More Whatzits--Can we make this the official Whatzit thread?
When we lived on the farm, we had squirrels electrocute themselves regularly on the top terminals of the transformer that served our place. This happened dozens of times during the years we lived there--quite often we would hear a bang, see a flash out the window, and sometimes power would go out. I'd go outside and there would be a scorched squirrel carcase on the ground under the transformer pole.
Happened to us in the mountains. Power company had to replace the transformer.
An air hammer, in general, has a trigger that is either on or off, while rivet guns always have variable flow triggers. For instance, with a rivet gun,
Thanks for this. I read somewhere (here or another forum) that a certain air hammer (from HF?) had a good trigger, and could be run at low enough pressure to be used for simple riveting (tool box hardware). They suggested mating it with Yard store hammers. It's been sitting unused for a year, and your original statement had me worried.
Thanks again, as others have said, great answer.
MisterEd
Florida
Bought 6 odd clamps on Friday for $1.00 each because “Why not?”, they were cheap and they called to both of us that they had to be useful . . . somehow.
Learned what they were and that eliminated “Whatzit” but rather than clutter the Forum with another Thread I figured there might be an acceptable Sub-Thread of “Whatzit for?”
“Yates clamps are versatile tools to have in the office. Routinely used for securely holding harnesses during fittings, these can also be used to suspend stockinette or casting socks.”
Surely we can find a broader usefulness for these little Clamps!
geneg
Midwest
Prior to everything laser- suspended ceiling contractors used them to level the grid system. They attached the wall angles using a bubble or water level. Then used the clamps to pull/hold strings for the mains. The mains were suspended from wires to the ceiling or structurals above. Twisting the wires to tweak the mains to the "level" of the strings. The grid system may not have always been level, but it was in a consistent plane.
Oregon Dave
My guess would something like a tarp clamp; tighten it on the edge of a canvas tarp, put a rope through the eye and pull tight.
^ they are also referred to as a "button clamp" but I cannot find anything showing exactly how they are used.
additionally, there's another "Yates Mfg. Co" in Lake Geneva, WI that makes a "univeral sewing awl" that's getting in the way of the search.
From a 1958 American Machinist
Yates clamps for dipping , flange work , edge work , and bench or wall use come in four types
Looks like Wedgelock May have been a maker or distributor.
Holding PCBs
Saw a reference to holding metal for dipping prior to painting, but don’t see it now.
Lots of references to prosthetic creation too.
Guy I got mine from said he used them for simple sheet metal alignment prior to screwing or pop riveting together
I have no idea and have not tried to identify what they were originally intended for, but I would say...
...it's simply a gizmo that allows one to clamp two pieces of <insert flat material type here> anything together in the process of assembly/manufacturing for any purpose...
As demonstrated by the application that Fillauer (mfgr of orthotics and prosthetics...) is using them for - which is the fitting room. Similar to a tailor with pins. @MisterEd pretty much implied a perceived versatility for pretty much anything in his post inviting ideas - and I agree with him! @Outlawmws laughed, and my comment was intentionally funny, but I was only half-joking when I said they would make terrific clothespins. They would! Or for hanging anything heavy securely on any line. I really like the quick clamp/quick release (cam) action.
For those interested in the original intent - apparently Yates' overall objective ("small clamps for multiple uses") was as diverse as @MisterEd's intuitive reaction to them. (My 1948 source is Snippet View only, but if you're clever, you can compel Google Books to give you as many snippets as you can with search terms and stitch it together.)
The last line in the second snippet reads "for holding sheet metal parts, films, towels," (which took me several minutes of trial and error to get it to confirm my conjecture with yellow highlight...), but I can't read the rest of the line or predict enough of where it might be going to give me the next few lines in another snippet to see what other kinds of things/uses he envisioned
EDIT: Here's the rest! (Smarter than your average f&^%ing copyright limitation!)
"for holding sheet metal parts, films, towels, instructions, prints, display cards and many other items."
Although the unit in the photo looks slightly different than the units @MisterEd found.
Their TM (for the term 'SKIN-TITE') also mentions sheet metal.
senlow
Wheat Ridge, Colorado
Here is my whatzit. I acquired, along with a few tools, them a couple of days ago. Does anyone know what they are? I did finally figure out that the item at the bottom of the pic is a 6" steel rule. It's actually in the pic to provide scale.1000003445.jpg
Wrench97
Southeastern Pa
Clever? Compromises my searches, I guess.
Snerk. I'm reading this as self-deprecating humor - but you do know I was only referring to how to get around the Snippet views, right? Not general searches.
Just to re-state the tip, in case anyone is interested... With Google Books, if a document prompted by your search terms is behind the copyright wall, it will be provided it in your results list, but not the whole publication, just showing you the few lines that anyone is allowed to sample from any book, song, etc without permission. However, if you can deduce what terms might be in a preceding paragraph or a subsequent paragraph to the Snippet based on the content of the Snippet, you can go back and search on those terms, and it will provide another Snippet. If you do that with enough patience and cohesion, you can piece together in multiple Snippets a semblance of an entire article that is behind the copyright wall.
Beerhippie
Far NE Oregon
Can't you train an AI to do this?
Snerk. It's actually pretty good at deduction. The subject matter might be too esoteric, though. (In general, across all government, industry, and academia, that's the biggest challenge with AI. Wide is easy. Deep, not so much.)
Speaking of AI and Yates, I tested our old friend Chatty and the mannequin over in the Copilot seat.
I won't bore everyone with the results, but in summary, both relied on eBay, Worthpoint, and Google Patents. Neither provided the TM or any of the information on the clamps I was able to pull out of trade mags on Google Books. Neither used any information about Yates posted here. Neither cited GJ. Both provided descriptions of the clamps we already have with examples in our possession. Both mined the same Fillauer website Ed posted to conclude they were still being made by others for that and similar industries. ChatGPT found an irrelevant 1943 Yates patent (2,327,148) for a different clamp. To its credit, Copilot found the design patent (D134,622) for the clamps Ed found.
Zrxrunner
Eastern Iowa
Rebooting the whatzits!!! Obviously could be used for all kinds of stuff, but seems purpose built to mount to something tubular and clamp something square or rectangular? Anyone seen a vise/clamp like this? Google lens seems to think its a cylinder ridge reamer (lolol) or a leg vise. Dont think so, Tim!!
  • Like
Reactions: RTM
Zrxrunner
Eastern Iowa
Looks like a possibility. Maybe not to clamp to something tubular, but maybe clamp to an i-beam and HOLD up something tubular?
