Makita Addiction Thread
ObnoxiousFumes
Southwest Sask
So, in theory I like this, but then I am not sure what I would need them for? It would be nice in my mower but they probably won't fit anyway. I want to get some 6ah and try those for fit.
I don't think I would want the weight in any of my other stuff. I already try to use my little 2.5ah batteries in my drills/impacts most of the time. I'm not sure where I personally would want to use the bigger battery.
Angle grinders, they draw a lot of juice.
duneslider
Riverton, Utah
So, I have had a cordless angle grinder for a long time and I have never used it for extended grinding. I love it but I just use it for quick convenience items. If it needs real grinding the cord versions come out. I have multiple grinders with different media on them and just don't see the battery version replacing all of them. I already sort of feel my cordless grinder is bigger and bulkier than the cord versions and don't want to add a giant battery to it. Just my opinion obviously.
Maybe a little more juice for my single battery circular saw would be nice. I have the 36v saw and wouldn't want to put bigger batteries on it and make it heavier. I would probably run a bigger battery on my sawzall for some things.
ObnoxiousFumes
Southwest Sask
Oh yeah, circular saw, recip saw, I think any higher-draw tool can probably benefit from larger batteries.
Unfortunately I have to use Milwaukee for work, as I’m not the one buying the tools, but on the job site almost everything we use is cordless, and the grinders kill 5ah batteries in probably a 1/4 the time of a 12ah.
Even on an impact gun, sometimes a 9ah is nice when you have 432 bolts to tighten 😂4FD61FAA-814E-4BF6-9642-C57224E2AF7A.jpeg
Again, that’s just my experience with Milwaukee, I don’t work my Makita’s that hard at home so I maybe can’t make a direct comparison.
jollygreengiant
Ontario, Canada
Cordless mitre saws, table saws, compressors, etc would all be an ideal fit for these bigger batteries. Those are applications where weight isn't an issue but runtime is.
Now before someone says it, yes you could also run corded versions of those tools. And that's what I do, but there seems to be more and more cordless.
bdbecker
Iowa
I was surprised to see that Makita is just getting into the cordless framing nailer game this year. I started researching them because I need to build a shed later this summer, along with some future basement finishing/wall construction at our new house.
I'm tempted to pre-order the XNB03Z through Acme Tools. Price is $399 for the bare tool, but there's a promo going on right now where they also give you two 5ah batteries. Seems like a decent deal...
Snapped-off
Indiana
Damn, I was going to jump on that but you gotta buy the circular saw too.
Mandres
Does anyone have a good source for Makita parts? I've been using some "parts direct" site but it takes like 2 months to get anything that they don't have in stock. Any place that can get obscure parts (circuit boards, switches, etc) direct from Makita quickly?
bdbecker
Iowa
Shoot... I didn't read the fine print on that one. Sorry for the confusion. While I wouldn't mind having a cordless circular saw, I don't really need one. If I bought the kit to get the nailer and batteries with the idea of selling the saw on Marketplace, I know I'd just end up keeping the darn thing when it showed up.
KnurledNut
n/a
They had one many years ago that was similar to Paslode and used a fuel cell:
KnurledNut
n/a
I ordered a switch from Quagmire Repair in PA. Fast service, good packaging, best price I could find, and factory sealed part arrived.
https://quagmirerepair.com/
KnurledNut
n/a
Picked up a 12v automotive charger. More so for disaster preparedness than regular use. Older style but not too concerned about individual cell balancing when the SHTF. :lol: Seems natural disasters and power outages aren’t getting any less lately.
dcg9381
Austin, TX
Does this count? It's more of a low-voltage shut off switch on Makita battery, but I'm setting it up to power Starlink (20-40 watts):
KnurledNut
n/a
My heated jacket/vest came with the original model ADP05. Instead of two USB ports, it has a single 2.1A USB and a 5.5mm jack that connects to the jacket. Its been used occasionally over several years for charging my phone remotely. Very handy and quality has lasted.
larry4406
Northern Virginia
I wore the bump head out on my XRU09 string trimmer. It never worked that well anyhow. Ordered a hopefully better replacement. Makita does not sell individual parts for the trimmer head, but it's a universal design with a M10x1.25 LH spindle thread. Careful ordering from Amazon. Lots of **** and misrepresented products.
Hey @engineer2 !
We finally wore out the bump head on our XRU09 as well. Parts list is clear as mud as it looks like it could have come with up to 5 different style trimmer heads.
Through process of elimination, I think we have the B-05119 trimmer head. We need a new spool Item 4 and spring Item 3. All the parts listings come up as no longer available although I did find some new full heads. The end of our spool looks like it just wore thru completely and then the spring ejected and that was that.
What did you end up buying and how do you go about locking up the shaft so the assembly can be replaced?
Here is picture of the new Makita B-05119 trimmer head
I found this Makita spool with a different part number but it has "B-05119" buried in the part number which happens to be the part number of the trimmer head I think I have....
A-89202 - SPOOL B-05119 - Makita Original Part​
No luck on the spring though......
Pictures of our worn trimmer head. I have cleaned out the spool and the bore is fully open to its tip
larry4406
Northern Virginia
Good info! I bought a Makita 197296-3 Bump & Feed Trimmer Head, M10 X 1.25 LH from Amazon and it was the exact replacement.
Thanks!
That model number head appears to be scarce has hen's teeth just like my believed model B-05119.
I will call Makita customer service this morning. Wish one could buy direct from Makita.
  • Like
Reactions: Voi
larry4406
Northern Virginia
Spoke with Makita customer service. Guy confirmed that the XRU09 trimmer has a M10x1.25LH thread.
He said that the original head was a 197296-3 like @engineer2 bought and not the B-05119 like I suspected.
Regardless, both of those heads are discontinued and individual parts no longer available.
The replacement head is 191R00-0 which claims to be an easy one to install new line. Align the triangle pointers, slip a measured length straight thru, find the middle of the string and make sure it’s centered in the head, then wind the knob.
Reviews on line are mixed. Found one at the orange box store for slightly less than $30.
Wife weed whacks, so I will patiently wait for her report.
Customer service guy said any head that has that thread form would work. Surprised he volunteered that.
Snapped-off
Indiana
The speed feeds are pretty nice. I might grab one for my trimmer.
IndyGarage
Indy
As I said earlier, I've been buying some non-Makita tools that use Makita batteries.
This week I got this SideKing 3.2 gallon backpack sprayer. Comes with a 2.5AH Makita style battery and charger for $75. I've had the Makita 2.5 gallon in my shopping cart for about a year, but it runs $175 and the reviews aren't that great.
I got this and used it for about 30 minutes the other day, and I just gotta say why did I wait so long??? I've been fighting with a pump sprayer for years - and this thing blows that out of the water - literally. I shot a full tank plus another half tank through it - easily, quickly - it sprayed great, it's not noisy it's got variable pressure. Other than the dorky sky blue color I love it.
SideKing sprayer
Steel_Rain
Not sure how this is on a National level, but two of my Home Depot's have clearance on Makita XGT Chainsaws and Leaf Blowers going on right now:
These both include battery/charger.
I'm very tempted by the chainsaw deal. Anyone own a XGT chainsaw? I have an old gas Homelite (maybe a 16"?) that's among my old OPE stuff and I'm looking to upgrade.
duneslider
Riverton, Utah
I bought one of these, it showed up in what appears to be a perfectly sealed package just like your picture but I can see through the plastic that it has been used. The bump is scratched up and there is grass all over it. Not sure if I open it up and try it or just send it back to amazon and try to get another one. Packaging has zero damage and looks factory sealed to me.
FTWingRiders
Central Ma
Unfortunately, in the past few months, we’ve also received obviously used/returns from Amazon. It seems the handlers are just allowed to return questionable returned items back into stock. I guess they hope someone with eventually keep it.
I’d return it, personally, of course someone else might end up with it!! lol.
larry4406
Northern Virginia
My wife reports that this trimmer head works great. She says she likes the easy feed method compared to the prior that needed to be taken apart and carefully wound on the cartridge.
Steel_Rain
Does anyone have the makita hydraulic impact XST01Z? I feel like I need it...or want it? Curious how much quieter it really is?
I have it and use it for some assembly work for my buddies stage side gig. It’s awesome. I always get questions from other people that help him when I’m using it because of the confined space you’re working in. That’s where these shine because of the reduced noise and overall tonal difference compared to other standard impacts. If your planning using an impact for a lot of enclosed assembly work, or work in a shop and just want something quieter and smoother, this is a great buy:
I also have the M12 surge as well:
It’s a good tool, but the Makita is better for my application. I don’t like the trigger feel, it’s louder and while it’s got a smaller profile, the balance isn’t as good as the Makita. The Milwaukee just doesn’t deliver the power the same way, it feels unrefined. My first reach for projects is always a Makita, but be prepared to be asked a lot of questions by the team red and team yellow squad, they are usually are curious about it.
FTWingRiders
Central Ma
I run both teal and red in my shop, but this is my go to.. Well balanced and a worthy addition. My hearing has also gotten more sensitive as I’ve gotten older to annoying whines and such.. like cordless vacs and other tools.. tinnitus *****.. the red ones bother me a lot more than the makitas..
