Found your thread searching for Garage Gator, I’m considering one for us and our 5 bikes, golf clubs and hockey bags. You seem to like it - any gotchas or words of wisdom?
I think it will not hold all of those at once.
On mine, there is a metal loop that gets pushed up when the hoist is all the way up. This stops the motor. The bolt that the loop pivots on got bent, so I had to do some work on it, got a replacement bolt and had to put a new spring on the loop.
The hoist drops a few inches as soon as you stop the motor. It didn't use to do that. Sometimes it drops a bit as the loops of cable uncross in the spool.
The whole thing is a bit inconvenient. If you have a car in the garage you have to take it out.
The way you are supposed to use it, is you hang the nose of the saddle on the bar and then drop a hook over the seatpost. But then the bikes hang down and I'd have to duck under them. So I have the wooden boards to hold the bikes level and high. I believe my garage is right about a 10 foot ceiling, and I can walk under.
