littlebean
- Joined
- Mar 7, 2018
- Messages
- 802
SwissMetric -that's great, thanks
I believe that your nice Elora 870-1-U has a date code under the selector cutout. It appears to be either a 75 or 76 date code? I have one of these guys as well. On mine you can clearly make out the "7", but the second number has been smudged while stamping, so it's unclear whether it's a "3" or less likely a "9"? More likely it is a 73 code. Anyway, just thought I'd put in my input. Thanks and Happy New Year!I just thought I would compare my different 3/8 drive ratchets:
The standard Hazet 8816P is probably the one I reach for most often. It's built like a tank but the drag resistance is the highest of the bunch. I think it's just time for some lubrication...
The Hazet 8816F is the fine tooth version and is a huge contrast to the standard one. The drag resistance is the least of all in this group except the Koken. It has a very precise feeling mechanism. The design is unusual looking, but I really like it. Inside the mechanism is similar to a Facom. Like the other Facom based designs, it tends to be a bit tall and that can sometimes be a factor in tight spaces.
This is an older versoin of the 8816F from the 1980's. It's much longer but not as smooth as the later one, but it is still very nice. The reversing knob on the top sometimes gets unintentionally switched, especially when you're using your palm.
Here is the famous Facom. I heard so much about it that I just had to try one. It has the free-spinning palm control disc on the top so it won't switch in your palm. The mechanism is very fine, almost as good as the later fine tooth Hazet. The ratchet is signifigantly shorter than the others in the group. That could be an asset in some situations, but is a disadvantage in others. They do make a long version, though. There is no COO on the tool, nor was there any on the packaging it came in. But my friend inside Facom Taiwan told me that these are made by USAG in Italy.
Another famous ratchet, the fabled Snap-On F80. It won't disappoint you in any way. It's so so nice. It's the prima donna of the group and it knows it.
This is an older Snap-On F=71B ratchet with a date code from the year 1949. I actually like the looks of it better than the contemporary one. It still works just fine. Very smooth.
This Elora 870-1-U probably dates to the 1960's or 70's. The mechanism inside is pretty similar to a Snap-On. Its mechanism was very worn and sloppy so I replaced the pawl with one from a modern Elora. The newer gear wheel wouldn't fit because the top part was a larger diameter. I thought about machining it to accept the new gear wheel but decided against it. I wanted to preserve its originality. So now it's half rebuilt. Its action is acceptable now.
This is really a clone of a Belzer. Which in turn was heavily influenced by Snap-On designs.
Old Belzer socket set for sale on ebay.uk
This is the undisputed champion of smoothness and low drag resistance. The mind-boggling Koken 3753P. Its smoothness is almost supernatural. You can hardly hear it. Nothing else even comes close. I don't think that it is particularly good looking, but it definitely does the business!
The mechanism inside is pretty much the same as those of Plomb/Proto which of course are also famous for smoothness.
I had never heard of Lauravia tools prior to this and, upon searching, learned that they joined with SAM tools of France in 1970. The SAM tools website said Lauravia had a large line of automotive and aviation tools.A few I came across last month... I believe the former owner was an aviation mechanic based on the other tools and Cessna parts I found at the estate.
Bahco Flex End Box Wrench - Made in Sweden
Belzer-Streamline Open End Wrench - Made in Germany
Lauravia Universal Extension with Cross Bar - Made in France?
There is a bit about Lauravia on the Facom thread.I had never heard of Lauravia tools prior to this and, upon searching, learned that they joined with SAM tools of France in 1970. The SAM tools website said Lauravia had a large line of automotive and aviation tools.
Hello again all! I finally got my hands on an old German made Belzer No. 7750 rat today, that dates all the way back to the 1960's. I gotta tell ya, these German made pieces have really peaked my interest recently. I really wanted to see just how close these were to Snap-On's F-71. So I tore into it, and my suspicions were confirmed. It not only does share component compatibility with the Snap-On F-71 model, it's practically it's clone as well! Just out of curiosity, to test my theory I installed every component, except for the bushing, but the gear, pawl & coverplate, all drop in perfectly into the 7750 head and work exactly just like an F-71 would. The parts dimensions are identical! Makes sense beings the two rats are practically twins from another mother...haha! Besides some altered cosmetic differences, and a slightly heavier overall profile on the 7750, you would think they were related! The 7750 has seen a good amount of use, so has this F-71. The 7750 parts are worn, and have chipped teeth, both on the wheel and on the pawl. So much that it does skip at a couple places. I am considering rebuilding the 7750 with a repair kit, problem is there really aren't a whole lot of choices out there when it comes to replacement parts for this 7750. I'm going to experiment with the Stahlwille 435 kit. I think the parts from that rat will work? Here is a few photos of the two side by side. You can obviously see the cosmetic similarities they share with each other. The 4th photo is a internal comparison of the two, even the internals really do look alike. Thanks and enjoy! -JS
You're welcome. Sorry for my late reply.SwissMetric -that's great, thanks
In the USA Felco is well known among gardening enthusiasts and professional landscapers and plant nursery employees. I have never seen them at big box stores such as Walmart. Walmart sells Fiskars gardening tools in their stores (at 1/3 the price of Felco). Felco spare parts are readily available online from Felco North America and other online sources.@Outahere:
Didn't know that Felco was known in th U.S.
It's a small Swiss company, as gardening-ignorant I only know that spare parts are sold in many specialized stores here......
The Felco C7 cable cutter is also well-loved in the bike mechanic community, used in just about every decent shop in the country.In the USA Felco is well known among gardening enthusiasts and professional landscapers and plant nursery employees. I have never seen them at big box stores such as Walmart. Walmart sells Fiskars gardening tools in their stores (at 1/3 the price of Felco). Felco spare parts are readily available online from Felco North America and other online sources.
Felco is basically the “industry standard” for high end garden loppers and pruners.You're welcome. Sorry for my late reply.
@Outahere:
With some basic maintenance they last decades. A zillion times better than consumer products like Wolf or Gardena, always found those two totally overrated.
@JSCraftsman:
The Belzer ratchet mechanism looks surprisingly close to the Stahlwille.
That said, some quite old Stahlwille 512 (1/2") versions require the diameter of the hole for the lever to be increased. I don't remember exactly the details and I'm not sure if it applies to the 415 (3/8").
Here is one of the better “local” hardware stores in Philadelphia that carries Felco.Thanks for your replies. I didn't know that about Felco, here their main products are very common and sold in many stores, from small local shops to garden centers and DIY stores.
Also I'm totally ignorant when it comes to anything related to gardening and landscaping, if I could I'd like a reinforced concrete garden, totally fireproof and low maintenance costs.
Here common spare parts like blades and springs are sold in self-service retail blisters.
A typical example of expensive tools which cost less over their lifetime (TCO for those who like abbreviations) because they last very long and spare parts are easily available.
Felco doesn’t cast their handles.My Felco bypass pruning shears have held up really well with use, but like anything that cuts, eventually require sharpening.
I have a couple models from Stihl that are made in Japan and can hold their own, especially the orange handled PP10. I like the textured grip over the smooth Felco grip and the easy to operate lock. The PP40 has ergo hard handles and steel blades, no lamination. They are lightweight but strong and the thin profile can advantageous cutting close to forks.
For heavy duty work, the Cutco 1527 is extremely stout. Where these others are using thin steel blades on diecast aluminum handles, Cutco uses a thick one piece 4116 high carbon german stainless steel for the entire tool. They are weighty, but these are the ones I grab when cutting stubborn vegetation. They just feel unbreakable. These also have grippy textured handles, a unique grayish purple.
The Cutco anvil shears are ratcheting and lighter duty, but have less pull on fragile plants.
As always, its good to have a variety of tools for different applications.
Regarding the wire rope cutters, I have the Felco C7’s and they are definitely the standard by which all others are judged, but I also have a pair from TOP Japan that have been just as good. Knipex makes some nice ones too, as well as a Bowden cable cutter that is top notch, no pun intended.
I did discover that the Stahlwille 435 (3/8") mechanism is indeed very similar to the Belzer 7750 mechanism. And as you mentioned regarding the larger hole on the Stahlwille, yes you are correct, the pawl receptical bore hole on the selector side is greatly larger on the Stahlwille vs the Belzer. So right away I could see that the Stahlwille pawl wasn't going to just drop right into the Belzer pawl cradle. Also, the Stahlwille's pawl is just slightly larger than the Belzer's bore, again just enough not to allow the pawl to drop in there. Now if I was completly nuts, and I didn't care about modifying the machining on Belzer head, I may remotely consider making the modifications on the Belzer. But I'm not going to do that! As for the Stahlwille's gear fitting into the Belzer's head, yup that would definitely work. The Stahlwille's 30 tooth gear thickness and diameter are practically identical to the Belzer's 30 tooth gear. But at the moment, unfortunately this 7750 is suffering from a stuck ball bearing, wedged inside the spring hole. Luckily there is still a spring under the bearing. The next day I get, I'm going to set up my drill press and extremely carefully drill out the bearing with a 3/32" carbide drill bit that I received today. I am going to go through the original hole at the top of the head which has the brass oil orfice, the hole which was originally used for drilling the spring hole. I was able to punch out the brass oil orfice, or just the body of the orfice, as the spring & ball in the orfice took a hike somewhere long ago, and never returned...haha. But the bit should go through the bearing like butter. I'm just waiting for a good warm day to do it, which who knows when that will be? Hopefully soon! -JSYou're welcome. Sorry for my late reply.
@Outahere:
@JSCraftsman:
I own an older (over 25 years) Bosch cordless drill and an older corded Bosch jigsaw that were manufactured in Switzerland. Is there still a Bosch power tool factory in Switzerland? A year ago I bought Bosch's top of the line corded jigsaw, and it was manufactured in Hungary. Made-in-Switzerland jigsaw blades are very common in the USA.It still sort of surprises me as there are lots of not that expensive tools made in the U.S.A., and Swiss made tools tend to be way more expensive Also there are only few manufacturers left like e.g. P. Baumann (PB), Gressel, Fraisa, DC, UMV (Vallorbe) or so. Fribosa died recently (2023?). No idea what happened to Reishauer (maybe I should google it).
Sadly the Swiss industry shrinks every year though interestingly many manufacturing jobs will never be replaced by AI.
Power tools manufacturing in Switzerland was stopped 2018.I own an older (over 25 years) Bosch cordless drill and an older corded Bosch jigsaw that were manufactured in Switzerland. Is there still a Bosch power tool factory in Switzerland? A year ago I bought Bosch's top of the line corded jigsaw, and it was manufactured in Hungary. Made-in-Switzerland jigsaw blades are very common in the USA.
Hello from the other side of the Alps (Slovenia)! In proper agricultural shops, Felco is also common here, as well as the German Löwe which is very similar in quality but I think far less known globally. I've recently been in the winelands region of South Africa and was surprised to see a lot of Felco. More than once I've seen hardware stores with big Felco signs. So I assume it is one of the bigger brands in wine regions of the world, apart from Europe probably also California, Australia and maybe even Chile. South Africa is relatively poor and I really did not expect it there...It still sort of surprises me as there are lots of not that expensive tools made in the U.S.A., and Swiss made tools tend to be way more expensive Also there are only few manufacturers left like e.g. P. Baumann (PB), Gressel, Fraisa, DC, UMV (Vallorbe) or so. Fribosa died recently (2023?). No idea what happened to Reishauer (maybe I should google it).
Edited:
The 2nd wire cutter shown by Dave455 is quite common here.
Lots of Felco parts are listed with price here:
FELCO Switzerland | Swiss Precision. Made to Last. | Official Store
Official FELCO Switzerland website. Pruning shears, loppers and other cutting and gardening tools – Swiss quality and durability since 1945.www.felco.com
Felco is one of those small Swiss companies well established in niche markets. I never contacted them but typically you could probaly end talking to a design engineer or some other expert if you've a really specific question. Usually there are no call-centers with some agent you can't even understand due to a thick foreign accent, with calls routed to another continent, especially for some French language call centers, for German you'll likely end somewhere in Eastern Europe.
