I am going to put in a basement sub-panel. Walls are poured concrete and I will have foam board + plywood below. I want to put it in Position A in the sketch below but could also put it in Position B. A question for you more knowledgeable code hounds: Is there a reason the panel cannot be located in Position A? The last thing I want to do is wire many circuits and then be told it has to move.
Thanks in advance!!
Thanks in advance!!
