They are made somewhere in Lower Saxony. Can't narrow it down any further either.Can’t answer the question, but I’ve seen the same tool branded Stahlwille, Hazet, and Saltus as well.
6-24V Matador probe light. Solid brass, very old school high quality. Fetched it in Bauhaus. Matador is only etched on, but made in germany is stamped. Who is the original manufacturer?
0 to 6 flatheads, 0 to 2 PH (already have a size 3).Which size did you get?
Dukefx basically said it.What's the difference between Wera's Zyklop bit adapter (8784 A1) and the more muted 784 A?
Nice, I was told by my mother to hit the bottom with your flat hand.BRIX JarKey, Made in Denmark!
It allows you to break the vacuum seal on stuck jar lids, thus making them easy to open (or so it is advertised).
I have a small Gedore hammer in my kitchen that I have been using to tap around the edges of stuck lids to accomplish the same, but hopefully this should be easier and a bit less destructive.
Ahhh, thank you. I missed it and Wera's website wasn't much help. It looks like you gain 7 mm of clearance, but lose compatibility. Also seeing some complaints about the ball detent not lining up correctly on a lot of tools.The 784 accepts only C type 1/4”, or C type 5/16” - but different tools for each size.
I've always found anything UNIOR to be overpriced and very "roughly" made. Maybe its the local distributor to blame for the prices but still, not really worth it.
Are those magnets long? I need some good ones to hold the prints up at work but I’m looking for something that isn’t stupid long so I don’t bump them off when I’m in and out of the milling machines.
I have that too from when I visited Switzerland. An excellent tool with tons of uses, it resides permanently in my main socket set case.
Is that a scribe tool?
about 60mm. A little bit smaller + shorter than their hook + pick handles.Are those magnets long? I need some good ones to hold the prints up at work but I’m looking for something that isn’t stupid long so I don’t bump them off when I’m in and out of the milling machines.
yes. PB Swiss "PB 700.190"Is that a scribe tool?
Thanks for the overview ! I have the red handle one too. It´s a bit longer and has a springy feel.700 Angular Scriber:
702 has carbide points and different dimensions:
703 has a lightweight, visible, easy to clean, plastic handle:
You are the man!
