Ok location for a sub-panel?
lund
I am going to put in a basement sub-panel. Walls are poured concrete and I will have foam board + plywood below. I want to put it in Position A in the sketch below but could also put it in Position B. A question for you more knowledgeable code hounds: Is there a reason the panel cannot be located in Position A? The last thing I want to do is wire many circuits and then be told it has to move.
Thanks in advance!!
L
lund
Both locations are OK as long as you have front clearance AND meet the overhead requirements above the panel AND maximum height of the main breaker.
Thanks. That is what I was thinking.
The basement ceiling is almost regular height (just few inches low) since it is a Michigan basement. So I suspect no issue on overhead and there are no dangling obstructions or anything poking out from the corners etc.
It will be a sub-panel and I will (of course) have it on a breaker on the main panel. So I think no issue there. I was going to put it at a standard height above the basement floor. Would you happen to know a good range for that from low to high? This is going to be a longer (vertical) and narrow (width) sub-panel with a lot of smaller circuits branched off. So should probably keep the range reasonable. I was going to keep the upper breaker row at around 5'6" and the low would then be maybe 2' lower. I suspect none of this matters but the code seems to get more and more particular over the years so assuming what is presently around in the house (mid 70s construction) may no longer be considered ok.
By the way, before I removed it, some ***** put a nest of sprinkler control pressurized water tubes in directly above the main panel in the basement with all the water solenoid valves etc on a cold wall in a location with potentially very cold winters. These were old plastic lines too (maybe 20 years old when I cut them out). The previous owner did little and hired "pros" to do everything. It is hard to believe what stupidity one sometimes sees. That choice seems like asking for a serious and somewhat dangerous problem and I wonder why a pro would do that.
dave*99
Coastal NJ
The top circuit breaker height rule requires that the center of the operating handle of the highest circuit breaker is no more than 6 feet, 7 inches above the floor or working platform. Of course it can be lower.
L
lund
Thanks.
I am surprised you can go as low as the floor.
In my case this is all easy to meet.
For commercial places I think there are stay clears what you cannot leave around a panel. But for homeowners they pretty much do whatever they want. just no building obstructions around for code approval.
dscheidt
Thanks.
The height restriction is so the main can be flipped without needing a ladder or something. Clearance around the panel applies to residential, too, but since the fire inspector isn't coming around....
L
lund
Thanks.
I figure you are doing good if a homeowner does not hide a panel behind a bookcase!
No OSHA type inspections for private homes ....
larry4406
Northern Virginia
I recall that 3’x2’-6” footprint on the floor goes all the way to the ceiling.
No hvac, plumbing, etc above.
Reserved space I recall is the jargon.
dscheidt
NEC calls it dedicated electrical space. Requirements are in article 110 somewhere. If I remeber right, the vertical clearance is 6' or the structural ceiling, which is ever is less. Structural got used to make it clear a drop ceiling doesn't count, nor does building a soffit around ductwork or whatever give you a pass.
larry4406
Northern Virginia
Thank you.
I learned this the hard way at the day job.
wyliesdiesels
Modesto, CA
Thanks.
clearances on panels are required in residential buildings as well. sure homeowners can do whatever they want in terms of violating the panel clearance codes but theyre still violating it....and i would not want to have to move a bunch of **** in an emergency need to shut off a breaker
mm08822
Once the construction inspections are passed and CO issued, there are likely no more "checks" to ever occur. Fires, disconnect/reconnect of services, sale of property are the only likely triggers.
I've seen people put so much junk in front a gfci recept, it trips, they forgot about it, and I get a call for no power. Boy they sure can look stupid and I feel bad charging 2 hours to press a reset button.
sparky 1971
Central Iowa
I only charge an hour plus a $25 trip charge for resetting a GFCI or breaker, but I don't feel bad because I had already tried to have the customer reset it over the phone for free.
starquestMM
JC, Missouri
If you go with "A" keep in mind the panel doors swing when you mount it. Try to make it swing up against the wall rather than out into the room.
L
lund
Yes, for sure.
I think most panels you can configure to hinge either left or right. So it should be possible to do it right.
