I'm persuaded that it is a type A clutch head screwdriver, but I gotta say, none of the images of type A drivers that I've seen so far look exactly like the screwdriver I have.
As Beerhippie says, the "wings" are thinner and the center post sticks out more.
Anyone have any thoughts as to who might have made it? The shank is very stout - .375"; the handle is very nicely shaped.
Just for grins, take it with you next time to Home Depot/Lowes etc. and try it out on an outlet terminal screw head.
Your driver is Model T/Model A era and coincides with the advent of the clutch head fasteners on automotive assembly lines; simplified insertion, reduce cam-out, speeds up the process - but they initially used a 'bat-wing' transverse profile for strength; a later "clutch A. Very seldom (never in my experience) seen." is also in the mix. It would require a clutch head fastener with a center recess so the wings would seat for a proper purchase; those are as yet unseen by me.
In the same era they were building and wiring skyscrapers and tract homes; electrical suppliers were using terminal hardware with a shallow flat-tip slot; phillips head and morphadite slot/phillips head terminal screws so which ever screwdriver pulled out might work. Of course some typical ingenuous American would invent your driver; speeds up the process.
EXC is relatively new; last 15 years so, but uses a square center post; I and most electricians I know just use a #1 or #2 mostly, square bit on a Klein hex bit driver, if we can't use a power driver. DeWalt & Milwaukee use flush tips; WIHA uses an extended tip.
Until a "clutch A. Very seldom (never in my experience) seen." surfaces; with your extended round tip, light weight parallel wings - still leaning to electrical/electrician use - your fit test would help at lot also - at this point am stuck on definitely maybe's.
