bushing remover, came in three sizes. model numbers 1233, 1234, 1235No part number just says Blue point Chicago. Believe it's a bushing Extractor maybe for Buicks?
Ford. 13/32 for dash adjustment nut. 5/16 carburetor needle valve inside of carburetor. Would date early 30sAnyone seen this in a catalog? 13/32 X 5/16 S-9057 I was thinking maybe Zenith Carb gas adjusting valve for Model A but.....
Have you seen it in a catalog?Ford. 13/32 for dash adjustment nut. 5/16 carburetor needle valve inside of carburetor. Would date early 30s
Hi. So in the cat. they say there's an earlier version of this Ford Model A carb wrench (S-9059) Do you have one? I'm guessing the 13/32 end was 7/16 on that one.it’s in the Blue Point wrench cat
So I kinda forgot about this but here’s a 3/4” single offset box Blue Point with the same forge?/ foundry mark indicating size. 1935 date code would line up with Pre war NAF number and possible Par-V time frame.Thanks. So it looks like the markings are showing up around 1935….so far. Based on comments I’m not sure I explained what I’m trying to do very well. I have a Par-V marked single offset wrench. It also has a USN- NAF pre WW2 contract # on it. The wrench is a dead ringer for a Blue Point but isn’t marked Blue Point BUT I noticed it has the forge/ foundry marking under the offset end just like Some Blue Points I had seen. I was trying to get a bigger sample size and it looks like Blue Point was doing that at least around 1935. This gives me some confidence that the wrench may in fact be a Snap-On / Blue-Point related 1935 ish PAR-V used for filling a Navy contract. Below is my 3/4” Par-V single offset next to the image of a 1935 3/4” Blue Point single offset taken from an eBay auction. Obviously both have the 24D (24/32?) marking. Of course my Par-V could just be a Blue Point blank used for a mil. Contract the someone stamped Par-V but……seems unlikely.
Its 1929. Usually a factory special would have a different (or added) model number like S9514. But if it were owner mod, why would both ends be changed. so, this is one you may never figure out. not in any cats I looked at, but maybe someone else can find it.Here is an old one... Blue-Point Boxocket X-30. I believe the end was modified as it carries the standard X-30 number, but it was done long enough ago and well enough that you can't really tell. I didn't find anything in the catalog that matched the design, so I assume it was done in someone's shop long ago. Marked -29 on the backside, which I assume is the date code.
