I’m looking to buy a different air compressor; I have an older 25gal horizontal craftsman. I want to get a 30gal vertical. Any recommendations would be great, (and the ones to avoid). I have a limited budget so the less expensive the better. Thanks.
I can run a 240V circuit if needed, I would like to be able to use a HVLP paint gun, and air tools.In order to really give a recommendation, we need to know how much air you need, and whether or not you have 240 volt power available.
Without knowing any of that, I think the Harbor Freight Fortress 26 gallon 175 PSI is a great option. Its compact, quiet, runs on 120 volts, and makes enough air for most home shop uses short of blasting and running high consumption air tools (grinders, sanders, etc).
That said, I sold my little benchtop blast cabinet to a friend who has one and he blasts with it regularly using a TP Tools gun and a small tip/jet combo. It sits right next to his blast cabinet and he's able to blast without it driving him batty.
26 Gallon, 175 PSI Ultra Quiet Oil-Free Vertical Shop/Auto Air Compressor https://share.google/ZELDHEDOdIxOZIpwv
Alternate link. https://www.harborfreight.com/26-ga...6768637354&adsetid=186768637354&product=57336
Sorry, but there's still too much ambiguity here. When you say air tools, do you mean an impact wrench, a die grinder, or a DA sander? Those tools have massively different air requirements.I can run a 240V circuit if needed, I would like to be able to use a HVLP paint gun, and air tools.
I bought the Ingersoll Rand Garage Mate compressor a year ago. Been very happy with it, and it is ultra quiet. It's a 20 gallon tank so it does most everything I ask it to do. One thing to note is that it is very top heavy (on the vertical model). I wouldn't get this if you need to roll it around much as it weighs over 200lbs.
I hooked a 1/2" Goodyear reel hose above it, and a nice quality regulator/water separator. Not a bad setup for an at home shop.
I bought this air compressor several years ago at Northern Tool and i am more than happy with it:
The most IMPORTANT specification for an air compressor is VOLUME of air the pump can supply (CFM sometimes called SCFM) at your most commonly used pressure.
High pressure and large tank are good, but if you are using a tool that takes a lot of air (sander, sand blaster, die grinder, etc.), the tank will quickly run low. Running multiple nail guns can empty a tank quickly !
that's misleading.Unless you NEED high pressure, there is no need for a dual stage pump. A single stage is fine for MOST pneumatic tools. You get more cfm with single stage to boot!
What Makes Two-Stage Compressors Different?
On the outside, a single-stage and a two-stage compressor may look similar. But under the hood, the differences are game-changing.
This design produces more air output per horsepower, lower energy costs, and longer machine life.
- Single-Stage: Air is compressed in one step, which puts heavy strain on bearings and can increase energy usage.
- Two-Stage: Air is compressed in two steps with interstage cooling between, reducing stress on components and boosting efficiency.
More CFM per Horsepower
The NXHE series delivers significantly more airflow at the same horsepower rating.
Example: A 250 HP single-stage compressor typically delivers 1,026 CFM @ 125 PSI. The FS Curtis NX185 (two-stage, 250 HP) delivers 1,217 CFM @ 125 PSI — an increase of 191 CFM, equal to adding a 50 HP machine without the extra cost or footprint.
Higher Energy Efficiency
Efficiency isn’t just about airflow — it’s about how much power you consume to get it. This is where the money is saved!
In simple terms: You get more air while pulling less power.
- Lower package power draw: Two-stage compressors deliver more air while consuming less kW.
- Better specific power: FS-Curtis NXHE units achieve industry-leading numbers (as low as 15.69 kW/100 CFM).
- Superior isentropic efficiency: Higher ratings mean less wasted energy and reduced operating costs.
Some shop run their air tools at 125+ psi ! Yes, they wear out quicker, but they are cheap to rebuild !$/cfm at 90psi is really the spec to look at. If the tank is larger, you have more reserve.
I would love to see a picture of that !... I modified the outlet lines from the pumps to go through a copper tubing array (about 12.5m) which is almost 100% effective at removing all the moisture which these compressors produce. This array fits between the pumps and the tank, so the air is cooled and dry before it goes into the tank.
If you want accurate air pressure, you need a surge tank near where the tool is being used with the regulator AFTER the surge tank.Some places set their regulators high because they're compensating for loss on small or long hose.
I don't know where your logic comes from, but if you have 2 cylinders pumping and one set is the same size VS one that is smaller, you get less cfm. You can argue all you want, volume is volume.that's misleading.
while you might be able to BUY a single stage compressor labelled to do more work with the "same" 5HP motor, in fact, you are not getting more CFM of air per operational dollar (energy input) with single stage over a two stage unit. e.g. all that's been done is given you a lower maximum PSI and a higher RPM compressor.
Single-Stage vs. Two-Stage Air Compressors: What's Right for Your Operation? - FS-Compression - Industrial Air Compressors
Air compressors are the backbone of many industrial operations, but not all compressors are built the same. One of the most common decisions plants face is whether to use a single-stage or a two-stage air compressor. At first glance, the two designs may look similar — but their performance...fs-compression.com
for example, at work our 10HP VFD compressor is rated for 175PSI. at 90PSI and full speed, it's only inputting 6HP of electricity into the motor.
often you can take advantage of this yourself if you check the RPM range for a given compressor, and then run it faster/slower to meet your needs. since this is GJ, you want to buy the largest two stage compressor money can buy and spin it at the minimum allowable RPM for maximum minimum-noise. best done on a unit with an oil pump (splash lube is for noobs!)
Exactly. And that other user was quoting marketing material. Not exactly a lab result. A two stage screw compressor is the same efficiency up to 70 psi.I don't know where your logic comes from, but if you have 2 cylinders pumping and one set is the same size VS one that is smaller, you get less cfm. You can argue all you want, volume is volume.
Yes if you are looking at HIGH pressure, it might be easier, but AS I SAID, if you don't need high pressure, single stage is BETTER.
And that's why bodyshops all had 2-stage compressors for multiple employees until screw compressors became more common?There's no debate. They're different tools for different purposes.
I can agree with that.2 stage also costs more. Unless you need it for specific use in most home shop type applications there's no problem with single stage.
Having said that, I never wish I had more air when running DA's, die grinders or when a friend helps out and we have multiple DA's running at once.
I run 1/2" hose and oversize fittings for the same reason. Improved the zoot on my big impact gun for sure.High volume tools DO benefit from 3/8" (10mm?) ID hoses from the surge tank to the tool.
The problem with water separators is, where does the water go ? Usually there is a sealed chamber at a low point that captures the condensate. This must be drained regularly. Depending on it size, you may have to drain it a couple of ties a day !
Screws for body shops are definitely single stage and def shitboxes. They wont last as long as a good reciprocating compressor with the air filter changed regularly. Most body shops have 2 stage compressors because thats what the more expensive brands made to make 175 pounds. There are 175 pound screw machines out there but I hate running them. The oil filters usually leak around the crimp. The unload solenoid valve takes a hit. The inlet takes a hit.And that's why bodyshops all had 2-stage compressors for multiple employees until screw compressors became more common?
I have a similar champion I used for 20yrs. I am upgrading to an r30 pump as I purchased a blast cabinet.
the logic comes from the wasted swept area of the low pressure piston acting like a spring.I don't know where your logic comes from, but if you have 2 cylinders pumping and one set is the same size VS one that is smaller, you get less cfm. You can argue all you want, volume is volume.
if we assume a linear relationship, the 2 stage compressor is still 8% more efficient at 50PSI than the single stage unit.Rules of thumb:
- A good single-stage compressor, per true HP input, will deliver about 4 true CFM at 100 psig. It is not uncommon to see this more like 3 CFM per HP, when using compressors from a retail store.
- A two-stage compressor is more efficient, typically by 15 percent, versus a single-stage compressor. You might see 4 to 5 CFM per HP at 100 psi, instead of 3 or 4 CFM.
- Formulas (see references below) for the theoretical power to compress one CFM are:
- HP = 0.015*P*(R0.29-1) [single-stage compressor, per CFM]
- HP = 0.030*P*(R0.145-1) [two-stage compressor, per CFM]
where:- R = the ratio of the compressed air absolute pressure to the ambient air pressure. R is about 8 for 100 psig compressed air versus 14.7 psia atmospheric pressure, and
- P = atmospheric pressure in psi (that is, 14.7 psi)
These formulas reduce to a theoretical 5.5 CFM/HP (single stage) or 6.4 CFM/HP (two-stage), but do not include various inefficiences such as mechanical losses, the effects of heat and moisture in the input air, and the build-quality and condition of the equipment. These are the theoretical limits of what can be achieved with ideal machinery. The imperfections of practical compressors and operating conditions typically lose about 1/3 of this theoretical performance. This is the basis of my rule of thumb that in practice you can count on about only 3 or 4 CFM per HP from shop air compressors. My rule agrees with the advice of quality compressor manufacturers like Quicy, who honestly report that their "well-designed compressors produce approximately 4 CFM at 100 PSIG per unit of horsepower."
The number of pistons doesn't seem relevant, just volume of the low stage. The first stage of a 2 stage compressor never sees full tank pressure, so you lose effective displacement much faster on a single stage unit.
I don't see how 2 stage would ever be less efficient, unless you're using a piston compressor without a restriction and the friction of the additional piston(s) is additional loss. I'm sure the curves cross somewhere. might be at the zero point.
disagree vehemently. the more you compress in a single event the LESS efficient it is.Simply put, compressing air takes work. Compressing air more, takes more work. In a less than perfectly efficient system, converting electrical to mechanical energy results in some losses (heat, sound, etc.) so any time you do more work, there are greater losses.
In short, compressing a given volume of ambient pressure air to 120 PSI takes less work than compressing that same initial volume to 175 PSI. As a result, there will be greater losses, thus reduced efficiency.
(snip)
Theoretically, single stage compressors should be more efficient. Practically, we as consumers can't really take advantage of that fact.
a two stage compressor isn't compressing to 175 PSI unless the tank is at 175PSI. all a two stage compressor is doing is separating the compression into two events. big piston does half the work, small piston does half the work. compressing less is more efficient than compressing more, so the system that compresses "less" wins.
