The VISES of Garage Journal
Shiftless
East Bay SFO
It looks like a string of Permatex or something. Definitely not a crack.IMG_7543.png
I agree.
I zoomed in and didn’t see a continuous line like a crack.
Just an old “drool” of some product that hardened up.
Thats a fine example of the earlier, made in USA, vises that Columbian made for Sears. Maybe 1960’s or ??? Still in original paint!
Nice find Don 🍻
Shiftless
East Bay SFO
The swooping triangular shaped “tail fin” feature on the side of that line of vises inspired me to paint one up in 1957 Chevy colors. I started with a vise I bought cheap because it had suffered a run in with a grinder wheel. I filled that gouge with epoxy. If I ever sell it, I will tell the buyer it has more than a bit of filler in that spot.
You can see the gouge in the last picture.
jawstight
I like these particular Craftsman vises because of that "fin". I think it's supposed to resemble the tail of an anvil? I like your paint scheme though. The '57 Chevy was a Classic to be sure.
I agree.
Nice find Don 🍻
Thanks. It could be yours! I chipped off whatever that drool was and the red paint is less faded there. It probably happened early on.IMG_1206.jpegIMG_1205.jpeg
CRSINMICH
Southeastern Michigan
Those pictures of fins reminded me of the 'Old Pictures' thread. It hasn't been used in a long time but it's a hoot.
ZOSO45
Good morning,
Looking at the screw nails (rivets) on the McMaster-Car site. Can anyone tell me which one to order for the badge installation? Thank you.
PeterPeter
Newburyport
Going to check out this Parker 449 He wants more than I am happy paying. Not much online about these big fellas. If it were a 474, that would be an easy decision. Anything anyone can tell me what to look for (weak points, etc.)
thnx. Peterx2
Oregon rock crusher
West of Salem
Looks to have an improvised collar for the spindle. Check closely for breaks at the base of the dynamic jaw as the picture shows some boogering there. I'd probably go for it if everything worked and no major casting breaks that it is not a common vise at all. Swivel base rotating vise. Pretty cool. Ed.
PeterPeter
Newburyport
Thanks for the heads up. Those collars can be pretty pricey, But it might also be a good bargaining point. If the dynamic is welded, that would just be deal breaker. He first posted @ 125, and then changed, so seems he isn’t set on anything.
peterpeter
fishwatcher
Good morning,
Those look good! Do they install with just a hammer? No rivet tool needed?
Got this big sucker done, unfortunately can't keep due to car troubles but had fun with it for being my first vise.
RickP330
Middle Island, NY
Hi guys, I am getting ready to put my vise back together after giving it some TLC. I'm kind of confused as to where to use grease and where to use some rust prevention. The lead screw I presume gets a thin coat of grease and in these pockets, when I took it apart were filled with grease. I had to scrape all the old grease out. I presume I just grease everything? Can anyone give me the 411?
RP
Beerhippie
Far NE Oregon
Do two parts slide/ride/turn against each other? Grease 'em. Otherwise, rust prevention.
I prefer a dry moly lube (like MolyKote) for things that are exposed, like the slide. It doesn't collect grinding dust. My vises are users.
RickP330
Middle Island, NY
I prefer a dry moly lube (like Molycoat) for things that are exposed, like the slide. It doesn't collect grinding dust. My vises are users.
yeah, I am struggling with that. Using grease would just be a magnet to attract grinding dust. However, it appears to be necessary?
Yes, I am going to use the heck out of this thing, it will get beat on....
RP
Beerhippie
Far NE Oregon
RP
This is what I use: https://www.dupont.com/products/molykote-d-321-r-anti-friction-coating-spray.html
Requires masking.
But DuPont has plenty of other versions: https://www.dupont.com/molykote/coating.html
Lots of brush-on options.
The heat-curing ones seem like they might be longer-lasting.
Not cheap, but don't attract dust/grinding debris.
Beerhippie
Far NE Oregon
I used the spray-on MolyKote on the cylindrical slide of my Chinesium rotary-jaw Roughneck when I refurbed it a year ago:
It looks like it's all worn off, but it still glides open and closed with one finger. I used some moly wheel-bearing grease on the screw as it's entirely enclosed.
PeterPeter
Newburyport
International Tool Catalog Library is your friend. ;)
list of vise brands
gigantic list of vise brands
Go to Vise Info Thread
click "search" at top right.
click "everywhere".
click "this thread"
in the "search" window type "parker"
in the "by member" window type "four.cycle"
click "search"
Thank you, four.cycle. All excellent resources. Really appreciate it. I hadn’t heard of these lists. I had, of course, done lots of searches here, but wow, there’s a LOT to wade through.
peter/peter
PeterPeter
Newburyport
list of vise brands
click "everywhere".
click "this thread"
click "search"
Thank you, four.cycle. All excellent resources. I hadn’t heard of those lists. I had, of course, done lots of searches here, and not stumbled on too many personal experiences with this vise. It is a rare one!
jawstight
Did some extracting of pages from Craftsman Catalogs, specific to bench vises. Thought they might be useful to others.
  • 1963_Vises.pdf
  • 1972_73_Vises.pdf
  • 1981_82_Spring_Vises.pdf
  • 1981_82_Vises.pdf
  • 1982_83_Vises.pdf
  • 1985_86_Vises.pdf
  • 1994_95_Vises.pdf
jawstight
Thanks. I don't think I've found anything knew, but didn't know about that thread. Sorry for the redundant post.
What I'm looking for in particular are the '84, '89 and '90 Craftsman Tool Catalogs
682bear
West GA
That Holland 16 is certainly a big boy. I’m betting the weight is less than 170. Some reliable sources say 132.
Upon 'official weigh-in', it comes out to 141 lbs... after compensating for the three pound bucket...
USPS also just delivered another hand vise... this one is a Goodell-Pratt geared jaw vise...
It's dirty, but is in very good condition and works smoothly.
-Bear
Beerhippie
Far NE Oregon
-Bear
I don't see your overhead lift?
Sweet lil' G-P!
akasrick
south jersey
I check it every time I use it... it looks rough, but works well.
You can't expect it to look like much for the $25 I paid for it!
-Bear
The same bucket must have been used at weigh-in or someone at the factory had their finger on the scale.
akasrick
Tom99
I picked up a Chas. Parker 973 1/2 last week with one serrated jaw and one smooth. Did Parker ever do this? Or was it ho-made or possibly a switched jaw?
I suspect the serrated jaw was a replacement. The fit isn't quite on par with the "smooth" one - which is serrated, but in the old style for the 97X series - my 974 is serrated like that.
