Ohio Andy
Promise if I hold one I treat it like a fidget spinner.... That said, I purchased many of those given away you a few
I’m wearing mine now…!
I have seen this set and it looks interesting. My biggest concern is that it looks like the bits have a 5/32" hex shank (3.96875mm). I own the iFixit kit so I have drivers that will work with it. I think that the new Tekton bits are also 4mm.I had to go up to O'Reilly's the other day to pick up a part. The store manager saw me come in and ran out to his car to grab his new acquisition to show me.
These guys did their homework. This set-up looked pretty slick:
Fanttik E1 MAX Precision Electric Screwdriver
Upgrade your DIY projects with the E1 MAX Precision Electric Screwdriver from Fanttik. Shop now for 50 magnetic bits and effortless jobs.fanttik.com
The company offers a variety of different "bit kits".
The bits in this particular kit are much longer than those in the little "Tekton" kit I bought a few weeks ago for a buddy.
Awaiting response from company regarding COO.
edit 12:53 PDT:
found a copy of the owners manual for their "NEX S2 PRO" model - COO appears to be China (PRC)
(image below)
Wiha makes two of these. The 75803 and the 75802. I would not recommend the 75803, it is not magnetic and only has a wire inside providing the bit holding and it is pretty weak. I think the 75802 is magnetic.I have seen this set and it looks interesting. My biggest concern is that it looks like the bits have a 5/32" hex shank (3.96875mm). I own the iFixit kit so I have drivers that will work with it. I think that the new Tekton bits are also 4mm.
This might allow me to use those bits in a standard 1/4" driver:
Amazon.com: Sys 4 Micro Bit Adapter 4mm to 1/4" 25mm : Tools & Home Improvement
Amazon.com: Sys 4 Micro Bit Adapter 4mm to 1/4" 25mm : Tools & Home Improvementwww.amazon.com
If you get one, be sure to post how you like it!
^ I would not argue that point with you, but considering that these tools are designed to turn teeny-tiny screws, how much torque are we talking about here?Most of the good quality 4mm bits seem to be of European or Japanese origin.
I think there’s a bit more to it than transmission of torque.^ I would not argue that point with you, but considering that these tools are designed to turn teeny-tiny screws, how much torque are we talking about here?
I would think one would reach that proverbial "point of diminishing returns" on something like this.
Nobody is going to be cranking down head bolts with 4mm bits.
The thing about that "Fanttik" set-up above that impressed me was the design of the case - it's a revolving, magnetic affair that holds the bits securely, but doesn't require the user to pry them out. The bits are longer as well - an issue we just ran into here when we discovered the "Tekton" bit wouldn't reach down into the hole to engage the screw.
Kind of hard to find bad bits these days, but it is possible I guess. S2 and pretty much all alloys are available world wide.
And I'm pretty picky about screwdrivers - screwdrivers that do not fit properly permanently damage soft brass alloy carburetor jets.
^ That's a situation I very rarely encounter here working on rusty lawnmowers in the Pacific Northwest.I’ve spent too much time removing, or trying to remove, screws that have been unnecessarily mullered!
The Tekton bits are listed as 28mm long with 11.6mm in the holder and 16.4mm protruding.The thing about that "Fanttik" set-up above that impressed me was the design of the case - it's a revolving, magnetic affair that holds the bits securely, but doesn't require the user to pry them out. The bits are longer as well - an issue we just ran into here when we discovered the "Tekton" bit wouldn't reach down into the hole to engage the screw.
Oh... no idea! They make a number of different sets.How many of the Fanttik bits are longer? it looks to me like most are the shorter bits. Please let me know if you know!
We're gettin' out in the weeds here again on this.... I'm watching what various manufacturers are offering, and the different approaches they're taking in respect to "usability" in the field, thinking "worst-case scenario" stuff: on your back, in the dark, in the rain, on a gravel driveway. And that is why that "Fanttik" unit impressed me - ease of finding/removing/replacing bits in the holder. Whether or not the bits or the driver are worth a damn I can't even speculate.
While the "Tekton" kit (post #293) allows the user to remove a strip of one type of bit, what happens when that widget slips out of his hands and falls four feet to the floor? Do the bits stay in? Or do they end up scattered all over the floor? (This was an issue raised by member @bwringer previously, if I'm not mistaken.)
I own one of those "Vessel" bit kits in a plastic holder (below), and I'm always a bit apprehensive when pulling it out because I don't know if that plastic holder will shatter if it hits the garage floor. And I find it kind of a pain in the *** to get the bits and the driver widget out of the holder.
Anybody dropped one of these things?
Cost | What | URL |
$19.00 | Titan Tools 11323 1/4-Inch Drive x 4-Inch 90-Tooth Swivel Head Micro Ratcheting Bit Driver. Buy | |
$30.00 | SK11 SRD-290 Bit Replaceable Swivel Ratchet Screwdriver 90 Thread. Buy | SK11 SRD-290 Bit Replaceable Swivel Ratchet Screwdriver 90 Thread - Amazon.comSK11 SRD-290 Bit Replaceable Swivel Ratchet Screwdriver 90 Thread - Amazon.com
www.amazon.com
$17.00 | VIM Tools HBR3 Double Ended 1/4" Hex Bit Ratchet. Skip | Amazon.com: VIM Tools HBR3 Double Ended 1/4" Hex Bit Ratchet : Tools & Home ImprovementBuy VIM Tools HBR3 Double Ended 1/4" Hex Bit Ratchet: Socket Wrenches - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
$120.00 | VIM Tools VHC77 '77-Piece' Half Cut Stubby Bit Set, 3.17-ukgja-985. Buy | Amazon.com: VIM Tools VHC77 '77-Piece' Half Cut Stubby Bit Set, 3.17-ukgja-985 : Tools & Home ImprovementBuy VIM Tools VHC77 '77-Piece' Half Cut Stubby Bit Set, 3.17-ukgja-985: Screwdriver Bit Sets - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
$15.00 | CRAFTSMAN Screwdriver Set, Ratcheting Offset, Multi-Bit, 10 Piece (CMHT68008). Skip | CRAFTSMAN Screwdriver Set, Ratcheting Offset, Multi-Bit, 10 Piece (CMHT68008) - Amazon.comCRAFTSMAN Screwdriver Set, Ratcheting Offset, Multi-Bit, 10 Piece (CMHT68008) - Amazon.com
www.amazon.com
$52.00 | GEARWRENCH 45 Pc. 1/4" Drive 6 Pt. Standard Slim Head Mechanics Tool Set, Metric - 81032. Skip | |
$40.00 | ICON RXFT-35 Locking Flex-Head Ratchet and Bit Set, 35-Piece. BUY. | |
$25.00 | Craftsman CMMT12004LZ 1/4-in Drive Gimbal Palm Ratchet. I like it. | |
$3.30 | Pittsburgh 92630 right angle screwdriver |
Ratcheting Right Angle Multi-Bit Screwdriver Set, 8 PieceAmazing deals on this 8Pc Right Angle Screwdriver Set at Harbor Freight. Quality tools & low prices.
$10.00 | Tekton 2888 mini ratchet and bit set | |
$5.00 | Tekton SHA05402 ¼" bit socket. Buy |
1/4 Inch Drive x 1/4 Inch Magnetic Hex Bit Holder Socket | TEKTON1/4 inch drive to 1/4 inch chrome magnetic hex bit holder socket. Adapts any 1/4 inch hex shank bit to 3/8 inch drive ratchets, drivers, and other drive tools. SHA05402.
$6.00 | Tekton SHA15402 3/8" bit socket. Buy |
3/8 Inch Drive x 1/4 Inch Magnetic Hex Bit Holder Socket | TEKTON3/8 inch drive to 1/4 inch chrome magnetic hex bit holder socket. Adapts any 1/4 inch hex shank bit to 3/8 inch drive ratchets, drivers, and other drive tools. SHA15402.
$12.00 | Vessel IBHBM150P1 Impact Ball Torsion Bit Holder | VESSEL Impact-Ball Torsion Bit Holder 1PC H1/4"X150 (6") IBHBM150P1 - Amazon.comVESSEL Impact-Ball Torsion Bit Holder 1PC H1/4"X150 (6") IBHBM150P1 - Amazon.com
www.amazon.com
$12.00 | DEWALT DWPVTHLD Pivoting Bit Tip Holder with Ring. Only if you need it. | DEWALT DWPVTHLD Pivoting Bit Tip Holder with Ring, 2 Pack - Tools Products - Amazon.comDEWALT DWPVTHLD Pivoting Bit Tip Holder with Ring, 2 Pack - Tools Products - Amazon.com
www.amazon.com
$10.00 | DWALT DWA3HLDFT Bit Holder, 3-in-1, Impact Ready. BUY BUY BUY | |
$8.00 | RYOBI 3PC IMPACT BIT HOLDER SET (AR2032). Works. | RYOBI 3PC IMPACT BIT HOLDER SETRYOBI Impact Rated Bit Holders are built to withstand the high torque and demand that comes with the use of an impact driver. These bit holders come in ...
$85.00 | Ryobi PSBID01 ONE+ HP 18V Brushless Cordless Compact 1/4 in. Hex Impact Driver. I like it. | |
$180.00 | Milwaukee 2953-20 M18 FUEL™ 1/4" Hex Impact Driver. I like it. | |
$345.00 | Festool CXS 10.8V (old version). My primary user. | Cordless Drill CXS 12 2,5-Plus |
I know this thread is about bit ratchets, but Chapman bits do work with the double-ended bit tools like Milwaukee and Wiha. They also store in the handle well.Unless specifically stated, a bit holder cannot hold a Chapman bit and a Chapman holder cannot hold a bit not made by Chapman. Assume a Chapman bit will NOT work unless it says specifically that a Chapman bit will work. If I remember without checking my notes, I think that means like 1 worked with them (that was not Chapman). I talk about Chapman bits earlier in this thread, and I really like their stuff.
Thanks, I've been thinking about doing a post about the bits since I have a rather interesting collection of them....Great work and information, @Ohio Andy
This thread has grown to be one of the best in General Tool Discussions for useful info on bit ratchets
I LOVE these stubby little Titan bit ratchets. I have purchased two of the one you list above and 8 of the type without the hex in the base. The problem is that I keep giving them away!I posted this in the NTA thread recently but figured I'd show it here too since it hasn't been mentioned.
The stubby Titan roto now comes in a version with a magnetic hex in the handle.
It's also more of a shiny chrome than the satin chrome found on the regular stubby.
I never got the first stubby version.I LOVE these stubby little Titan bit ratchets. I have purchased two of the one you list above and 8 of the type without the hex in the base. The problem is that I keep giving them away!
I have some reservations about the box, which didn't appear to me as all that durable. (see below) You will find on the OReillys page for that item under "Questions and Answers" my question regarding the hinge and the box, which is as of yet unanswered.
O'Reilly's Auto Parts said:A: Helo and thank you for your question. The hinge mechanism on the Power Torque Screwdrive Bits Set - GM4325 is designed as a plastic blow-molded hinge. For further product details you may contact Tech. Service# 800-585-9691.
follow-up post on that GM4325 Power Torque 32-piece bit and ratchet set (post #314):
Has anyone who owns one of those little ICON kits dropped the thing when it's fully loaded and closed?
(I know the Kobalt kit will bounce, but I only dropped it from waist height.)
In a real-world scenario, I can see a guy easily pushing that little thing off the edge of a fender and onto the concrete floor 40 inches below. Question is: will the box withstand the impact? Or shatter in a million pieces, scattering bits, ratchets, and tiny screws all over the driveway/lawn/shop/under the car?I will try the bounce test for you today.
If the case in which the kit is contained cannot withstand the impact from being dropped from waist height, one may as well just have all those little pieces in a cereal bowl. Is not the entire point of the thing to have a compact portable kit? One intended to be used away from a safe, cozy "shop" environment?
I think some of the manufacturers are simply not doing their homework.
