Really depends on what you are doing. My only air use is nail guns, so improved flow over M won't matter.Only buy High Flow ones. Your tools will really wake up.
I've never seen these before. Is there an advantage to them?Right out of high school I started in a higher end bodyshop. After a couple years as much as I liked bodywork, I decided I didn’t want to do that for the rest of my life and I joined Uncle Sam’s School For Wayward Children (USN) and ended up staying 25+ years.
That bodyshop I worked at 37+ years ago used all L-Style fittings. No idea why, that’s just the way it was.
Now that I am retired am built my own hobby, bodyshop I went back to those L-Style fittings.
You have Tru-Flate 3/8"-body fittings instead of the more-common 1/4"-body.All my plug fittings marked "T" are the size of the P style. Not sure how common that is.
No doubt Lincoln thinks so. As I recall, they were one of the first designs for compressed air couplers/plugs. I worked with them early in my career.I've never seen these before. Is there an advantage to them?
nobody can borrow your toolsI've never seen these before. Is there an advantage to them?
I keep a stash of the RIGHT ones just for those occasions.nobody can borrow your tools
These are my favorite. Takes no effort to insert into the coupler. And its true no one will borrow your air tools.Right out of high school I started in a higher end bodyshop. After a couple years as much as I liked bodywork, I decided I didn’t want to do that for the rest of my life and I joined Uncle Sam’s School For Wayward Children (USN) and ended up staying 25+ years.
How long does it take to swap the plug out? A minute if you have to look for the compatible one?These are my favorite. Takes no effort to insert into the coupler. And its true no one will borrow your air tools.
That's part of why I finally moved from 3/8 T to V style... the M ******* fit the V couplers.I've always used the M style because they were cheap and easy to get and most cheap air tools usually come with them, if they come with any fitting.
Pretty sure Industrial/M is most commonWhat is the interface that comes on an air tool purchased at Home Depot? That's the one I want to standardize on.
The wrong one.What is the interface that comes on an air tool purchased at Home Depot? That's the one I want to standardize on.
Whats wrong with M?The wrong one.
I bought a bag of fifty T-style plugs from Azon a while back. I think it was around $15. Why worry about what comes on a tool when it's seconds away from being what you need? You have a wrench right?
The wrong one.
Exactly.Whats wrong with M?
I also often swap connectors, but to get M swivels. That said, I can buy a tool or hose and plug it in as-is.
Whats wrong with M?
Because I have maybe fifteen air chucks scattered around the brewery and they're all type T. A bag o' plugs is much cheaper than a bag o' sockets.Whats wrong with M?
There's nothing better than hearing "because we're always done it this way"Because I have maybe fifteen air chucks scattered around the brewery and they're all type T. A bag o' plugs is much cheaper than a bag o' sockets.
Why type T? because that was "right" thirty years ago on construction sites out here.
This. 5 in 1 couplers with Type V fittings. Done.I've moved most of my stuff to the Milton 5 in One's...They work with M, V, T, A and L style fittings. All metal and easy to use. They are available in 1/4", 3/8" and 1/2".
