Show your new tool arrivals
mikeinri
Made of American hickory but started in Taiwan and finished in China šŸ˜’.
I've been seeing more and more of that lately. But, Taiwan is now part of China, so that doesn't really surprise me.
Of course, until the past few years, I have to admit that I never really paid much attention to COO.
Mike
ecotec
I'm not sure what Klein is thinking but a couple months back I reached out to my wholesaler about some Modbox stuff. They informed me some of these items were only available via your typical retails store and not available thru a electrical wholesalers, in my case - Graybar. What kind off nonsense is that?.
Some exclusive products are probably a big part of the deal with Lowe’s.
I love Klein. I have been an electrician for 30 years.
At this point, I am making an effort to bottom feed their products out of garage/estate sales.
When you already have too much… it’s time to make an effort to find excess at bargain prices.
I will step up, and pay retail for ā€œneedsā€ā€¦ but it is stupid to pay retail for a fifth pair of D-2000 diagonals.
My price point is ā€œsnob on a budgetā€. I like to buy the cream puffs, cheaply, on the secondary market. I want the best of the best stuff for the least. Once you have more than enough, why not?
Pinne
I wanted to get a label maker and decided I'd rather not worry about batteries.
Ended up narrowing it down to a Dymo 1570 - an old school embossing style label maker.
This one is new to me, and likely older than I am. It's mostly metal and very burly.
It's a bit slower to use than an electronic label maker, but I think it's a worthwhile tradeoff.
It'll be nice to have drawers, hardware, and blowmolded cases labeled.
Squankum
Southeast
Got a trio of Vessel sets for Father's Day. I must have mentioned at some point I was wanting a set of Vessel screwdrivers, but I guess when he went to get me one he didn't know which ones I wanted, so he tried to cover all the bases. Vessel Megadora 8pc, Vessel Precision screwdriver set, and an Vessel Impact Ball Driver.
He did good!:rocker:
VESSEL MEGADORA Screwdriver Set 8pcs. 9008EVA.jpg Vessel 9836 Precision Replacement Screwdriver Bit Set.jpg Vessel Impact & Out Screwdriver with 7pcs bits and Pouch.jpg
And now that Impact Ball Driver set came in a case with some empty slots that now I'm going to have to figure out what to fill them with.
Is that ImpactOut a balldriver handle you hit with a hammer? I assume it doesn't ratchet, just does a little bit of impact driver twisting?
Callelle
Depew NY
The $50 Gedore ratchet and socket set from Zoro actually showed up today. These are my first Gedore tools, they're not bad, I like the knurling bands on the sockets, the satin finish isn't bad either. I don't understand what people see in the ratchet(s) though, I think it's 44 tooth and smooth, but very much just "an ratchet". I'm not disappointed about spending $50 on it though.20250620_170641.jpg
YesIHaveAHammer
I don't need them, but I'm a sucker for green. Do you have any other picks/hooks to visually compare with?
I have this Birzman double ended no-handle set. Completely different thing really and the shafts are ~1.5mm diameter, so not much of a comparison, and I don't have them with me right now.
See here for @Ohio Andy 's comparison photos of Tekton and PB Swiss picks. Tekton also has great photos on their website.
The closest thing I have is Tekton's 5/32" (4mm) 30deg mini pry bar, length 16.8cm. Their picks are the same length but 1/8" (3.2mm) shaft. The Stahlwille picks are 3.5mm shaft and 15.5cm long. This photo may be of help regarding the handles, length, and proportions.
1320
Arizona
What do you work on that you will use these enough to be worth while?
I'm not sure, I've wanted these for a long time because I thought they looked cool. I've found myself wanting ratcheting open end wrenches very few times for sure, pretty much only when a socket can't be used because of some obstruction.
I don't think Snap-on has made them in 20 or so years, so maybe they didn't sell very well.
If I have them for a while and find I haven't ever used them, I'll probably get rid of them.
WWheeler
Middleofnowhere USA
Yeah, that's exactly what it is. I haven't needed to use it yet, but I assume it's similar in respects to their impacta screwdrivers, not on level with an actual impact driver though.
moemc
We all (me) want to know if a 14 hex fits in the 13 surface drive!! My set didnt leave Louisville yet.
lotus_esprit
I have the exact same set, the 12mm was perfect for undoing the front powerhead bolt on Yamaha 90hp outboards.
Never used the rest of them!
Mr.zippy
Wyoming
I ordered the exact same set, same price. After about three weeks they pushed the delivery date back to September. Two days later canceled the order. Screw Zoro.
Meursault74
Southern California
First ever Park Tool purchase. I’ve been working a lot more on bikes and these became a need. Made in USA which is nice. I wish they had the sizes somewhere on the wrench so I’ll have to put some tape on each one with the size written in sharpie.
Went on the Snappy truck just for the small pliers and found some cool flexible diamond files. They should work well at work because I specifically machine hardened tool steel and only diamond files will work.
re spoke wrenches. The color is the size. Most keep that color coding. I have the black (used most by me) and the green for a set of mavic wheels that just had to use that ****** size. I also have the 3 sided park which has 0,1,2 sizes. I also have an 8 sized spoke wrench as well. Sometimes a little corrosion, and you go the next size up.
Squankum
Southeast
Just remembered that in the past week I got a Husky kneeling pad from Home Depot. 22" x 15" x 1.5". Best pad I've seen. Nice and comfy, and large enough that if you're kneeling on the floor while peering under a dash, you can move about and still have your knee(s) on the mat. $14.88.
Also, stopped by my local/only Ace Hardware today and grabbed a brush. I wanted a handbrush, so I removed this plastic socket when I got home.
The best kind of Lanka!
rharman
SoCal
A knock-off set of silicone trays (similar to Grypmat). Came with two magnetic trays and Amazon had a 10% coupon. Ended up right at $34. I've wanted these since Grypmat came out but don't NEED them so I held off. Came across these on Amazon and pulled the trigger. At a quick glance, they seem pretty decent. Time will tell.
moemc
Honestly, I would just try it again. They haven't adjusted the price on it. Even if Zoro shot me down on something like that.. I have to say that they have saved me tons of money the last year, I would have a hard time writing them off.
Prospecter
Maine
Labels are awesome. Just the labeling process helps me sort and classify stuff so I remember where things go, and put stuff away. And a memory aid when the above doesn't work!
CHI_Tool&Die
Chicago, IL
Yeah, it’s definitely on Gedore and not Zoro. Anything not in stock from Gedore takes a long, long time to import. KC Tool also has most of their Gedore stuff that is out of stock with a late July or August release.
mikeinri
I have a couple of those Husky kneeling pads. Simply amazing!
Mike
Markoos
South East England
Today’s stop on the truck. Ratchet is a warranty replacement for a vintage one. Shirts and bottle opener was baked into everything I’ve bought over the last 25 years.
Hi, which model Milwaukee M12 drill is pos and why? The reason I am asking is I have Snap-on 14,4v at work and wanted Milwaukee M12 for home use but can not decide.
M.
LXCam
How do they compare to the typical interlocking mats? I have been using one of these to save my knees:
Way better, they’re much thicker and softererer. I don’t have the husky but do keep a klein one in my truck, it’s the same thing just different colors.
My other favorite is this style. It’s really handy being able to adjust the height but they’ve got about the same cush as those interlocking pads
cody1325
Southwest Virginia
The Kobalt Tool Check wannabe.
A bit big for a compact kit, but most everything that's not on the chainsaw tool (which also gets used a lot for small engine type stuff) is pretty easy to get at and use. Figure I'll pick up a cheap pencil case (or a little metal Trusco/Toyo box) and add a couple smallish pairs of pliers and a Crescent wrench--making a small tool kit.
Honestly, though--even at full price, the 1/4 socket set with bits is a better value--it's also SAE AND Metric. For general repair and small engine work, it's better (honestly the 1/4 ratchet is one of my favorites) AND much more compact. This kit is aimed at bikes--and I didn't even learn how to ride one.
The Wiha ratchet is a couple bucks more--but both bits and ratchet are higher quality, and it comes in a sturdy metal tin. Or better yet, just wait until the actual Weras on which these are based go on sale. In fact, I'm getting a "Mini" (well the advent calendar) here pretty soon. Hmm, Kraftform salt and pepper shakers in the kitchen....
Tire levers will come in handy for when I need a non-marring pry tool. I also assume the mount for them has some specific purpose as a tool.
Bought a deck box to use as a package delivery box, and stopped back in Lowe's after the Sam's run to get letter/number stencils and paint for my mailing address/name.
Noticed they had a bunch of "freebies" on a table--keychains, can holders, (foldable--not the good hard plastic ones) frisbees, and something in a box. Picked it up, and the box read "Project Source Garden Snips". Model #55787 is written, but Lowe's apparently doesn't have a regular catalog version. Figured they'd be about $5-6 to buy.
Really good quality, surprisingly.
They have fine tips--meaning great for detail work. I mostly use these "shear" type pruners as general-purpose scissors.
MWEric
Wyoming, MN
M.
Standard M12. I drill and tap a lot of holes at work. I usually use the m12 for the smaller ones vs a Dewalt 20v for the bigger ones. The Milwaukee should not have a 1/2ā€ chuck (probably the same for the SO). It’s very underpowered above say 3/8ā€, also it seems with Milwaukee once it gets moderately warm it chews through batteries at a very fast pace. In my career of owning way too many platforms of tools, the Milwaukees are the only ones I’ve had thermal issues with.
I think the electronics in Milwaukee tools are too intrusive.
Mind you, I’m not a fan of any 12v system, but I have more Snap On so I figured I’d eliminate a charger with this one.
For my usage, a better idea for an 12v drill would have a smaller chuck and higher RPM, they don’t need to be pretend 18Vs.
tamaraw
Zoro has really good support in my experience. Just give them a call if you have an issue or question.
They stock and ship a lot of US brands direct but some things have to be imported or drop-shipped from vendors.
In my experience, Gedore, Stahlwille, or Facom take a while to ship, often a couple weeks or more. Koken is pretty quick drop shipping from palmac. Beta is reasonably quick drop shipping from the Beta USA importer or sometimes direct. I think my Wiha orders were pretty quick too. Stuff like Proto is lightening fast because it is nearly always stocked directly by Zoro.
neophyte
Pennsylvannia
Snap-On has made a bunch of different Ratcheting Open End Wrench designs over the decades judging by patents.
Someone on here said on of the designs was actually used as a torque wrench head on a torque wrench for one assembly task on one of the automotive lines in Detroit.
Personally, I have the Armstrong version, and have used it to remove bolts in tight spaces were I have to contort my hand just to get a wrench on the bolt.
Not having to remove and switch the position of the wrench can make this sort of job a bit easier.
mikeinri
Those floor mats win on surface area, but this Husky mat is a soft 1.5" thick!
I haven't tried working on the interlocking ones. I've walked / stood on them at daycare ages ago, don't recall them feeling especially soft (better for kids than falling on a hard floor, of course).
As mentioned by @Squankum, the Husky ones are definitely thicker, and very soft. And, the surface area is a little small. It would be nice if they had a hand-hold cutout like other manufacturers' versions, but there may be cons to that.
Mike
