Show us your VFD conversions/installations
W-Cummins
Iowa
Interesting, never seen those form factor of SSR used in a cabinet. Do they have heat sinks behind them?
Well I guess you could say "kind of" they are attached to metal din rail mounts that probably provide some heat sinking but not much... Also there is no thermal compound under them....
No. Guessing not much load on them.
Bingo! So the relays are 240 vac @ 10 amps so I'm sure at full load and max switching they will get hot, however neither is the case here. These drive small 120v pneumatic valves, and they have a super low duty rating like 5 seconds out of 60! It looks like the oem dust controller has a range of up to like 3 seconds max. So if you look closely at the HMI display you will notice a cool down timer. The timer is used to prevent the cleaning "cycle" from repeating more than once per 60 seconds, I currently have it set to 1 second, with 1 second between the banks ( to allow the air to refill the "air tank" mounted on the collector) so it's over in 8 seconds then waits 60 more. Also under "Normal" operation this will probably be a rare event as I assume that the thing will not need to clean the filter banks more than a few times per day??
Beerhippie
Far NE Oregon
I mount those Croydon SSRLs directly to the aluminum backplate with a little compound on them and call it good enough. They seem to do fine, even with a pretty good load on them.
I have a few that are mounted in regular watertight single-gang outlet boxes. I use a piece of copper plate (flattened out type L pipe) that fits just inside a blank aluminum cover. Those also work fine.
One thing to be aware of, if you're not already--is that SSRLs tend to fail to the closed state. In some applications, this can be a real problem. I've rarely had any problems--and there are dozens in use around the brewery--but it has happened twice that I recall.
whateg01
doo dah, kansas, usa
...One thing to be aware of, if you're not already--is that SSRLs tend to fail to the closed state. In some applications, this can be a real problem. I've rarely had any problems--and there are dozens in use around the brewery--but it has happened twice that I recall.
When the makerspace built a powder coat oven, they used a ssr. It's failed a few times now. It's better after I convinced them to get the control box away from the side of the oven where it was cooking everything in the control box but it's still failed once since then. In this case, I am trying to convince them to add some sort of thermal runaway monitoring. I'm not sure what i would do in op case, but I think I would want something to back it up in case it fails. As stated here, it will fail closed.
Beerhippie
Far NE Oregon
For those who aren't fluent in electricalese, "closed" means ON.
