Yeah that my opinion too, the appropriate tool instead of this is an oxy cutterIf I ever found a piece of equipment that needed that, I'd scrap it.
Kinda wish I owned a dozen universal socket swivel adapters and could chain them together and take a pic as a joke but I’m sure someone here doesThe extension length in the middle being a fixed length means it's tailored for only perfect scenarios
I was going to point the same thing out. It'll get bound up.
Many times, I’ve removed an obstructing part, so I could get at a fastener, but not sure in how many instances this tool would be better.I have used a universal with an extension with a universal socket… which does the same thing.
I can’t imagine buying that tool, unless I needed it often. You wouldn’t be able to change the length of it.
^See above.Well, if you're building a tiny pickup and you need a driveshaft...
That's where the cutting torch comes in.Many times, I’ve removed an obstructing part, so I could get at a fastener, but not sure in how many instances this tool would be better.
Even VIM couldn't come up with oneGot to admit I'm surprised it doesn't come with a recommendation for the specific use case, ie on 27 to 28 ford tundras bottom left turbo encabulator nut without pulling the engine
I hadn't noticed that. I wonder if there's an actual reason it's made that way? Something to do with the forging or assembly order that makes it cheaper or quicker if it's out of phase?
I as well, always been on 24 or 36" extensions. Once two 36" together.I've had times where we needed two universals to get past some obstruction to access some hardware, but never on that short of an extension.
First, OCD. Second, no, that's not remotely what a double cardan joint looks like, and if it was, there wouldn't be a phase issue....First they are sort of double cardan joints on each end, not a single cross/cardon joint like on a typical driveshaft...
That is why I used the phrase "sort of"First, OCD. Second, no, that's not remotely what a double cardan joint looks like, and if it was, there wouldn't be a phase issue.
Universal socket extensions get used at much larger angles than driveshafts (which in reality see angles more like we'd expect from wobble extensions), and as the angles increase, the issues with that phasing become more apparent. My issue here isn't with constant velocity, but with the shaft wobbling. With every turn, one universal is going to take more of the angle and then the other, rocking the shaft up and back. There's going to be a point (probably before 45 degrees), where the fight between one universal and the other will drive so hard to one side that the joint that loses is going to lock up. You can test this yourself with two universal socket adapters connected in line, if your universals happen to align the ears with the square drive.
Then again, this is a tool in search of a problem, so why not let it create some problems of its own.
Yes, you are missing something.Setting aside the frequency of its utility, I don't understand why it would ever sell if the same exact tool can be assembled with two knuckle joints and an extension of any length you want. I mean, that's the whole point of interchangeability, and the whole reason the industry moved away from fixed socket wrenches, circa 1902-1919. Am I missing something?
I have been in situations where a universal joint on an extension with a socket ended up being too tall and nothing else would work other than an extension with a single built-in universal joint. Not an everyday occurrence of course.I wouldn't be overly concerned with the connections, and I don't think the profile advantage would be enough to make me, personally, see a need, especially when it would imply buying several of them in different OAL's to achieve the same potential functionality I can achieve with tools I already have, but okay, yeah, those are valid differences between the tool in question and doing the same thing with two uni joints and extensions.
who makes those and what length extensions do you like for itI have been in situations where a universal joint on an extension with a socket ended up being too tall and nothing else would work other than an extension with a single built-in universal joint. Not an everyday occurrence of course.
I'm not really following you with respect to "height" (or "too tall"), which is an odd dimension to use in this case. The VIM tool has a sleeker profile in the sense that the male and female universal joints permanently pinned to the extension are the same diameter as the extension. Yes, building the equivalent tool with detachable parts, the universal joint attached to the male side of the extension is going to be wider than the extension. That could, I suppose, create obstruction issues, in some unforseen use cases. I can't imagine what they might be, but yes, as I said above, it's bulkier than the VIM tool on that end.Less height, less slop relative to the extension + universal joint.
That looks handy. Where can I get one in 1/4, and 3/8 dr.
Seriously?That looks handy. Where can I get one in 1/4, and 3/8 dr.
I thought if I liked it enough, I'd get it in 1/2 and 3/4 dr. That would complete my sets.Seriously?
I too once looked at this and thought, hmmm, I'll bet that could come in handy so paid the $15 or so at Harbor freight for it. I tried conjuring up scenarios for using it but always failed. Gave it away a while ago otherwise you could have had mine.
Don’t forget 1 inch driveI thought if I liked it enough, I'd get it in 1/2 and 3/4 dr. That would complete my sets.
