Red Devil Hand Tools
misterbill
Thanks, @Private Lugnutz . FWIW, I suspect that they were my grandfather's pliers before they were my dads - which would dovetail with the timeline. My dad was not one to buy a tool unless he had a need for it (a recessive farmer gene I suspect) and I don't remember them around the house when I was growing up. My grandfather would likely have bought them in the 30s before WWII I suspect.
LesserSon
PA USA
I’m in process of unfreezing/derusting these linesmans and casually thought I’d check if a No1150 had been previously posted. Guess not. So far, not clear how they are different from No1050. Maybe the original finish, which, whatever it was, is long gone now.
LesserSon
PA USA
Turned out pretty good.
Comparing to two other linemans, now I’m not sure if the heavy top pair is 1950, 1650, or 1050. IMG_5397.jpeg
Kinda leaning toward 1650, but not sure what the early advertising means by “double cutter.”
Nice! I wasn't aware you had so many variants.
Just to add to the comparative superset, I am re-posting the pair I found last year bearing no model number but the initials "S.C." near the "U.S.A." marking, which I strongly suspect signifies "Signal Corps", based on ads I found, example linked here. EDIT: One of the things you will immediately notice is no knurling and a forging seam showing on the handles. I believe these may have had insulated grips, which they did offer special order (as the No. 4950).
The No. 1650 was consistently described as having "Button's cutters" in addition to the side-cutters in catalogs.
MisterEd
Florida
Smith & Hemenway “Red Devil” 926 Slip Joint Plier with Bent Nose
LesserSon
PA USA
Wow, nice! I really like where the PO (E.W.SWOPE?) stamped their name on the side of the handle. So much more sophisticated than three ugly grinder marks.
CCaillet
Louisiana
Found a 2nd Red Devil tool while cleaning up.
Top is Klein, then 2 Red Devils.
Bottom is unmarked.
CCaillet
Louisiana
Bottom is unmarked.
LesserSon
PA USA
Now I’m thinking the name might be E.W.SQUIRE. Like the Buttons pattern pliers despite surface erosion. Those unmarked longnose have unusual heavy terminations to the grips, which may suggest a manufacturer.
Snaparxon
Closer to Idaho
My Red Devil 725 daily users just for the fact that the maker cared so much about USA that they put it on the handle. Tools were so much more works of art back then.IMG_0521.JPGIMG_0518.JPGIMG_0519.JPGIMG_0520.JPG
There's been a lot of talk on the Crescent thread as well as the Mega Pliers thread about a grip pattern described as "barrel stave shaped" in Crescent catalogs of the late 1920's. Although I have not been able to find them in a Smith & Hemenway catalog, they were clearly being made by Smith & Hemenway before the acquisition by Crescent. We have No. 950 side-cutting slip joint pliers in the Lugzsonian that @Leviton first posted a few years ago upthread linked here.
LesserSon
PA USA
Raining here today, so I rephotographed my pliers.
888 5-1/2” curved longnose
IMG_0041.heic
IMG_0042.heic
20 6-1/2” squarenose
IMG_0039.heic
IMG_0040.heic
650 7” flatnose
IMG_0037.heic
IMG_0038.heic
1050 5-1/2” linemens
IMG_0033.heic
IMG_0034.heic
5-1/2” linemens
IMG_0035.heic
IMG_0036.heic
LesserSon
PA USA
444 7-1/2” giant grip slipjoints
IMG_0015.heic
IMG_0016.heic
IMG_0013.heic
IMG_0014.heic
LesserSon
PA USA
This JAK-NIFE was gunked-up enough, I didn’t realize it was missing a screw until I went to put it back together. I probably have something that’ll work, but it could take a while to find. I am happy to have found a Red Devil blade in it, though!
LesserSon
PA USA
Added these 6” pincers to my collection Sunday, but have not spotted them in catalog. They do not resemble Utica, S&H, nor Crescent “carpenters pincers” which typically include a screwdriver and claw on the ends of the handles and often a Buttons (notch-type) wire cutter in the jaws. These jaws are also quite circular compared to oval-jawed catalog illustrations. The worst is they don’t have a model number.
