Model A Fan
I'm wiring in a switch and I'm wondering if I can run two lines of romex under the same staples and through the same hole in the metal box or if I have to separate the incoming and outgoing lines.
I'm doing new lighting based off a switch for some LEDs and doubling up would be tidier but I also want to remain compliant. My other thought was run the romex I to a box above, run THHN down some conduit to the switch and then the THHN goes back up the conduit to the lighting. All I'd have to do is put everything in a junction box up top and run the ground and black wire down and back up the conduit where the neutral, hot, and ground would then proceed to the first outlets.
This is all with 14AWG for lights and a 15A breaker. It will only power outlets into which LED shop lights would be plugged.
Thank you!
Thank you!
