Flip socket storage
ericg
I have several flip style sockets for lug nut removal as well as the new Lisle flip sockets that have a hex on one end and a twist pattern on the other end. They all came in different plastic cases. Since the 1/2” broach for these is midway down the socket, there is no way to store these sockets on a conventional socket rail. I don't have access to a 3D printer for something custom. Do any of you know of a socket rail that can accept these style deep sockets or do you have any suggestions how to store them together?
WWheeler
Middleofnowhere USA
If you can't find a 3D print, and you have room tall enough to store them standing up, you could make your own hanson-style holders for them.
If you have access to a welder you could fabricate your own out of rod or bar stock or just cut the heads off some nails and weld up some Hansen-style trays yourself, sort of like this guy did to make his wrench racks using nails and sheet metal .,..
And don't know if this might work for you, but it does for me. I've been making Hansen-style holders, of sorts, out of wood. The black-stained wood holder with sockets on it is a test piece for the newer unfinished ones I've recently been working on. The wood stained one on the right is one of the first such sets I made back in the late 90s.
E
ericg
I have 15 different flip sockets, so to conserve space, I figured a rail would take up the least real estate vs a tray.
kbeefy
Harington, Eastern Washington
I keep my flip sockets and the tuner sockets in a plastic stand up tray that came with a different socket set. Sorta like a molded hansen tray but without the pegs.
I put a bit of magnet tape under it to keep them in place.
Mr_B
Reading
Make a vertical stand for them out of wood or metal.
I done one for some deep 1/2" drive impacts that live in the barn mounted on wall out of some offcut old hardwood and dowel .
Mock up the layout and drill holes for glueing dowel as locator pegs ( you can make the pegs long to work with you double ended sockets) .
I oiled my wood rail but they look nicer in a toolbox if lightly coat them with black satin spray can paint .
Cheap and quick to make .
E
ericg
Excellent idea @Mr_B . Easy to make and effective.
E
ericg
Thanks for all of the replies. You have shown me that have some options. I have no room left in the wide draw so I am trying to minimize the space taken up to put these sockets in another drawerIMG_0016.jpeg
AJHD
That's a lot flip sockets. Are they all for lug nuts? Those are the only flip sockets I own.
E
ericg
The Lisle set is designed for lug nuts but, in reality, could be used for any rounded nut since they are hex on one side and twist on the other. The others I have are hex only on both sides
larry4406
Northern Virginia
Well GJ did it again for me!
Never heard of a flip socket til now!
Had to google it - double ended socket with different size ends and the drive in the middle using an extension.
Slight derail - but why would one want these vs individual sockets?
Steve_P
The few I have include a half size for swollen lug nuts: a 21 and a 21.5mm on the same socket. Put it on an extension and you only need one socket that you can flip to 21.5 when you encounter that swollen nut.
larry4406
Northern Virginia
Thank you!
I saw the half sizes when I googled and was puzzled.
Ford with their "better idea" uses "chrome encapsulated" lug nuts making them a consumable item when they swell. Other OEM's do as well I understand.
Create ****** lug nuts to shave a penny and create a new tool.
All's swell that ends swell I guess.
Steve_P
Thank you!
This is nothing new. OE's have been using steel lug nuts with a stainless-steel cap for at least 55 years.
I have 3/8 and 5/16 guessing made for people who drive little TEC screws like HVAC guys.
Just added this to my wishlist, 1/4” and 5/16”, but without the sawtooth.
dscheidt
The original users of them were tire jockeys. You can get a single socket with the sizes you use all the time on it, and a couple sockets covers everything that comes in. if you use an impact with an extended anvil you don't even need to mess around with the extension. There were probably some other uses, where a pair of sockets covers much of the work, sames why 11-in-1 screwdrivers have 1/4 and 5/16 nutdrivers, because they're everywhere.
The other combinations, like the extractor or the 19/19.5 sort, serve the same sort of purpose. Take the single socket to the car, and when you run into bulging nuts, flip the socket over and use the +0.5mm side.
E
ericg
mine go on a Hansen tray like I see you have. What's the problem? I'm confused.
I was looking for something slim like a single rail that would not take up a lot of space in another drawer. The only thing Ernst makes in 1/2” for deep sockets is the double tray.
