Anyone know what this screwdriver was made for?
nz44tool
New Britain CT
I just picked this up at a junk store. It's a nicely-made tool, looks like 1920s or '30s to me.
But I don't recognize the tip.
Anyone out there know what it's for?
I'm betting someone does.
N
nz44tool
New Britain CT
It's a clutch head driver. There two types of clutch head one used by GM in the 50's and this one. I forget the designations though.
Huh. I know the "butterfly" clutch heads; I think I even have one or two. But I've never seen one like this, and can't (so far) find a picture of one on the interweb.
Please let me know if you come up with a pic or a catalog listing (I'm looking too.)
Well now - I think you nailed it; this does appear to be the "A"-style clutch head driver.
I wonder who made it - there's no mark. It could be Stanley or PS & W, perhaps.
Thanks again!
Beerhippie
Far NE Oregon
Thanks again!
I see Clutch B (butterfly) all the time--even new sets occasionally. I've seen a sum total of one A, not including yours. I've seen a lot of B fasteners in older cabinetry, but never seen a single A fastener anywhere.
Oregon Dave
Looks like it could be an electrician tool to me; fits those annoying screws on household outlets & switches; today's drivers have a #2Sq for the center post - in the early 1900's who knows- performs much better than a standard flat-tip.
Also the wings in your last image appear a little light-weight for clutch-head; and notice center post extends below the wings on your image. If you have a switch or outlet handy; try it for fit.
Beerhippie
Far NE Oregon
Just nope. Clutch A, not ECX.
Beerhippie
Far NE Oregon
By way of observation the O.P's last/right hand image shows the center post extended beyond the wings; all the the clutch head drivers I have so far used have them flush???
There are two types of "clutch head". This is the other--clutch A. Very seldom (never in my experience) seen.
N
nz44tool
New Britain CT
I'm persuaded that it is a type A clutch head screwdriver, but I gotta say, none of the images of type A drivers that I've seen so far look exactly like the screwdriver I have.
As Beerhippie says, the "wings" are thinner and the center post sticks out more.
Anyone have any thoughts as to who might have made it? The shank is very stout - .375"; the handle is very nicely shaped.
Beerhippie
Far NE Oregon
IIRC, the extended center post was the earliest type--but no idea of the date.
Oregon Dave
Just for grins, take it with you next time to Home Depot/Lowes etc. and try it out on an outlet terminal screw head.
Your driver is Model T/Model A era and coincides with the advent of the clutch head fasteners on automotive assembly lines; simplified insertion, reduce cam-out, speeds up the process - but they initially used a 'bat-wing' transverse profile for strength; a later "clutch A. Very seldom (never in my experience) seen." is also in the mix. It would require a clutch head fastener with a center recess so the wings would seat for a proper purchase; those are as yet unseen by me.
In the same era they were building and wiring skyscrapers and tract homes; electrical suppliers were using terminal hardware with a shallow flat-tip slot; phillips head and morphadite slot/phillips head terminal screws so which ever screwdriver pulled out might work. Of course some typical ingenuous American would invent your driver; speeds up the process.
EXC is relatively new; last 15 years so, but uses a square center post; I and most electricians I know just use a #1 or #2 mostly, square bit on a Klein hex bit driver, if we can't use a power driver. DeWalt & Milwaukee use flush tips; WIHA uses an extended tip.
Until a "clutch A. Very seldom (never in my experience) seen." surfaces; with your extended round tip, light weight parallel wings - still leaning to electrical/electrician use - your fit test would help at lot also - at this point am stuck on definitely maybe's.
Beerhippie
Far NE Oregon
"so whichever driver is pulled out will BARELY work." FIFY.
Gods, I hate electrical fasteners... I finally broke down and bought some ECX bits... only to find that they have four sizes, of which I have three. Some equipment I work on uses all four sizes.
Electricians also seem to be the only trade ever to use #1 square.
N
nz44tool
New Britain CT
Beerhippie, I see why you thought it would fit electrical devices, but...nope. Way too big.
Oregon Dave
I whole heartedly agree about electrical fasteners; and they charge such LOW wages and use such cumbersome hardware; how about the POC #4 screw head!!!
I enquired in another of your post if your Far NE Oregon was anywhere near Troy where I grew up?
Beerhippie
Far NE Oregon
Sorry, thought I replied. Troy is about thirty-five miles from here, tucked down in the Grande Rhonde gorge. One of my co-workers outfits out of Troy.
Unfortunately, not much of a town--more of a fishing/boating tourist center. I've built/remodeled some homes around there and it has the worst bar/tavern selection of any town in the county.
It's afar enough from Enteprise and other Wallowa county towns that most folks from there do their shopping in Clarkston/Lewiston.
N
nz44tool
New Britain CT
Is that and outlet terminal? If not please try one.
By outlet, do you mean a receptacle? As in, the thing on the wall you plug an appliance into? Wanna make sure we're talking about the same thing. The device in the pic is a wall toggle switch.
I'm not an electrician, but being in the sound system business for many years I built many electrical assemblies - cables, distro panels, breakouts, etc. The receptacles I have (all are 110V 20A) use the same size screw.
Oregon Dave
If the screw on your wall toggle switch is the same size as the terminal screws on your 110V 20A receptacle made in the USA; then yes it did NOT pass the fit test.
As Beerhippie mention the EXC system comes in multiple sizes; for different sized fasteners as you know - but EXC came out 80-90 years after your driver.
Black painted wooden handled screwdrivers were made in the millions for early auto tool kits; few if any were maker marked. A source to try might be a local antique car club; Model A Club of America etc. You might get a match on the ferrule or handle design/shape; our local club tool expert has led us to believe the screwdrivers, unlike the pliers & other tools, cannot be maker identified - but hey, technology is technology, something might turn up
N
nz44tool
New Britain CT
Gotta admit, I'd never heard of the EXC system until now.:censored:
Beerhippie
Far NE Oregon
And I wish to hell I never had.
The different sizes of the ECX **** are hard to distinguish by eye--sure, I can easily tell a #0 from a #3, but a #2 from a #3 or a #0 from a #1? And confusingly, some of the higher-torque screws--like the terminals of a 30A breaker--use some of the smaller sizes on BIG screws.
Mintgrun
Kingston, Wa.
The tip looks like it might fit carb jets. The nub in the middle would keep it centered.
Googling for images of similar tips based on that description wasn't fruitful, but that may just mean they weren't plentiful.
N
nz44tool
New Britain CT
Ah, that's "progress" for ya! Makes everything ever-more-complicated...
Oregon Dave
Earlier I posted; just use square tip bits, cheaper, easier to use and distinguish. Been down the ECX rabbit hole myself; lastly with WIHA - better, but square tips for now.
Also, for others viewing, the bit holder cannot easily release a bit when working around 'hot' circuits; I began with an old Irwin that had a set screw holding - good for working over high speed moving parts, when you have to, also.
Beerhippie
Far NE Oregon
I find there's so little material left around the square drive part that they're very easy to strip out. Hence buying all the ECX bits. I now have a dedicated multi-bit driver for nothing but. Not insulated, but I never work hot.
Oregon Dave
WERA will help your frustration; but hurt your wallet.
Beerhippie
Far NE Oregon
This style of tool would be better:
That's for removing/installing the check valve of a Coleman appliance pump, but it has a screw to keep the screwdriver part firmly in the fitting. I know I've seen similar for threaded inserts.
