KnurledNut
Wera (Norbar) Made in UK
Head Made in Germany
That’s great. If it’s convenient, could you please provide the exact model number?Finally got my order from Mister Worker, some Hazet ratchet wrench adapters and Stahlwille locking extensions. I'm looking to upgrade my extensions and didn't have any locking ones so I thought I'd try these. The locking mechanism is unobtrusive and easy to use. I might just get all locking ones instead of regular ones at this point at the expense of my wallet.
Thanks for the info ! I´ll try it.You might want to exercise that a few times (also at different settings) and see if it actually releases every time. I have one of these in one of my kits and even though the dealer already sorted through a few before shipping me mine, it still hangs/ won’t release from time to time. These are (were?) notoriously known for that behavior, sadly.
Kind regards,
Olli
The Hazet wrench adapters are great but you need good ratcheting wrenches (with switch) to pair them with, I tried many and ended with Facom. In the end, there's a Gedore red set (previously Carolus) with ratcheting wrenches that includes these 4 adapters and comes a bit cheaper with negligible difference in quality compared to Hazet + Facom 10, 13, 19 wrenches. But with the Gedore set you getFinally got my order from Mister Worker, some Hazet ratchet wrench adapters and Stahlwille locking extensions. I'm looking to upgrade my extensions and didn't have any locking ones so I thought I'd try these. The locking mechanism is unobtrusive and easy to use. I might just get all locking ones instead of regular ones at this point at the expense of my wallet.
Known as X-Cut. I have only those.box joint 73 02 160
That’s not a “box joint”.Got three different hinge design 160mm long Knipex cutters now:
The box joint 73 02 160 are the last ones I got. They seem to be very precision made, no wobble at all and the box join will of course help with that a lot. They are not too tight and I'm sure they'll loosen up with time like my other two did.
I did not measure it but I assume the box joint design allows for a thinner pin and less wall thickness, so the pivot is probably the closest to the cutter edge on those.
The X Cut is indeed like this.An actual plier “Box Joint” has one leg passing thru a slit or slot in the other plier leg
But that is exactly what the 73 02 160 Knipex X-cut are. A true solid fixed box joint with a fork-and-knife pivot setup.That’s not a “box joint”.
That’s a “solid joint” or sometimes “boxed joint”.
An actual plier “Box Joint” has one leg passing thru a slit or slot in the other plier leg, similar to the Knipex Cobra or alligator or Twingrip pliers.
Large pliers used yo be made with actual box joints, sometimes, but most rarely are nowadays due to the extra cost of manufacture.
The now discontinued Channellock 349 was an example of a true box joint, although Channellock seems to have forgotten what the term means.
Jewelers pliers for precision work is were true box joints are still routinely seen. (And roofer’s tongs for bending sheet metal for larger pliers).
That’s a neat set Monte, I take it it’s referred to as safety that in the US we call it security. Love the metal box, thanks for sharing.
yes i think it is commonly called "security bit set". In germany it´s called "Sicherheits bit set" and you can translate "Sicherheit" to "security" or "safety".....That’s a neat set Monte, I take it it’s referred to as safety that in the US we call it security. Love the metal box, thanks for sharing.
nice Stahlwille collection !Finished my Stahlwille locking and wobble extensions set. I put in the three that I already owned in this picture.
Do I need to have my eyes checked??
Is the Kaiser of Hazet using……..Gedore ?????
I'm pretty sure that's made by Schroder. Many consider it to be the best ratcheting tap handle available. Snap-on used to sell them under the Blue-Point name.From the depths of my workbench, cleaned and ready to use: Athlet ratcheting tap holder/ tap wrench.
Kind regards,
Olli
Positively surprised that it is made in Germany. Looks sleek and sturdy made for these things.
Is that a “clicky” ratchet, or a roller ratchet?
yeah that was a big surprise. I don´t think there is another german manufacturer of these left.Positively surprised that it is made in Germany. Looks sleek and sturdy made for these things.
it´s clicky.Is that a “clicky” ratchet, or a roller ratchet?
It´s like the Wiha screwdrivers. Black = grippy / Red = slippy^ I was curious as to what the "feel" is like on that handle. Is it grippy grippy? Or kind of smooth? Or squishy?
Looks well-proportioned.
Does anyone know if Stahlwille put out a catalog for VW Type 1 Beetle tools like Hazet did?
Stahlwille in their main catalogue did list sets of tools for VW and other prominently German marques. I have a number of their old catalogues and product sheets in English. Been collecting their tools for a while . I’m on the way to having a complete set of the set in the Rollmaster they listed for Porsche aircioled in the early mid seventies.Does anyone know if Stahlwille put out a catalog for VW Type 1 Beetle tools like Hazet did?
Any chance it is deep enough to hold Drive-Loc blades without much slop?
I think this is only for the usual 1/4" hex bitsAny chance it is deep enough to hold Drive-Loc blades without much slop?
(My kingdom for ratcheting Drive-Loc handles.)
