Does anyone make a longer switch?
no704
I have this old face plate that I would like to use. It’s probably the only thing that was originally in this house that I have kept (including a lot of walls) it’s kinda thick though anybody offer a standard light switch with a little longer toggle?IMG_2040.jpeg
rlitman
Long Island
I doubt it. The dimensions were standardized a long ways back, and toggle switches need to fit into things like exterior switch covers and under protective straps that only allow for certain lengths. I'd expect spec grade 20A, 277V, and even fractional horsepower rated switches to all fit the same dimensions.
An industrial grade motor starter switch might have a slightly longer toggle, but retails over $80 and would make any box an uncomfortable squeeze.
tool_scrounge
Southern California
Odd NOS electrical stuff can often be found on EBay for pretty cheap.
walta
Dutzow Missouri
Drill hole super glue in steel pin shown in red (OK fiberglass pin) Mix coloring into Bondo extend the tip of the switch as needed.
Walta
N
no704
Installed! I thought a black switch was best! I did use a couple 1/4-20 nuts to space out the switch from the box. Tried some 5/16 but they were too much with the button head screws I had. Definitely useable. Nice to have it back up!IMG_2043.jpeg
AP514
Pearland, Tx
OH........Do you have a Link for those switches ? They might be my answer to a set up for my dual soft-starts on my AC unit.
I want to Isolate the Capacitors when the generator is in use.
