It looks like a string of Permatex or something. Definitely not a crack.
I agree.
Indeed!Ouch!
Thanks. It could be yours! I chipped off whatever that drool was and the red paint is less faded there. It probably happened early on.I agree.
I zoomed in and didn’t see a continuous line like a crack.
Just an old “drool” of some product that hardened up.
Thats a fine example of the earlier, made in USA, vises that Columbian made for Sears. Maybe 1960’s or ??? Still in original paint!
Nice find Don![]()
Thanks…I edited my earlier post.That's a '60. I had one.
Thanks for the heads up. Those collars can be pretty pricey, But it might also be a good bargaining point. If the dynamic is welded, that would just be deal breaker. He first posted @ 125, and then changed, so seems he isn’t set on anything.Looks to have an improvised collar for the spindle. Check closely for breaks at the base of the dynamic jaw as the picture shows some boogering there. I'd probably go for it if everything worked and no major casting breaks that it is not a common vise at all. Swivel base rotating vise. Pretty cool. Ed.
Those look good! Do they install with just a hammer? No rivet tool needed?Good morning,
Looking at the screw nails (rivets) on the McMaster-Car site. Can anyone tell me which one to order for the badge installation? Thank you.
Not much online about these big fellas
yeah, I am struggling with that. Using grease would just be a magnet to attract grinding dust. However, it appears to be necessary?Do two parts slide/ride/turn against each other? Grease 'em. Otherwise, rust prevention.
I prefer a dry moly lube (like Molycoat) for things that are exposed, like the slide. It doesn't collect grinding dust. My vises are users.
This is what I use: https://www.dupont.com/products/molykote-d-321-r-anti-friction-coating-spray.htmlyeah, I am struggling with that. Using grease would just be a magnet to attract grinding dust. However, it appears to be necessary?
Yes, I am going to use the heck out of this thing, it will get beat on....
RP
Thank you, four.cycle. All excellent resources. Really appreciate it. I hadn’t heard of these lists. I had, of course, done lots of searches here, but wow, there’s a LOT to wade through.International Tool Catalog Library is your friend.
list of vise brands
gigantic list of vise brands
Go to Vise Info Thread
click "search" at top right.
click "everywhere".
click "this thread"
in the "search" window type "parker"
in the "by member" window type "four.cycle"
click "search"
Thank you, four.cycle. All excellent resources. I hadn’t heard of those lists. I had, of course, done lots of searches here, and not stumbled on too many personal experiences with this vise. It is a rare one!International Tool Catalog Library is your friend.
list of vise brands
click "everywhere".
click "this thread"
click "search"
Did some extracting of pages from Craftsman Catalogs, specific to bench vises. Thought they might be useful to others.
That Holland 16 is certainly a big boy. I’m betting the weight is less than 170. Some reliable sources say 132.
I don't see your overhead lift?
Upon 'official weigh-in', it comes out to 141 lbs... after compensating for the three pound bucket...
The thickness of rust on the platen should match that on the balance beam, keeping it calibrated!When was the last tine that scale was calibrated?![]()
