar and gave it a test, THAT is when I about **** myself when I saw how much play there was. Even the look on the owner's face was evidence he had no idea how bad it was. I told him it was good we got it in when we did because I didn't know how much longer it would remain intact, it was that bad.
Other than the ball joints, it looks like all fluids will be replaced and he wants me to give it a good once over while I'm under it. I noticed the tires are wearing very uneven and suggested a more frequent tire rotation than 10k miles as once the irregular wear begins it is nearly impossible to correct, and with large lug all-terrain or mud style tires it becomes even more critical to ward off irregular wear.
