rktinc
Midwest/USA
Any better pics of the mural in the bar area? Looks cool from here.
You guys both need build threads, if not for our entertainment, it will serve a a catalog for your projects.
Thanks, My 18 yo daughter spent a couple months on scafolding hand painting it on new sheetrock for me. I think it turned out great.
micromind
Fernley, Nevada, about 30 miles east of Reno.
Great examples of why you never want to wear socks and open-toed footwear while welding or brazing. (y)
Also, make sure that you pantlegs cover the top of your boots. Red hot slag dripping down into your boots is rather painful.......
Same with shirts and pants.....don't tuck your shirt in......
Beerhippie
Far NE Oregon
When lying on your back welding overhead, a leather bolero, apron and chaps are the thing. Slag goes right through most clothing when dropped straight onto it. Slag in the crotch is really distracting. That happened wearing Carhart double-face bibs and a welding jacket.
WildBill
PNW
I pulled the rotted power steering **** off my 1967 cougar and replaced it with a cool doohookie that lets you leave everything else alone and convert to manual. Don't even need an alignment after as it doesn't mess with tie rods or anything. I also put in a roller bearing idler arm at the same time to make it easier to steer. I have a bunch of other bearing suspension parts (spring perch/control arms, etc.) going in that will also help and make it handle/steer better. I had about 4" of play in the steering before but don't have any now.
Everything in the pic was replaced by the two lower right parts. Mostly by the one little conversion part. It works on most old fords and is super easy to install, pretty neat. I drove the car last fall with the power steering disconnected and it wasn't horrible, only tough when sitting still. Should be much easier now without all the junk and not fighting the rock hard idler arm rubber, I stood on the old one and couldn't get it to rotate.
Wrench97
Southeastern Pa
Saturday #1 Grandson and I replaced the fawcet in our ensuite. It had been in place about 30 ears, so corrosion pretty bad. GS wanted to do as much of the work as possible but the fitting nuts needing 3/4 crowfoot he couldn't handle as really tight spot. He also couldn't break loose and back off the big plastic wing nuts that held everything in place, so out to the garage to find a piece of 1 1/4 schd 40 6063 pipe to make a 4 slot socket - the he used to finally break nuts free.
Sunday PM #1 Son-in-law brought over Big Kid's B6 wagon with stripped drain plug (found when vaccum oil extractor failed) and new Amazon pan (obviously a TSI regular problem). Anyone who works on later VWAG stuff knows they use a wickedly strong sealant/adhesive instead of many gaskets, and a sheet metal part will be destroyed when removing. Once I got it off (hard to do without prying against the aluminum gasket surface of the block) I grabbed a can of CRC Gasket Kleen and holy **** did that ever work! After leaving it 10 minutes or so to work its magic I was able to scrape most of the stuff off with a plastic scraper and a quick polish with scotchbrite finished it nicely. Sadly some well meaning idiot somewhere in the past (probably the one who overtightened the drain plug) seeing so leakage just started tightening everything in sight and managed to strip the M6 screw just above the drain plug. No room for a thread insert, so off today to find an M7 plug tap and screw.
Best part of day was letting our 8YO do 90% of changeover (car had been parked since spring) with a bit of help from his 6YO bro. Our 14YO has been able to do this stuff since their age, so fantastic to see 2 more garage kids coming along.
Sharpen a putty knife and use the sharp edge to cut the sealant, you can even tap the end with a small hammer to get it started and work it around the flange.
JEFFREYWisconsin
Save that pump, kinda hard to find if it is original to the car, someone will buy it.
WildBill
PNW
It is the original but I have about 8 of them. I bought a warehouse of Mustang/Cougar parts from a guy who dismantled them and sold parts on ebay for about 35 years. He kept only the best parts to sell, this one is not as nice as the others I have. Not sure if anyone would want it.
Beerhippie
Far NE Oregon
As those of who grew up with "Armstrong" power steering knew, you don't steer unless the rig is moving. Bigger rigs in particular are impossible unless under way. Takes some planning on a three-point (or greater) turn on a steep trail.
JEFFREYWisconsin
As those of who grew up with "Armstrong" power steering, you don't steer unless the rig is moving. Bigger rigs in particular are impossible unless under way. Takes some planning on a three-point (or greater) turn on a steep trail.
I have a 67 cougar with weak PS and I have 70s on it, that's not exactly a treat turning from a stop.
Snapped-off
Indiana
Cracked my Wilton C2.
Wilton is going to warranty the vise base plate. Pretty cool.
I had some wheel bearing noise coming from the front of the Audi. Bought 4 wheel bearings, and figured I'd knock out the fronts, and I'll do the rear a little later.
Well, starting on the passenger side, I stripped one of the triple square bolts holding the bearing to the knuckle. Spent almost 2 hours screwing with it last night. I really didn't want to damage the knuckle. We prevailed.
It was late last night and I was literally pouring a solid stream of sweat from the humidity, so I called it quits after getting the passenger side replaced. I came home today and got started on the driver side. Took about 45 minutes. 😂
Astro Pneumatic screw extractor pictured.
jblnut
In the Middle of MN
The 4-wheeler needed a servicing and a few little things done to it so I brought it into the shop and stuck it up on the service table.
First up was to rebuilt the carb so I took it off and went through it. I big deal. A bunch of crusty stuff in there but it looks new now.
I noticed a torn cv boot on a front axle so I decided to investigate.
For **** sake I should have known better than to let myself do something like this. I don’t think I’m gonna be able to stop until it’s all fixed and new again. Needs a new axle as the boot must have been torn long enough the innards are slopped out and junk.
The ball joints are also shot. May as well do both sides right away.
Hey look a wheel bearing that’s rusty and sloppy. This thing is gonna be half new when I get done. I bought it new in 2004 so if I only have to go through things every 20yrs I’ll be pretty happy.
cody1325
Southwest Virginia
or nylon mesh type Nike shoes
And I assume Muck boots are flammable as well....
Recently put my Dunlop Purofort steel toe boots out to pasture (they now only get used in mud/manure) because the soles were getting heavily worn, and bought some decent slip-on work boots. I need to get new laces and insoles in my soft-toe Rockies that I rarely ever wear. Got some welding to do in a month or two with a buddy.
PWC Repair
Arkansas
So, y'all are saying that this:
is sub-optimal welding clothing?
Go home!
Oh Hell,.......I just tig'd some aluminum the other day in basically the same outfit!!
Today I fought brakes on my '04 Nissan Xterra tow pig. The fronts started screeching about 100 miles ago. The fronts went pretty well. I had a frozen slide pin on one caliper I had to use lube and the impact to remove. Cleaned, emery cloth, grease, all good. Then on the rear just lots of filth to clean up and the springs that hold the shoes to the backing plates.............DAMN....those suckers are way to stout, or the pins could have been a bit longer! Then one drum had attached itself to the center hub. Some lube, heat, big hammer, finally got it moving a bit. Then back and forth some more got it off. After all that I clamped a round of sheet metal to a rusted out weld on the exhaust to shut it up. Then finished today's project with a tire rotatation since the wheels were off anyway.
nadogail
Coronado, CA
A few days ago, I cut some parts for a different style planting box than I have been selling. Today i assembled those parts into a prototype box, they all fit together nicely.
Now that the dimensions have been firmed up I will build a fixture to hold the parts in position while they are being glued and nailed together.
Made a holder for my shop copy of Machinery’s Handbook on the 3D priniter.
Many machinist's boxes have a drawer specific for MHB.
I guess steel toed shoes are out of fashion...
KIMG2824.JPGSwapped out the factory antenna for an aftermarket shorty.
I did this on my Wrangler and the reception sucked, how is yours?
Not surprised at all.
I switched to a lighter socket holder for a USB storage card that I can set to an unused station, and get what I want to listen to without annoying announcers or commercials...
jblnut
In the Middle of MN
Meh I wear flops a lot on the farm. When I'm mixing feed or doing stuff where foot safety is important I'll toss the work boots on but usually I'm in flops in the summer. I get so dang hot so anything (within reason) that I can do in flops and shorts I do. I know I can drop something on my toes and that's bad and blah blah blah but I'm not one to rush though things and make mistakes and have yet to come close to an "Oh **** I should be more careful" in the last 15yrs.
Working on the wheeler in the shop was right there on the edge of "should I or shouldn't I" and shouldn't I won out this time :dunno:
