SouthernIllinois
- Joined
- Jan 14, 2024
- Messages
- 1,697
I learned something new today. I'm an experienced wrench turner. Do not own said set and now I kinda would like to.A lot here already know this, but some of the less experienced may not; the open end is thicker than other open end wrenches Snap-on makes.
I was just going to say precisely this, but KnurledNut beat me to it!A lot here already know this, but some of the less experienced may not; the open end is thicker than other open end wrenches Snap-on makes. Its not readily noticeable in pictures. This design helps with soft fittings where the flare end may not fit due to crimped ferrules, stacked fittings, etc.
If these are strictly for automotive, then I would recommend the double flare ends.
For use on machinery, equipment, plumbing/piping, or building maintenance the open end can be beneficial.
Keep in mind you will need twice as many of the flare/open wrenches to make a set.
Compared to a standard Snap-on combination wrench of the same size:
My experience, exactly.I got so used to the double ended flare ones, that when I got a flare/open in a size I used a lot, I couldn’t stop putting it down to grab a combination wrench.
This is the way.This is the garage journal so you are required to buy both sets. I never knew the open end combo version existed and I would prefer to have those over my double end line set.
I think the bottom line is that you can’t go wrong with either.Thanks for the feedback - seems to be pretty close to a 50/50 split of opinions
Thanks - it will probably come down to which set he has on the truck next ThursdayI think the bottom line is that you can’t go wrong with either.
I’ve got flare nut wrenches from several other manufacturers, and normally would offer some advice regarding alternatives, but you have already decided to go with about the best of the new ones available, whichever option you go for.
I don't see why a choice between the two needs to be made.
GET BOTH.
Sometimes you want/need to have an open-end flank drive AND the line wrench end at your disposal. Best to get this all in a single wrench to minimize how many tools you bring with you.
Other times you only want/need line wrenches, no need for open ended wrenches.
Getting both is a no brainer.
I do that with a lot of Snap On tools.I like buying the sizes you need not the whole set.
I like having the sizes I need when I need them, not having to wait til I can get them.I like buying the sizes you need not the whole set.
Good plan, same took me awhile to upgrade to SO tools nice to have a Snap on truck nearby or online. Sockets and wrenches I bought whole sets, no skips. Liliysdad has a good point it is a PIA to wait for a tool if missing a size tool.I do that with a lot of Snap On tools.
Lately it's just been buying pliers I need, not whole sets
Pliers are far more flexible and versatile. One plier can be used for a wide range of things. With the wrench, when the need is there, only 1 specific wrench size will work. So it’s best to have the set of wrenches where as sets aren’t nearly as essential with pliers.I do that with a lot of Snap On tools.
At the end of the day, it not that much.I see 282-296 reasons
