Are these crimp lugs acceptable on 6-2 stranded romex?
Status
Not open for further replies.
PCustoms
VT
Do you really want to use Chinese no-name lugs on a high current circuit?
I'd say no, they aren't rated
whateg01
doo dah, kansas, usa
My real beef with them is the import stuff on Amazon tends to be very thin. So whether it would hold its shape over time, and thus keep a good connection is pretty sus.
T
tlmartin84
West Virginia
odd fuse panel in building wiring to need a ring terminal. have a pic?
The old sub panel lug was corroded, and I am unable to remove the set screw from it. I was going to remove it, drill the rivet out of the bus bar, and replace it with a bolt and lug.
I know you guys will frown at it, but at this point it is all that can be done.
mike93lx
Richmond, VA
Is this a new circuit that you are adding to the sub?
Especially being a sub, replacement should not be super difficult, and if one lug is corroded, I'd imagine other stuff is corroded/worn out too
A small sub is not expensive
T
tlmartin84
West Virginia
It isn't a sub, and our power company said it would be after the first of the year before a disconnect/reconnect could be done.
Basically that is what I am trying to do, is create a small sub panel to take the load off of the old box, until we can get a new service installed.
mm08822
Can the meter be pulled to replace the panel now? Finish the rest in conjunction with the d/r.
T
tlmartin84
West Virginia
You said it was a sub....
Half-assing a fix likely isn't any better then what you currently have going on
Look man, I never said sub. I said sub panel lug----the lug that feeds the sub panel off of the main panel.
Secondly I am not arguing with you on a forum over this. It needs completely redone. This isn't a fix, it is temporary until we can completely redo it.
I guess in your everything is perfect world, it is better for someone to not have heat, or power for months than a temporary fix, that is most likely better than what was there.
We can patch it up, and try to have heat, or disconnect it and use kerosene heaters, pick your poison.
T
tlmartin84
West Virginia
OK, but that's not the question......
Man, honestly the less we touch at this point the better off we are....
I am afraid to touch the wire going in and coming out. it is cloth covered and half rotten. The more that it is moved/messed with the worse it is going to make it.
I am going to feed a breaker off of the sub panel lugs/bus bar and move on until we can completely redo it all.
mike93lx
Richmond, VA
I hear you. Can't always rip it out and start fresh and it sounds like you know what needs to eventually happen. Just be careful to not let temporary become the new permanent
reader2580
Minneapolis, MN
That is crazy that it takes that long to schedule a disconnect/reconnect. I guess there are benefits of being a member of a 170,000 member CO-OP. I recall it was a week or so out to disconnect/reconnect power. They would have no problem doing the disconnect almost immediately for a situation that can't wait. I ran several hours past my scheduled reconnect time, but they said just call the power outage line, and they would send the night shift crew over to reconnect.
T
tlmartin84
West Virginia
I put in a request on 11/3 for disconnect to install a generator, and it is supposed to happen this Thursday on 12/4.
wyliesdiesels
Modesto, CA
yeah dont do that. thats just asking for a fire... youve modified it beyond the design...
Status
