Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
I have a general idea of how the welding cart is going to get done but some of it is still a figure out as built.
All the pieces cut ground and ready to be tacked together. This is of course the bottom side.
EDIT: I should add, these are just the base pieces, not all the pieces for the entire cart. I did cut the vertical uprights as I wasn't sure if I was going to have enough tube, even after buying an entire 24' stick.
N
NUTTSGT
Since this was my day off and the coolest day in the last 2 weeks, I decided to get some work on the welding cart.
I started clamping down y bottom frame...I realized this morning that I need more clamps for the welding table.
As I was finishing it up, I got toned in for hazmat spill and that took up about 3 hours of my day.
Once I finished up the bottom piece I set up and welded the vertical y cross pieces.
Then I had to call it a day and went in the house, leaving it for some garage time tomorrow.
N
NUTTSGT
Sat around trying to decide about a bottle mount and how to do it.
This is the plan for the top shelf.
Went in the house, ate lunch, and then spent a couple of hours mowing the yard. A quick project in the house and off to work a 15 hour shift at work. It butts up to my shift so no more progress till Friday... I hope I can work on it Friday...
N
NUTTSGT
That’s why now we have Central AC in the house….I put AC in the garage like a few have done around here. Gonna insulate and finish off with wallboard. Tired of moving it in and out.80215F64-54D0-4EBF-B779-7D8A01220455.jpeg
I've got a portable AC unit but it's not big enough for the garage, especially with the way it's cut up with 3 different sections.
If it was one big open area of the same sq footage, I think it'd be quite different.
That is part of the reason I don't want to spend the money on a mini split for here.
N
NUTTSGT
I'm at this point of how/ where to run the MC cable to keep it safe.. no plasma cutter arc hitting it, keeping grinding debris off it or catching a welding clamp on it.
I believe what I am going to do is weld a piece of sq tube under the rails for the plasma table. I'll run the MC cable through it as a precaution.
Been at work last two days and going to be there, at least the next two days so I need to get the yard mowed, cutting garage time short ...
Bob Heine
Boca Raton, Florida
The reel originally came with a 25' hose, I'm replacing it with a 35 footer.
Eric, I'm a Flexzilla fan boy as well. I replaced the 50' 3/8" hose that came with the reel with a 50' 1/2" Flexzilla hose and the 25' 3/8" hose on the smaller reel with a 25' 1/2" Flexzilla hose as well. I do have to be a little more careful letting the hose retract but it fits just fine. The bigger hose keeps the air tools and HVLP guns supplied with all the air they need.
50-foot Hose Reel Original Hose.jpg 50-foot Hose Reel Flexzilla Hose.jpg 25-foot Hose Reel Flexzilla Hose.jpg
N
NUTTSGT
Second welding table outlet completed. As mentioned above, I used a piece of sq tubing and welded it underneath the table. Then fed the MC through it and made the connections. Checked all four outlets with a meter and good to go, with the exception of needing some paint.
Once the outlet was completed, I continued to make some progress on the cart. . . still slow progress as I figure out more as I go. I welded the middle shelf in place then added the back piece. You can't see them here but I welded on the front swivel casters to set the final cart height.
Welding the back plate in and front casters needed done so I could set the location of the rear casters. You can see here, I'm trying to mock up their location.
N
NUTTSGT
These are the top mount plates for the rear casters. This is just one of the few times I've used this drill press that I bought last year. I'm really starting to like this thing. To the right of the table, you can see the new oil can ( Thanks to HJE '25) sitting in a HF can holder. . . . works pretty good as a repurpose.
N
NUTTSGT
I was going to hear, bend and weld a piece of steel over the edge of the bottle mount. Then I had an idea.... auto door trim.
A quick search lon O'Reilly's website and a trip to the store, I have these.
Then I moved on to the wheel tubs. I wanted to weld them on the inside as it will half the cart weight and the all of the bottle weight.
N
NUTTSGT
I wanted some black oxide eye bolts that were for sale at TSC.... online, in stock last night and this morning...some must have changed or updated as I was trying to find them in store.
Out of stock and no longer available at most stores....argh. But some close enough at another place. I picked up some chain and other items for the bottle retention.
Mocked up.
