Electric unit heater
qmdv
I found a used 10,000 watt unit hater. It was wired from the factory for 480 volt. It says it can be wired single phase. If it is wired single phase will it still be 10,000. Here is the rating plate attached.
mm08822
Even if you were able to reconfigure the element connections (just a maybe) the fan would still be 480v.
The wiring and contactor sizes would need to increase.
Probably also a transformer with only 480v input.
I would pass on it.
