The repurposing thread
atch
Columbia, Missouri
Got tired of my Jacobs chuck key.. dropping it into the lathe tray of doom, misplacing it between lathe and mill.. seemed the sob was always flying around.
Don't know why it took so long, but today was the day. Found an old pipe cutter handle in the stash box and voila. Nice reach, no weird handle, big enough to keep track of, hefty enough to hammer on stuff.
I don't know for sure how you would handle it with a lathe but on both my drill presses I have the key hanging on a chain. It NEVER gets lost 'cause it's always right there. Here's one of them:
FullRaceMerc
SoCal (SGV)
I remember reading an article where the guy set up a kill switch that was released when the key was slid into its parking place. So if the key wasn't put away the motor wouldn't run. Always seemed like a good idea, but not one I've ever implemented.
atch
Columbia, Missouri
Simple one - repurposed this funky old pipe clamp:
into a paper towel holder:
(Bonus repurpose: paper towel roll into funnel holder!)
Your paper towel holder reminds me of a couple I made for my shop. First is some threaded pipe screwed together. Second is some 1/2 x 1/2 inch square tube welded together. I guess you could call these "repurposed" as they both are made out of scraps.
BMW Rider
Calgary, Alberta, Canada
So now I can neither tighten the chuck or start the drill press cause I misplaced the key. :confused: :lol:
atch
Columbia, Missouri
Sounds like (if you were to actually do this) time to hit up garage sales, estate sales, and swap meets to obtain some extra keys. Which isn't a bad idea anyway. I've kept the keys for all the drills that I've ever scrapped and keep them in a drawer. They sometimes come in handy.
atch
Columbia, Missouri
On another note; on some forum (perhaps this one but I just don't remember) I was roundly criticized for this. The poster claimed it was dangerous in that you could start the motor while the key was still in the chuck and cause catastrophe. I really can't see how this could happen. One of these drill presses has had the key hanging on a chain for over 35 years and the other one over 25 years. I've never failed to remove the key before I started drilling. While tightening the chuck the chain is always touching my hand and it's just natural to remove the key before doing anything else.
  • Like
Reactions: 555
atch
Columbia, Missouri
And while we're on the subject of drill presses and repurposing, note the holes in the DP table. Those are all tapped and I have cut the heads off of bolts (the repurposing part) that screw into these holes. I rounded off the non-threaded end of them. They stick up an inch or two above the table when installed. When drilling I usually install a bolt in the appropriate hole and let the subject piece rest against that bolt before starting the motor. That way you NEVER have a piece of steel spinning at a dizzying rate (and slicing your hand at the same time) when the bit catches in the subject. One of the holes has one of these bolts installed, near the edge of the table away from the camera. Of course, I conveniently had the clamp handle partially obscuring it when I snapped the pic. These tapped holes were already in the table when I bought it. They are different sizes and I have no idea what the previous owner used them for.
When I don't use one of the bolts I use the HF clamps on the subject. These come with a nut which I replaced with those nuts that have a large loop cast into them. I don't know what they are called but every hardware store has them. That way it's really easy/quick to move the clamps around on the table without having to resort to using a wrench. A large wing nut would do the same thing.
gleman
Michigan And Florida too!
I got an old masker from a barn clean out.
A bit of cleanup and its a paper towel holder now.
dscheidt
Hey dsheidt, how 'bout filling us in on what that gizmo is that you attached to the DP post?
It's a little table to hold stuff, like a drill index, and some other often used bits. It was inspired by the one Lee Valley sells -- I got one as a gift a few years ago, and the column of my press is too big for it. Mine is rather larger and has an articulated middle section that moves the table far enough over to not interfere with the drill handle, but lets the actual table be closer to the front.
Clamp is round on one side, and a V on the other, so it has three point clamping. It also rests on the collar that holds the top of the table adjustment rack. The clamping bolts use the sort of barrel nut lots of flat pack furniture uses. I forget if I bought them, or if they're salvaged from some piece of scrapped furniture. Everything else is made from scraps. It really does tilt that much, from a combination of slop in the pivot holes, and flex in the clamping pieces, which are only 1/2" ply. But it works, was basically free, and it hasn't annoyed me enough to rebuild it.
FullRaceMerc
SoCal (SGV)
Part of the self training process. Do that a couple of times & you'll remember to put it away. ;) Or stuff a screwdriver in there to override the safety. Which might help you find the key hiding in the backside of the chuck.
The other solution is the one I use. That is to think it's interesting, but never put it into practice.
BMW Rider
I do actually have a few spare chuck keys from an old chucks and drills that wore out and got replaced. The main key is kept stuck to the drill press with a magnet, so not truly a problem most of the time. But I do sometimes play games of hide and seek with myself.
mikeinri
Would love to see this!
Mike
mikeinri
VERY nice!
Mike
Old Man Roger
Palm Coast Florida
Just repurposed this old corner cabinet into a portable sanding/grinding cutting cart. Note i can move my messy work outside with a floor jack
Your idea makes me think of those motorcyle/atv jacks. It would be nice if everything in the garage that wasn't already on wheels was able to be easily moved. Like a pallet jack but smaller.
Beerhippie
Far NE Oregon
img_1216-jpeg.2436782
TURN THAT RAKE AROUND!
I'd be bleeding the first time I walked by.
WoodsTruck
I have one. I use it under the quad, motorbike to change tires, sleds and also put a platform on it to install a 4-speed/transfer case in my Bronco. Mini pallet jack with decent lift.
BMWBOB2
I hastily chucked a bunch of tools into the new rack - we’ll need to make another, a little shorter, for all of the axes, sledgehammers, picks, etc with shorter handles, and another the same height as the first
Honestly, the shop is such a disaster at the moment that, trust me on this, it is A LOT safer with all these tools contained. When we get the shop organized to the point you can actually walk through, all of these tools will be accessible, but out of the way
Beerhippie
Far NE Oregon
I'm a little rake-obsessive. A coworker here loves to leave them lying around tines-up. Having actually stepped on one like that, it isn't as funny as it was in the cartoons.
BMWBOB2
An acquaintance was plowing snow with a small tractor with no cab: had a shovel across his lap. A tire chain link broke, and the flinging chain wrapped the shovel handle sending the shovel end into the side of his head, broke his jaw and got knocked out. One of the neighbors found him, still on the tractor, driving in circles out in the adjoining field, out cold.
Beerhippie
Far NE Oregon
I drove a pumper for the USFS many years ago. It was a mil surp deuce-and-a-half with 500 gallons of water and a big gas powered pump on the bed.
Anywhoo, we were practicing off-roading one day (we actually got paid for this) and my partner had his arm resting on the window frame with his elbow sticking out. A large stick got kicked up by the front wheel and he then got a ride to the hospital (an hour-and-a-half away) to get a busted elbow patched up. He spent the rest of the season with his right arm in a wrist-to-shoulder cast--which were hot, heavy plaster back then.
I'd warned him, but he knew better....
mikeinri
IMG_1217.jpegCleaned up a dozen old hand tools with an old plastic carrier for wine bottles, some scrap lumber, and a few screws. Our daughter and SIL just moved into an old refurbished farmhouse in N Italy this summer - there is A lot to do….
I LOVE that idea!
I've never seen a plastic carrier for wine bottles. Everything here is cheap cardboard.
Mike
mikeinri
Sounds like the makings of a scene from a horror movie: Final Destination maybe?
Mike
mikeinri
No shortage of ways to be killed or injured in a deuce-and-a-half. Dad's told me few from his two years driving them in convoys during the Vietnam War.
Mike
Beerhippie
Far NE Oregon
Mike
Well, at least no one was shooting guns or RPGs or throwing grenades at us!
A friend of mine drove a gun truck on Hwy 1 in 'Nam in the late '60s. He has stories.
Which truck absolutely fits this thread.
