Spiral Ratchet Screwdrivers
Eric Brown
I see that most of the sizes from Highland Hardware are shown as discontinued. I have some older adapters that are Apex, but their website shows most of those as discontinued also. Years ago I recall making an adapter from a bit holder with a 1/4"hex stem using a grinder and file, but it may have only fit the 35/135 smaller size Yankees.
The ones from LV are less expensive and feature a quick release. The Highland ones use a threaded nut to clamp the hex. They both have grip areas that are free to spin. My preference is the LV. You need to determine what size. There are at least four different sizes. The smallest size fits push drills. The rest spiral ratchets. You might also try to get some 3-jaw chucks with 1/4 hex shafts. Then you can drill too.
Eric Brown
Posted some G&J Products ratchet screwdrivers on the G&J thread, but wanted to explain details about them. The design is copied from the Zachary Furbish patent 593157 (Nov. 2, 1897) assigned to North Brothers.
Disassembly requires removing the screw close to the handle on the sleeve and then sliding it over the selector while holding the selector down. Then the selector and two pawls can be removed. The handle is simply pressed on. To remove take a board and drill a hole sized to fit over the main body. Clamp body in vice with board close to handle and then use hammer on board to knock handle off.
Removing the shaft requires removing a keep (stop) on the backside of the main body closest to the screwdriver end. I found using a small jewelers saw and cutting a slot where the keep is allows removal. Picture #2 shows the backside and two keeps.
Re-assembly starts with first putting the shaft back in the body and replacing the keep. I used a washer with a flat inserted into the groove and then ground down to match the body.
Next put the pawls in. Note that if put in upside down, it will reverse the switch position for direction.
Put the slide switch in and slide the sleeve on while holding the switch down. Put a drop of oil into the screw hole and replace screw.
G&J post https://www.garagejournal.com/forum/threads/gormully-jeffery-tools.425971/#post-11440847
  • US593157 North Brothers ratchet screwdriver.pdf
Eric Brown
Few typos you might want to fix, maybe more, way too earlier here for technical review.
Seems like exactly how to do a Yankeee driver too.
Thanks. Guess I was still somewhat asleep. Hope I got them all.
Eric Brown
Ok, I'm done with spiral ratchet screwdrivers and also ratchet screwdrivers. Many share the same ratchet mechanisms. The files are ZIP files that un-compress to Excel. They are both big files. About 50MB and 12MB.
When it opens you will be on the home page. The drivers are listed alphabetically. There are small pictures of each driver. Clicking on the picture takes you to another sheet with more information on that maker. There are RETURN buttons to take you back to the home page.
At the bottom left you can see the different sheets. You can click on them also. At the bottom right is a magnification adjuster so you can enlarge (or shrink) the pages and pictures. I tried to put things so they will print out in landscape orientation.
Note: My main concern was finding matches of Fulton tools to German makers. I added a bunch of USA made ones as a comparison.
They are not complete lists by any means.
Edit: Added North Brothers Yankee 33H
  • Ratchet Screwdrivers 1-11-26.zip
  • Spiral Screwdrivers Jan 15 2026 (2).zip
WisJim
Menomonie, WI
I've been spending time sorting my related screwdrivers to figure out patent info for older screwdrivers that I have. I haven't paid much attention to imports or secondary brands--I'm finding some oddities just in the basic Yankee/Stanley and Millers Falls tools that I haven't figured out. I'm away from home for awhile so nothing happening with them now.
ararat
Ararat NC
Little ratcheting screwdriver Yankee North Brothers. Patented May, 1 1906 I believe it says. 5 3/4" length. Model No 45.
It has remnants of a coating over the brass. Chrome or Cadmium or something else?20260902_190049.jpg20260902_190145.jpg20260902_190129.jpg
Eric Brown
Probably nickel. Chrome was expensive and has multiple steps. Cadmium or zinc don't look as nice as nickel.
