Vintage Blue Point, Blue Points Chicago and Blue-Point tools thread
Steven 33
No part number just says Blue point Chicago. Believe it's a bushing Extractor maybe for Buicks?
MR.X
Anyone seen this in a catalog? 13/32 X 5/16 S-9057 I was thinking maybe Zenith Carb gas adjusting valve for Model A but.....
snapmom
Florida
Ford. 13/32 for dash adjustment nut. 5/16 carburetor needle valve inside of carburetor. Would date early 30s
MR.X
it’s in the Blue Point wrench cat
Hi. So in the cat. they say there's an earlier version of this Ford Model A carb wrench (S-9059) Do you have one? I'm guessing the 13/32 end was 7/16 on that one.
snapmom
Florida
Yes, I have one, was changed
genog
Silicon Valley
Found a Blue Point dbe......in whitworth
Once upon a time as a teenager, I had an ole MG
I'm not sure what wrenches and sockets I used to work on it.....
A wrench like this one may have come in handy
I'm guessing I used a combination of SAE and Metric tools to work on the stupid thing which was constantly
Glad to have gotten rid of that unreliable lousy car :ROFLMAO:
snapmom
Florida
1936 Buick oil line wrench S9813. For all 1936 series. Space for turning the nut is very restricted and obstructed on the 1936 models 3/8 and 1/2 opening
snapmom
Florida
Blue Point No. 1091 long handle tappet wrench. Date 1937. Opening 1/2”. Length 12”
A odd one. Cannot find it listed in any cats. shape is different, has a small bent neck. Has no size stampings. Has a odd model number as to other long tappets
MR.X
Thanks. So it looks like the markings are showing up around 1935….so far. Based on comments I’m not sure I explained what I’m trying to do very well. I have a Par-V marked single offset wrench. It also has a USN- NAF pre WW2 contract # on it. The wrench is a dead ringer for a Blue Point but isn’t marked Blue Point BUT I noticed it has the forge/ foundry marking under the offset end just like Some Blue Points I had seen. I was trying to get a bigger sample size and it looks like Blue Point was doing that at least around 1935. This gives me some confidence that the wrench may in fact be a Snap-On / Blue-Point related 1935 ish PAR-V used for filling a Navy contract. Below is my 3/4” Par-V single offset next to the image of a 1935 3/4” Blue Point single offset taken from an eBay auction. Obviously both have the 24D (24/32?) marking. Of course my Par-V could just be a Blue Point blank used for a mil. Contract the someone stamped Par-V but……seems unlikely.
So I kinda forgot about this but here’s a 3/4” single offset box Blue Point with the same forge?/ foundry mark indicating size. 1935 date code would line up with Pre war NAF number and possible Par-V time frame.
snapmom
Florida
M4272, 5/8 on both ends. no date code, Cannot find it in any of the cats. Probably early 30s probably for a Mack truck as most M codes from that era are Mack
snapmom
Florida
Blue Point fender body dolly. 689, HB350, BF773
683- about 1931-1938 HB350 38-40 BF773 - 40-45
The same dolly, but looks like two types.
The pre about 37 the angle looks different in the cats, also the two pictured are different. but I am not sure if one as been modified. Looks factory. both have the same logo, both have the USA stamp. But it is possible they were made in the same year 37-38. neither has a date stamp, but that is about normal in the 30s BP dollies.
LNKMK8
Overland Park, KS
Here is an old one... Blue-Point Boxocket X-30. I believe the end was modified as it carries the standard X-30 number, but it was done long enough ago and well enough that you can't really tell. I didn't find anything in the catalog that matched the design, so I assume it was done in someone's shop long ago. Marked -29 on the backside, which I assume is the date code.
snapmom
Florida
Its 1929. Usually a factory special would have a different (or added) model number like S9514. But if it were owner mod, why would both ends be changed. so, this is one you may never figure out. not in any cats I looked at, but maybe someone else can find it.
MR.X
Running into Merlin Packard stuff at fleas lately… no secret that Snap-On / Blue Point filled some of the contracts…..found this actual Blue Point marked Regular Whitworth wrench on the $1.00 table and picked it up to compare. 42 date code on rear.
Steven 33
Anyone got any info on this? Can't find in cats
snapmom
Florida
could be the same box. the odd thing is the logo, Blue Points did not make sockets in that era.
MR.X
Buick maybe with the 98XX #….. has a “30” code on it. Obstruction offset is to reach a 15/16”.
snapmom
Florida
A blue point XD3436 that started out as a X-3436. Probably should have been a Sxxxx. has two deep offsets, the D was added as a hand stamp (much smaller than a normal D. Has a 44 code. not in the cats.
It is not uncommon to see factory mods in Snap on and Blue Point, that never show in the cats.
