recommend an induction heater (for bolts) please
Junkman
Northeastern CT
I need to replace the body mounts on my 1962 Chevrolet, and I was thinking the induction heater would be just the tool to break the bond to the J-nut that the body bolt goes into. Has anyone tried the induction heater for this application?
dscheidt
So THATS how it works! I’ve heard maybe half a dozen explanations on how heat will facilitate the removal of a stubborn fastener but none that ever made sense to me. Is this also how it works to free a fastener that’s rusted/corroded in place?
that, and rust expands differently than steel does, so there's force breaking the bond.
pbon
I use to think the heat was supposed to expand the metal around the bolt, but that did not make sense when the bolt was often ending up red hot.
zendriver
Indiana
Used one for brake caliper frame mounting bolts, not really rusted, but would not budge, untouched for 25 years.
Use mine a lot on old stuff. just need to break the tension.
seber
Deep East Tx.
It is nothing more than a current limiter and if it runs on 110AC then a cheap transformer. No excuse for the exorbitant price
alwaysFlOoReD
Airdrie, Alberta, Canada
Just learned this recently, and I believe it was on this site. Heating the bolt makes it want to expand, and because it's constricted by whatever surrounds it, it expands in the direction of least constriction, usually length. Once it's cooled it shrinks slightly. Repeated heating and cooling can help shrink it more. The diameter is reduced.
Steve_P
In the (Honda) crankshaft bolt case where you're heating the head, yes, you're lengthening it and reducing preload.
In the rusted bolt case, no, you're dealing with a different issue, and it's the expansion of the diameters this time
nbpt100
Massachusetts
I am thinking of investing in one of these types of heaters. I estimate my use down to a about 6 to 10 times a year. Not heavy use. I am thinking of the Vevor 1500 or 1100 watt, or the Solaray 1100 watt. I am concerned the 1500 watt or higher may trip the breaker. On the Vevor, the coil leads look shorter. Maybe they are not, but it kinds looks like they are and that may make it harder to use in some locations.
Anyone have experience with the Vevor products?
Bmw4life
Canada
I dont have any experience but my buddy had no luck with 1100w. I would not go below 1500w. It shouldn't trip the breaker. What you really want is a tool that works, and you don't have to waste your time and money and be frustrated.
308guru
Basically, you are just lengthening the fastener due to thermal expansion which then lessens the preload- and the torque required to remove it.
I call B.S. on that idea. I've had fasteners with no, or next to no, load on them, just corroded/rusted in place and won't turn. Apply (a lot of) heat and voila, out it comes. I'll offer my thought that the heat causes one or both components to expand enough to break the bond of the corrosion/rust.
nbpt100
Massachusetts
Both factors could be true at the same time. So not BS. Maybe not the whole story, but a factor.
nbpt100
Massachusetts
At 1800 watts and 120volts you are pulling 15amps. If you are on a 20 amp circuit, not a problem. If a 15 amp circuit, you have a problem. The cheaper ($500) Induction Innovations does not provide a wattage or current draw on their website. All I can find is voltage. The other two brands mentioned above have 1800 and 1100 watt units. Sure, I want it to work well, but if it keeps tripping the breaker, is it working?
Bmw4life
Canada
Go for 1800w. Mine is 15 amp and didn't trip the breaker. Just don't load anything on that breaker while using the heater.
You'll only use it for a couple of minutes here and there. It's not like it's "on" for an hour and the breaker keeps tripping.
Get 1800w you won't regret it
Beerhippie
Far NE Oregon
Shops need 20A breakers, wiring and outlets. If your wiring is already 12 AWG (yellow Romex, if it's newer), you just need the breakers and outlets.
I have several corded 120V 15A tools.
Hakeem
Chicago
I have one of the cheaper knockoffs, a “hot rod” or something like that, and it works well but is slow. The name brand ones are much faster.
All that to say - if you’re going to get one of the knock offs get the 1500w at least.
