Cleaned Up Vintage Craftsman Tool Cabinet
superautobacs
Vancouver, BC
After purchasing this locally for just $20 CAN, it was destined to get a good soak in the bath, to have it all cleaned up fresh. Before I purchased it, I had to ask the GJ community as to what the box's vintage might be--that thread is here:http://www.garagejournal.com/forum/showthread.php?t=34212
From that thread, Lauver suggested a broad range of in between 1945-1959; T56 Impala, suggested it was pre-war. I did some research on my own and I was able to verify the box in a 1949 CM catalog. That particular Craftsman logo appears to have been used from as early as 1930 and can also be seen in a 1954 catalog as well. So, both Lauver and T56 Impala are right--this one could've been produced before or post war.
Knowing the vintage of this box, sanding it down and repainting it was out of the question. All I ended up doing was Re&Re, a thorough cleaning, dent/frame/slide staightening, and a lube job.
Here's the cabinet before I started working on it. It actually looks cleaner in photo than it really is in person:
Here's a picture of it with guts taken out, after a vacuum job (there was a lot of stuff in there :wtf:):
Here are the two drawers and the tray after cleaning:
At some point in it's earlier lifetime, this top drawer slide had to be welded on for some reason or another. All slides were removed, straightened, cleaned, and coated with dry lube:
There was a small little surpise in the cabinet--a broken Snap-on socket tray:
After giving the frame a good bath, I had to ensure everything was 100% dry before reassembling. I left it in the sun for 15mins to let most of it evaporate, but I brought it in to let my hair dryer do the rest of the job. I went over all seams and rails and to finalize things, I used this can of dry lube. It does a good job of driving out any moisture out of the seams, as PTFE does not absorb moisture. Spraying the seams also leaves a coating to protect it from rusting as well:
So, after something like 8 hours, I was able to get it to look the way it is now; it surprised me how long this ended up taking. :shocking: But, I think the results speak for itself, most notably, the drawers that slide smoothly without any bind, and how the fit and finish is proper after all the pulling/straightening.
It's now resting in my small storage unit:
I found it really hard to clean the crinkle paint with years of caked on grease and oil; here it is, cleaned down to it's base.
fatfillup
Finksburg, Md
Great results, nice photo log, great attention to detail. Very cool old box!!:thumbup:
Now, what's up with the dualing vises on the corner of you bench:lol_hitti
dps
It's a great looking box. My question is, if a person was interested in doing so, could you not do a "frame off" type of restoration? Would that be considered to be ruining a box? I don't mean as far as financial value, I just mean would that be in poor taste, that a little piece of history had been treated badly?
If it was a car instead, there would definitely be an interest in seeing an unrestored original; a growing interest, I believe. On the other hand, a great car restoration is also appreciated and draws a crowd (and higher price, not that that is part of my question).
Just curious...
T56 Impala
Roswell GA
Nice work. I would have taken it too far if I had done it. What you did is perfect for that box. I would suggest you wipe down the inside, and the non-exposed areas with some oil. Just a light coat to keep the rust down.
Very nice work!!
sk farmer
nd
very nice, i just picked up an sk that eric 87 tipped me off to. very similar in size and layout with divided drawers. i was hoping for one a little older as mine is of the vintage of the green sk socket boxes. 60's or 70's maybe. i like mine but i love that old craftsman of yours!!!!!
Bolster
Mexifornia
I agree, you did just the right amount of restoration. Well, one more thing you could do without overdoing it is:
Put a little evap-o-rust in the tray and let it sit awhile. Then use a brass hand brush and brush off the rust. Then you're done.
Tool Pants
San Jose CA
Recently someone noticed that on the back of the Craftsman plate the name of the company that made the box was stamped. Here is a picture from thiat thread. Does your box also have this?
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
Just curious...
In this case (JMHO), only the inside top tray, even had enough rust to consider this. If anything was done, that is what could be restored, especially since the rest of the box is good enough to get an accurate color, from one of those computer matching machines.
Of course it has such light rust, if one could navel jelly it, then neutralize that, and get matching paint to overspray the bare metal area, that over restoring.
eric87
i just got one to mine is a 3 drawer. i will be putting fresh paint on it and going to be placing it ontop of my old roll around. by the way skfarmer i would like to see some pics of that sk box you picked up.
superautobacs
Vancouver, BC
Just curious...
I'm not really sure what you mean by "frame off" type of restoration. This is my first time restoring anything.... :confused:
Even though I may have been happy initially with a 'new' look from a complete repaint, I opted out in much favour of keeping the original character that suits the age of this cabinet.
:lol_hitti I just bought the blue vice over the weekend for $40 and it's just sitting there, waiting for it to be installed. The little orange Pony could go take a hike elsewhere. :D
superautobacs
Vancouver, BC
I'm glad you found one yourself! :)
Is that the original colour/paint? Also, is the chain stop on the top lid original?
eric87
no someone painted the one i got and did a really bad job. it used to be the same color as the one you have. they also added the chain stop.
dps
I was trying to compare it with a car. In this case, a person would remove all the hardware and badge and have the box parts bead blasted to bare metal, any dents, dings, or rust repaired before being repainted; in the original color (and texture) if that was the intent.
The handles would be cleaned up and re-plated or otherwise restored along with the lock and the label would be re-attached, or a new reproduction made if necessary (for something far gone and not findable otherwise).
So really, just like a car would be treated, but much simpler of course.
It seems like it could be a fun project for the right box.
superautobacs
Vancouver, BC
When I stripped it out, I looked intently for some kind of tag or production date, but none were to be found (if there was any?). I checked the back side of the name plate thinking, "how could I have missed it?". Result was: nothing there.
Have I had another identical box, only it were in worse shape, and having all the equipment and time to do it, it probably would be a fun project. :)
BTW, thanks for all the kind words everyone! :beer:
Mark in Indiana
Southern Indiana
This is my first tool box that I used as an industrial maintenance professional in the early 1980s. I've just retired and rattle-canned it. I also had it in a yard sale last weekend but (to my astonishment) there was no interest. I'm glad to keep it. Does anyone know what year it was manufactured?
Thanks in advance,
Mark in Indiana
pep
LOL. Next thing you know, you'd be worrying about having factory overspray, the box would be on Barrett-Jackson, and different websites would be arguing about whether it had the proper speedometer and holes in the firewall to be a COPO Craftsman toolbox.
You know what I think would look cool, would be some seriously bright colors. Maybe a teal body with purple drawers. I wonder if it's practical to upgrade the slides.
Mark in Indiana
Southern Indiana
My opinion: Formula 409 has been my choice for over 20 years. Worked for my Kennedy cabinets. I like that it leaves no residue.
Mark in Indiana
johnnybentwrench
Los Angeles
nice job, nicer tool box. It's nice to see people just clean em. I have a twin to yours:thumbup:
you ****! mine cost three times as yours, but I had to have it.
jobu77
Hey love your tool box maybe you or someone can help me figure out how old my Vintage Craftsman Tool box is.
jobu77
Top box is mid fifties or so, the bottom box logo indicates about 1960 or later.
(But why resurrect a 2 YO thread?)
Are you going to clean then up or repaint?
BigAl62
suburbs of Chicago
I have one of these boxes! I got it from my wife's grandfather's house when I helped clean it out after he passed away. I thought the tray was from another box because it doesn't look like a Craftsman one, I'm glad to see that it's the correct one. I need to get the lid hinge re-spot welded (I need to find someone to do it). Mine has a lot more rust too! I need to get it out of storage and start fixing it, this thread has inspired me! (Sorry to drag up a 2 year old thread)
onething
TEXAS
Thanks in advance,
Mark in Indiana
That looks like my first tool box, which I just rediscovered. It was given to me about the time I started driving in 1966.
View media item 14632I found it in a closet, and was searching here for how to clean it up.
superautobacs
Vancouver, BC
No problem. A good thread deserves a bump. ;) :p
I hope you got your box out and gave it a cleaning for the new year. :)
Brad54
Well, almost three years old, but I'll jump in too!
I have a Craftsman 3-drawer roll-away with storage compartment on the bottom. It was originally blue hammer-tone paint like yours, with the same emblem, but someone repainted it red. They actually did a pretty good job--masked everything really well, painted inside the lower compartment, too.
I'm turning mine into a welding cart.
Mine also had the name of the manufacturer stamped behind the Craftsman nameplate. Some sign company in Chicago made it. (Too lazy to go look right now).
I'll put it back hammertone blue when I'm done with the conversion to welding cart.
-Brad
