ObnoxiousFumes
Southwest Sask
Yup, that’s the one we had. Lived in a camper for a year or two, parked it in an insulated shed for winter, and proper plumbing wasn’t really a thing. There were four of us kids and then the baby happened along.
Also the aforementioned shed had no windows, did I mention it sucked?
But I will say, it was an interesting character-building experience. Lol.
Then when we did get a “house” (house trailer/mobile home) it was still buckets, because the composting toilets we tried were a scam. I think we were there for 8 years. I don’t miss the toilet situation. 😂
ObnoxiousFumes
Southwest Sask
My DWV lines have a tendency to freeze in the winter. I mounted a nice toilet seat to a five-gal bucket so it's somewhat comfortable.
And, yes, Zappa. Apostrophe is the album. Side B, Nanook.
I thought it was Nanook Rubs It.
Or St. Alphonso’s Pancake Breakfast. Perhaps between the two? I never had the actual album, it’s confusing.
Edit: Just looked up the album, yeah it’s right at the end of Nanook Rubs It. Lol
rd65
Granite Falls, WA
I took apart a 1997 Waverunner so I could get in there and do an R@R on the midshaft housing that was leaking. Then I pulled apart the carb rack........it had NEVER been apart! You can see how the paint chips off around the screw heads when they've been opened up. I found slightly deformed diaphragms but they weren't crispy......and they were pretty clean too. Not to shabby for a set of 28 year old carbs!!
WaveRaider? Those were a ****** handling POS, all about top speed back then. Choppy water was not a friend when running any speed.
rd65
Granite Falls, WA
Managed to get the shop sink plumbed today. Did not turn the water on to the shop. For some reason I was thinking that if I had a leak it was too long of a run in the dark to turn the water back off. Well, *******, you have a shut off on the incoming line right there in the cabinet. Jeez. I think I am overly tired. Been a busy three days and sleep hasnt been going well over the weekend. I will turn water on tomorrow and check things out. Just need reinstall the door and tighted down the sink clamps.
kaymccampbell
Upstate New York
Isn't that the track right after Yellow Snow? If so, then I think it's on the A side, cause my wiggly brain says that whenever I'd drop that on the turntable, I'd get hit with Yellow Snow.
PWC Repair
Arkansas
Nope, WaveVenture (3 seater). The triples are VERY difficult to work on inside this hull.........BUT, the whole front hood and fuel tank can be removed in about an hour to gain access. I only had to remove the exhaust pipe and engine mounts and just slid the whole engine forward into the gas tank location to work behind it.
micromind
Fernley, Nevada, about 30 miles east of Reno.
Is this where you got your username from??
bmwrd0
Beaver Fever Oregon
Kept working on the saddle, and am mostly there. But, one thing about restoring a project you bought as a pile of parts: you don't know what you are missing until you need it. I am looking at various front gibs, and saddle locks. As I am not sure if I have them. Also, cheese head screws are needed.
rzims
Grass Valley, CA
Spent the morning trying to figure out why the little kubota 2600 tractor won't start. Ran fine last week. Thursday a little slow to start, but cranked and then fired up and ran great for 4-5 hours. This morning....no start at all....
Thought maybe a mouse chewed a wire, but don't see any evidence of that. looks like there's a relay under the dash or possibly the glow plugs?
Beerhippie
Far NE Oregon
Fixed a $1,600 refrigerated air dryer with $40 in parts and fifteen minutes' work.
This is one situation where living way the hell-and-gone out in the boonies paid off. We had this unit replaced under warranty, but if we lived closer in, IR would have sent a tech out to fix it. As it is, we now have two working units, one in use, one spare--which is good, given the failure rate we've experienced.
Now I'm trying to fix the original unit. It quit working back in March, which is when we bought the unit that was replaced under warranty. It might be something as simple as a temp sensor... or not.
rharman
SoCal
Built a new work bench.
I like the flip front trash disposal. I thought about it for my bench but went another direction.
I have an L-shaped bench and, in part of the open space at one end, I put a pull-out that holds two waste baskets - trash & recyclable. Either way, having trash disposal right at hand is a big benefit. With the pull-out, I can sweep the bench trash right into the can.
edit... Ha.... Just saw @zanyad appreciates it too. I've been reading the thread kind of bottom up.... :dunno:
SMOKEYBEAR
In the shop, sanding..lots of it. Benefit to living solo, I did the Tung Oil inside( temperature is swinging here day to night). Free bonus..higher than a kite and currently airing out the living room. OCD kicked in, 2 places to sand again, glue residue preventing the oil from taking and 1 snipe mark on the top I'm going to clean up. I plan to do 2 coats, I don't want it glossy, matte/ satin is my preference. It's even better now that the first coat is drying/ absorbed. Pics no order..
jblnut
In the Middle of MN
@jblnut - Are the red bins all loaded with various hose ends or is that just oher parts stock?
Yea they are. All the ones with white labels have two different ends in a drawer. The bottom ones I filled with my misc hydraulic fittings/adapters and couplers. Probably a bunch of **** down there I’ll never use but it’s all in the same place now !!
Reels of hose are downstairs and will likely stay there as I don’t plan to cut or measure hose upstairs to keep the mess out of the loft.
JustVicingIt
I made a lot of progress on a long gestating workbench, with Benchcrafted hardware. The tail vise is almost fully installed which means the top is about 80% complete. It's been slow as other jobs in the shop have been at the forefront because work but happy to take my time with this workbench.
niget2002
Josephine, TX
Went out to find a 5v USB charge brick for my wife's task light in her art room.
This is the second one we've had go out in the last 2 weeks. I don't think I've ever had one go out prior to today that I can remember. It's a good thing I have 5 million of them sitting in a box in the shop from back when phones all came with their own charger. Most of the places in the house where I plug devices in to charge has a larger Anker brick.
Need pics of this one.
rd65
Granite Falls, WA
I have one of those seats and some plastic bags in our earthquake supplies. Other supplies are stored in the Homer bucket.
Gotta be prepared where we live.
I just hope the big one doesnt hit while I am at work. Cant get in or out without crossing a very old bridge no matter how I try to leave. I work in Everett, WA. Waterfront city north of Seattle.
