Any better pics of the mural in the bar area? Looks cool from here.
You guys both need build threads, if not for our entertainment, it will serve a a catalog for your projects.
Great examples of why you never want to wear socks and open-toed footwear while welding or brazing.Did some out of position (on my back under a car) welding this weekend.
Thanks, My 18 yo daughter spent a couple months on scafolding hand painting it on new sheetrock for me. I think it turned out great.
or nylon mesh type Nike shoesGreat examples of why you never want to wear socks and open-toed footwear while welding or brazing.![]()
When lying on your back welding overhead, a leather bolero, apron and chaps are the thing. Slag goes right through most clothing when dropped straight onto it. Slag in the crotch is really distracting. That happened wearing Carhart double-face bibs and a welding jacket.Also, make sure that you pantlegs cover the top of your boots. Red hot slag dripping down into your boots is rather painful.......
Same with shirts and pants.....don't tuck your shirt in......
Sharpen a putty knife and use the sharp edge to cut the sealant, you can even tap the end with a small hammer to get it started and work it around the flange.Saturday #1 Grandson and I replaced the fawcet in our ensuite. It had been in place about 30 ears, so corrosion pretty bad. GS wanted to do as much of the work as possible but the fitting nuts needing 3/4 crowfoot he couldn't handle as really tight spot. He also couldn't break loose and back off the big plastic wing nuts that held everything in place, so out to the garage to find a piece of 1 1/4 schd 40 6063 pipe to make a 4 slot socket - the he used to finally break nuts free.
Sunday PM #1 Son-in-law brought over Big Kid's B6 wagon with stripped drain plug (found when vaccum oil extractor failed) and new Amazon pan (obviously a TSI regular problem). Anyone who works on later VWAG stuff knows they use a wickedly strong sealant/adhesive instead of many gaskets, and a sheet metal part will be destroyed when removing. Once I got it off (hard to do without prying against the aluminum gasket surface of the block) I grabbed a can of CRC Gasket Kleen and holy **** did that ever work! After leaving it 10 minutes or so to work its magic I was able to scrape most of the stuff off with a plastic scraper and a quick polish with scotchbrite finished it nicely. Sadly some well meaning idiot somewhere in the past (probably the one who overtightened the drain plug) seeing so leakage just started tightening everything in sight and managed to strip the M6 screw just above the drain plug. No room for a thread insert, so off today to find an M7 plug tap and screw.
Best part of day was letting our 8YO do 90% of changeover (car had been parked since spring) with a bit of help from his 6YO bro. Our 14YO has been able to do this stuff since their age, so fantastic to see 2 more garage kids coming along.
Save that pump, kinda hard to find if it is original to the car, someone will buy it.I pulled the rotted power steering **** off my 1967 cougar and replaced it with a cool doohookie that lets you leave everything else alone and convert to manual. Don't even need an alignment after as it doesn't mess with tie rods or anything. I also put in a roller bearing idler arm at the same time to make it easier to steer. I have a bunch of other bearing suspension parts (spring perch/control arms, etc.) going in that will also help and make it handle/steer better. I had about 4" of play in the steering before but don't have any now.
Everything in the pic was replaced by the two lower right parts. Mostly by the one little conversion part. It works on most old fords and is super easy to install, pretty neat. I drove the car last fall with the power steering disconnected and it wasn't horrible, only tough when sitting still. Should be much easier now without all the junk and not fighting the rock hard idler arm rubber, I stood on the old one and couldn't get it to rotate.
It is the original but I have about 8 of them. I bought a warehouse of Mustang/Cougar parts from a guy who dismantled them and sold parts on ebay for about 35 years. He kept only the best parts to sell, this one is not as nice as the others I have. Not sure if anyone would want it.Save that pump, kinda hard to find if it is original to the car, someone will buy it.
As those of who grew up with "Armstrong" power steering knew, you don't steer unless the rig is moving. Bigger rigs in particular are impossible unless under way. Takes some planning on a three-point (or greater) turn on a steep trail.I pulled the rotted power steering **** off my 1967 cougar and replaced it with a cool doohookie that lets you leave everything else alone and convert to manual. Don't even need an alignment after as it doesn't mess with tie rods or anything. I also put in a roller bearing idler arm at the same time to make it easier to steer. I have a bunch of other bearing suspension parts (spring perch/control arms, etc.) going in that will also help and make it handle/steer better. I had about 4" of play in the steering before but don't have any now.
I have a 67 cougar with weak PS and I have 70s on it, that's not exactly a treat turning from a stop.As those of who grew up with "Armstrong" power steering, you don't steer unless the rig is moving. Bigger rigs in particular are impossible unless under way. Takes some planning on a three-point (or greater) turn on a steep trail.
Wilton is going to warranty the vise base plate. Pretty cool.Cracked my Wilton C2.
Oh Hell,.......I just tig'd some aluminum the other day in basically the same outfit!!
That girl has talents!
Made a holder for my shop copy of Machinery’s Handbook on the 3D priniter.
The ball joints are also shot. May as well do both sides right away.
The only time I have exposed feet in the shop is when I make a potty run from the pool. No way I'm oopsidentally losing my grip on heavy metal and hurtin my tootsies.I guess steel toed shoes are out of fashion...
Pfft, those are considered safety shoes in Florida.I guess steel toed shoes are out of fashion...
I did this on my Wrangler and the reception sucked, how is yours?
LOL - most of my garage shirt sleeves look like that.
and many third world countries...Pfft, those are considered safety shoes in Florida.![]()
Meh I wear flops a lot on the farm. When I'm mixing feed or doing stuff where foot safety is important I'll toss the work boots on but usually I'm in flops in the summer. I get so dang hot so anything (within reason) that I can do in flops and shorts I do. I know I can drop something on my toes and that's bad and blah blah blah but I'm not one to rush though things and make mistakes and have yet to come close to an "Oh **** I should be more careful" in the last 15yrs.I guess steel toed shoes are out of fashion...
