The Bicycle (Specialty) Tools Thread
Meursault74
Southern California
I looked over bunch of listing on ebay as the sellers of used HG50 9cassettes spread them out. I didn't see any with those odd looking teeth.
I found an image from on online vendor selling the same iteration of HG-50 that I have in my hands. They both have those odd teeth at the same location.
So, that's either a new feature or a bad day for 14T cogs at the Shimano plant ;) .
Grant Gunderson
Bellingham, WA
It’s 100% an updated feature. All of my highend cassettes have those slanted teeth.
shibertus
Do the tops of those two teeth at the top of the 14T cogs look the same to you on the two different cogs I posted.? They don't to me, which is why I posted.
Those two also are taller. If I look at the cassette from the side while it's mounted on the carrier it shipped in, I can see those 2 sticking up higher when I rotate it. None of the others do that. Teeth in question vs other in same cog.
It's normal. Here are similar looking teeth on my Ultegra 11 speed and XT 12 speed cassettes.
Meursault74
Southern California
Thanks. I see that now.
When Shimano road went to 10 speed many years ago. The price of 9 speed components dropped like a stone. I bought a whole bunch of parts on the cheap then and have been using them since. The prices were ridiculously cheap I couldn't resist. Now some of that NOS 9 speed stuff brings a lot of money on ebay if it says Dura Ace. I have a DA STI shifter kit in the box untouched. It's shocking how much that will sell for. But I'm keeping them to use. The ones on my bikes are still going. One had to be resurrected, but it's still going with a little tri-flow now and then.
This is the first "new" 9 speed component in a while, it's not high end either. I just wanted to try a little lower gear.
ericm
Southern Oregon
Yea mine are all Ultegra and Dura Ace and have had the slanted top teeth since they went 10sp. Maybe earlier, I can't remember.
A bike shop owner friend who did a lot of them said the best way to fix sticky Shimano 9sp shift units is to liberally spray CRC Powerlube in the holes. It works for mine. He said there's 30 or 40 tiny parts in there, unlike an SRAM shifter which has two or three. Maybe someone like @Grant Gunderson could work on that but my friend recommended I just hose it down with lube.
Grant Gunderson
Bellingham, WA
Shifter or Derailuer? I like to lube the pivot points on the derailleurs. I never bother with working on shifters. Done it twice and it’s futile as many use a clock spring and if you don’t wind it to the correct torque they are done. Both times I found broken / worn parts and of course there is zero repair parts available.
Unless you get excessive dirt / grit in there they tend to be greased for life from the factory.
99% of shifter issues is usually worn cable and housing. Back when I ran non-electric shifting I would always line the shift cables with Shimano cable grease. I’m almost certain it’s just white lithium rebranded. I’d replace my housing and cables 4-4 times as summer. It’s a slow degradation so you don’t usually feel they are getting bad till they are completely f’d.
I always buy the thin housing in bulk as it fits both internal / external and is way cheaper than buying the kits. Same with cables
ericm
Southern Oregon
Shifter. The Shimano 9sp road shifter internals were lubed with something that gummed up over time. Or that's what my bike shop owner friend thinks anyhow. Maybe it's when they sit, or maybe it's just age. Mine were fine until they got relegated to back up bike duty and then a year or two later they got sticky. A big shot of Powerlube would fix them for a year or so.
dscheidt
the 9spd stuff was well known for getting gummed up, and flushing with new lube was a very common practice. It generally made them work for a while.
308guru
I had some XT shifters from ~1998 or so on a MTB. After sitting for many years the grease inside had dried out and the pawl mechanism wouldn't work. Some Triflow spray and working them back and forth for a while freed them up. Worked like a charm for a couple more years as a kid trailer tow truck until I sold it.
Mecha
Volunteer State
You'd be amazed if you use electrical cleaner spray. Hose the mechanism down, let dry and follow up with Triflow or equivalent. It's fixed a lot of old rapidfire, brifters, and what not for me. Great trick.
LOW1
ontario
I bought this about 1980. Because of the pouch it comes in I assume it was intended to be carried on a bike but by today’s standards I think it would be considered very heavy. The tools are sturdy and seem well made.
BWWgarage
Very cool. Could weigh as much as some modern road bikes though 😀. What’s the below clamp
Mecha
Volunteer State
If you have quick clamps, the pistol grip kind, you can use those for third hand tools.
Don't forget fourth hand tools too.
duneslider
Riverton, Utah
I have one of those 4th hands and it works great but I am very glad I haven't had to use it in a lot of years. I honestly do not miss cable actuated brakes.
duneslider
Riverton, Utah
Hydraulic brake hose repair. Just curious if anyone has run across a way to repair (temporary) a hydraulic brake hose?
I took a bit of a digger at a bike park yesterday and my rear brake hose received a tear. Before now, I haven't ever carried brake hose in my tool kit. I do have stuff to bleed brakes but not a whole hose. As I sat there not riding I thought it would be cool if I could have cut out the inch of bad hose and rejoined it and gave it a bleed and then got back on the lifts. Its internally routed and the routing is sort of a pain and I am not certian how fun it would have been to try and replace it in the parking lot but I did also think I could have just run the hose external and zip tied it up, that would have been fairly easy as well. A little splice kit would have been cool if such a thing existed.
Odd-job
A splice kit would be pretty cool. Shouldn't be hard with the barbs and a coupling.
Never had to do a brake bleed in the parking lot, but I guess folks do it in the Autozone parking lots all of the time.
Would some plastic or rubber hose protector done any good? Guessing it got nicked near the rear caliper if internally routed?
slowtwitch73
Hellgate
If you're going to futz with barbs and compression beads, may as well just bring along a full length of hose and replace the whole thing leaving it a bit long.. zip tie it externally, when you get home, run it internally and shorten to correct length.
duneslider
Riverton, Utah
Best I can tell is the handle bars over rotated and some how split the hose between the lever and the frame. I haven't seen that happen before but thats what it was. I think the easiest route would be just running a hose from lever to caliper and zip tie it up. I could have done that fairly quick.
Gebirgekind
Montana
Yeah, if you're at the bike park and can keep an extra hose in your car, replacing the whole line is best. But Ti Cycles also makes this coupler which could be a great trail fix (but you'd still have to carry fluid).
Gebirgekind
Montana
We're starting to see more quick-connects too on gravel bikes with internally routed forks and others. Here's a great dry-break version that doesn't require rebleeding.
duneslider
Riverton, Utah
This still might be worth having in my tool box, thanks for the link.
duneslider
Riverton, Utah
This is really cool, not sure I need anything like this but good to know it exists! Thanks for sharing.
BWWgarage
I’m struggling with what your carry on trail to make this work? This kit, fluid, cup thing for brake lever? Seems limping back without brake and a full brake line replacement in parking lot is way to go?
duneslider
Riverton, Utah
Yeah, I wouldn't have this in on the trail, this would be a parking lot fix. If I am just at a local trail I don't take much of anything but if I spent money to ride the lifts I am motivated to fix the bike in the parking lot to get back on the mountain, same with at races, I want to make every effort to get riders back on course if possible.
I'm extremely lazy at the local trails though and rarely even carry stuff to fix a flat, guess I have been spoiled with tubeless and been lucky.
Meursault74
Southern California
Thanks for sharing. Too bad this doesn't seem to work too well with the wax emulsion lubes as per the FAQs. Except for the Silca stuff.
Yes I read that. I use White Lightning, it specifically says no go. I figured as much as soon as I saw the device.
The little WL bottle I use to apply gets clogged up at times, so not surprising it's not going to work with this device.
Seems like it would be OK for oil types. Don't know if I'd shell out $40 if I did use oil based lube.
Odd-job
Hey my name is Fred and I don't believe in there being a useless tool! :)
I guess I can live with my permanent puddle of squirt underneath my bike stand.
HannibalLecter
Don't tell me you are a dentist as well lol. It's not exactly useless, it's that it's too expensive while providing hardly any benefit. As for the squirt pool I feel you. However the mess mostly occurs when backpedaling, after the application
YesIHaveAHammer
Wow $40 for a 💯 useless tool. Holding any line bottle upside down and rotating the chai does the exact same thing.
This places the lubricant only on the rollers, which is fairly tedious to do by hand.
That method is beneficial for not having excess lubricant on the outside surfaces of the chain to attract contamination, and less waste.
There are arguments about the necessity and value of the tool, but it's not useless.
bonneyman
Desert SW
My old bike guy told me that Shimano had an epoxy-like compound in their shifter grease, that would harden over time and cause a malfunction. It was supposed to be timed to cause failure after the warranty period, but so many shifters came back under warranty that they changed the grease.
Old time third hand brake tool. Had one and my brother was always trying to get me to give it to him.
I recall on the older 8-9 speed cassettes their was a groove or valley cut into the outside edge of the cogs. Meant to grab the chain pins (as they stuck out ever so slightly more than the chain plates) so as to facilitate quicker, more secure shifting on the index systems. Perhaps this profile change accomplishes the same result more reliably.
slowtwitch73
Hellgate
Sorry, but very useless. Worse than useless.
Saves waste? Like how much? Not as much as the effing plastic and packaging for that thing.
Take a look at the inner face of a 1x chain and tell me it doesn't need lube.
Ditto the outer face if there's more than one chainring.
Get a squeeze bottle, place on top of chain, squeeze, turn cranks backwards.. let sit a bit, squeeze rag over chain, turn cranks backwards, done.
Meursault74
Southern California
Wow $40 for a 💯 useless tool. Holding any lube bottle upside down and rotating the chain does the exact same thing. Laughing my *** off that their are apparently idiots that will spend money on this.
Couldn't agree more. Luckily many dumb cyclist Freds that will be potential clients lol
here's a review of it from RBR. which is were I saw it.
I wouldn't get one for that price. Maybe if I used oil and that device was cheaper I'd give it a try. But I'm good pedaling backwards and wiping with a rag.
But yeah $40 seems ridiculous to me, but not more so than a $5 cup of coffee(which I don't understand, but yet is pervasive).
Wow, I didn't think posting that info on a new bike tool would inspire such a debate.
YesIHaveAHammer
The device makes the manufacturers' recommended application method easier, so it's not useless. That's what the makers of the best lab tested lubricants say to do.
I don't know, maybe half. This was the secondary reason.
They will get enough through migration when you turn the cranks backwards.
This will result in more excess lubricant on the outside surfaces (including the inner faces) of the chain, attracting contamination.
