Snap-On line wrenches. Which style?
SouthernIllinois
I’m going with Snap-On one way or the other. My question is which style.
The kind with flare wrench on each end or the kind with a regular open end on one end and a flare on the other or the kind with a flare end on both ends.
TIA
Or this kind
1320
Arizona
I like the RXS open end/Flare combos more than the double Flare end wrenches. It does mean having more wrenches for a "full set," but the open ends are useful for their increased speed of use.
There are also the no longer in production RSXS style, which are a speed open end/Flare combo that I also like.
908Jim
I have the RXF style in metric because I couldn't afford the full range of the RXS style when I bought them 15+ years ago. If money were no object, the Open/Flare combo all day every day. Reason being it makes it much faster to remove old crusty fittings that you can't remove with your fingers.
I often think about selling my existing flares to buy the RXS style, but life has gotten in the way of major automotive projects and I cant quite justify it. In hind sight, the "fringe" sizes get used so infrequently I should have just gotten what I really wanted.
fozzy
Florida
Depends on what you already have for regular wrenches. The open end/flare nut version would be triple redundant in my box. If this is the same in yours, then I would go with the double end flare nuts.
KnurledNut
n/a
A lot here already know this, but some of the less experienced may not; the open end is thicker than other open end wrenches Snap-on makes. Its not readily noticeable in pictures. This design helps with soft fittings where the flare end may not fit due to crimped ferrules, stacked fittings, etc.
If these are strictly for automotive, then I would recommend the double flare ends.
For use on machinery, equipment, plumbing/piping, or building maintenance the open end can be beneficial.
Keep in mind you will need twice as many of the flare/open wrenches to make a set.
Compared to a standard Snap-on combination wrench of the same size:
NHtoolguy
Gilford, NH
Like many have said on this thread, I bought double-ended flare nut wrenches for the additional sizes versus the flare end/open end style. I have found that once the nut is loose, a standard-width open end (of which I have many), would run the nut in and out. That meant having two wrenches available, but in my poorer days I tolerated it. I did eventually buy a flare end/open end set with the "ratcheting" open end that allows faster repositioning. It was a bit of a luxury, and not really needed.
Dave455
Sussex, England
I was just going to say precisely this, but KnurledNut beat me to it!
In some situations, the thicker open end is possibly the better option.
Some pipe unions have much much taller fasteners, and the thicker open end allows you to use most of the height available.
Again, as KnurledNut correctly points out, sometimes you may not even be able to get a flare nut wrench past the fitting.
Some pipe unions, especially in hydraulic systems, have a round pipe fitting with just a couple of flats machined in. In such cases, the open end is the only tool that works, but the flats are almost always machined to accommodate the thicker open end of these wrenches, so I assume there is a standard for these.
Again, as KnurledNut says, most of these difficult fittings are found in industrial settings, rather then automotive.
I have the Snap On flare nut / open end and find them superb. If I was buying again, for tools to keep in my workshop, I would get these again.
If I was buying for exclusively automotive, I would probably go for double flare end. I would certainly do this if I was buying tools for mobile use.
Dave455
Sussex, England
Thanks for the feedback - seems to be pretty close to a 50/50 split of opinions
I think the bottom line is that you can’t go wrong with either.
I’ve got flare nut wrenches from several other manufacturers, and normally would offer some advice regarding alternatives, but you have already decided to go with about the best of the new ones available, whichever option you go for.
SouthernIllinois
Thanks - it will probably come down to which set he has on the truck next Thursday
alinc100
Dearborn,MI
I don't have a preference for one style over the other. I did just list a metric 10 piece set with the open ends on Facebook Marketplace. We will see if these sell quick or languish.
impactims
I don't see why a choice between the two needs to be made.
GET BOTH.
Sometimes you want/need to have an open-end flank drive AND the line wrench end at your disposal. Best to get this all in a single wrench to minimize how many tools you bring with you.
Other times you only want/need line wrenches, no need for open ended wrenches.
Getting both is a no brainer.
ATC
VA
If you are doing A LOT of fittings, I would go with open/flare for the speed.
If not, get the flare/flare for 2 more sizes.
1320
Arizona
In the toolbox in the shop, I have the open end/Flare combos. In the travel kit, I have the double Flare end wrenches.
SouthernIllinois
GET BOTH.
I see 282-296 reasons
Dakotadadv8
I do that with a lot of Snap On tools.
Lately it's just been buying pliers I need, not whole sets
Good plan, same took me awhile to upgrade to SO tools nice to have a Snap on truck nearby or online. Sockets and wrenches I bought whole sets, no skips. Liliysdad has a good point it is a PIA to wait for a tool if missing a size tool.
liliysdad
I absolutely wait to buy specialty tools until I need them, but I don’t consider line wrenches a specialty tool….especially SAE for me. I have several sorts of SAE wrenches from SnapOn, Proto, and Bonney.
I don’t use metric enough to have more than just a bare bones basic set, and all my metric stuff is new and clean enough that an open end wrench will take care of the vast majority of my needs.
rsanter
visalia ca
I have both and use both.
sometimes you need more than one.
if I had to decide to get one set or the other I would buy the flare/open set.
why?
sometimes you may want to use the open end for brass or other materials that you may want the fatter head.
once you break a fastener loose, you can go faster with the open end.
you may get into a tight spot where you need the thicker head to not round a fastener.
impactims
Pliers are far more flexible and versatile. One plier can be used for a wide range of things. With the wrench, when the need is there, only 1 specific wrench size will work. So it’s best to have the set of wrenches where as sets aren’t nearly as essential with pliers.
SouthernIllinois
I appreciate the input.
Just texted my SO guy and asked for this set ...
I am not a professional wrench turner - just a retired guy that fools with old cars and likes nice tools.
I already have full sets of Snap-On, Milwaukee, Craftsman and Icon combination wrenches. I'd rather have the additional sizes I get with this set.
I also have a set of old, made in USA, Craftsman line wrenches but want to upgrade.
Buying these for old US car brake and fuel lines - I don't fool with much of anything else.
