I hope my van wasn't used for anything nefarious while the shop had it, lol:
When I shop Crapazon, I let my items sit there for a week or more before I hit the button. Just in case my first thought was a bad one.
You should probably change your login name. How many jeffreys are there in Wisconsin?Maybe I should start promoting the idea next year and see if more people will take part!
Imagine it goes viral, gets huge and Bezos just comes looking for me! Awesome!
The knock on the door at 3AM... two very large men in shiny suits: "Mr. Bezos says you deserve a nice little place in the country... get in the car."
Most of the stuff I buy are needs, and some wants, but there's a minor percentage that are bad choices at second blush, or something that after further consideration, I didn't really need or want.How much stuff do you end up buying vs. deleting off the cart?
Pretty much.Kinda like dating, right?![]()
What is your weapon of choice for sanding these? Belt sander or hand sanding?
Nice to see old school, corded, tools that the “influencers” tell you are a hindrance to good work.Front and back, this 4x24 belt, with 36, 80, 120 grit belts
The sides, this 3x21 Ryobi with 40 and 80 grit belts.
This Ryobi is the smoothest running belt sander I’ve ever used. Amazing difference.
Then all over with 100 grit on a palm sander
I have a rubber block for hand sanding, but that’s only getting used for small touchups and filler. No f’in way I’m stripping doors by hand.
Almost got one of those off Craigslist for 50 bucks, I was a little too slow though.After a shower and dinner, assembled my new Vevor air jack.
Finding the leak is more than half the job, at least for me.@niget2002 Thanks for the printing tips, I'll give it a try.
Recently had the bug in my avatar out for a spin. Noticed drips in the driveway and leaking oil when parked. Fired it up drove into the shop and saw no leaks. Raised it up cleaned a bit. Decided to fire it up and watch. Found it passenger side valve cover gasket dripping. So new project. Located the package of gaskets. Will get put on shortly.
An interesting topic. When I was setting up shop, corded tools were generally more powerful, less expensive, and there were more options. I wired the house and shop with plenty of receptacles, inside and out, so power was not really an obstacle. Helping my children set up is sort of like starting over. Battery power is better, with more options, and the price is more similar when I figure in the cost of additional wiring and extension cords. So they are almost exclusively battery based tools. No cords or hoses, but heavier. I have to move forward with the times.Nice to see old school, corded, tools that the “influencers” tell you are a hindrance to good work.
Use what you have and let ability and experience get the job done
The house we are redoing has a 30x40 garage/shop that has over 100 outlets... the former owner was a woodworker and he thought of every place imagineable to put power.An interesting topic. When I was setting up shop, corded tools were generally more powerful, less expensive, and there were more options. I wired the house and shop with plenty of receptacles, inside and out, so power was not really an obstacle. Helping my children set up is sort of like starting over. Battery power is better, with more options, and the price is more similar when I figure in the cost of additional wiring and extension cords. So they are almost exclusively battery based tools. No cords or hoses, but heavier. I have to move forward with the times.
Old VW, marking its territory.@niget2002 Thanks for the printing tips, I'll give it a try.
Navigation light/ horn wired and installed, the lights and horn even work. The piece is NOS, has a small nick on it, but It works and they are no longer manufactured. Spliced the new one into the plug from the old one to keep from cutting and splicing into the main harness. I found a newer version, requires a larger hole. Cutting a larger hole is something I wanted to avoid.One screw will snap off flush on initial torque, the plug will strip and one clamp will fall apart on use...![]()
Not kink shaming you Kay, but we didn't need to know that.lolPerformed the biannual reaming of the poop pipes.
What kink? I could pay some goofer several hundred dollars twice a year, or do it myself. These modern water saver fixtures just don't use enough water to fully sweep the sewer pipes clean, so I get buildup. The pressure snake is saving me a fortune. I could buy one every 6 months and still be hundreds ahead every year.Not kink shaming you Kay, but we didn't need to know that.lol
As long as its for the house Kay, As long as its for the house...What kink? I could pay some goofer several hundred dollars twice a year, or do it myself. These modern water saver fixtures just don't use enough water to fully sweep the sewer pipes clean, so I get buildup. The pressure snake is saving me a fortune. I could buy one every 6 months and still be hundreds ahead every year.
My humor is wasted here.What kink? I could pay some goofer several hundred dollars twice a year, or do it myself. These modern water saver fixtures just don't use enough water to fully sweep the sewer pipes clean, so I get buildup. The pressure snake is saving me a fortune. I could buy one every 6 months and still be hundreds ahead every year.
At least you understand me.lolAs long as its for the house Kay, As long as its for the house...![]()
Oh, you were trying to be funny. OK. Hahaha.My humor is wasted here.
I try.You know how to make it sting Kay.lol
